Question about AlumaPro Car Audio & Video
Is there a diagram for wiring up the 15 farad cap i have the relays and stuff just need to know how to wire it up and what gauge to use email DKGRAY99@gmail.com
fastboyz
  • 674 Answers
SOURCE: distributor cap wiring diagram
Posted on Sep 17, 2008
4x4papa
  • 14 Answers
SOURCE: 917.271021 Wiring Diagram
here's one, not very good. Let me know if this doesn't help and I can clarify the locations of numbers. 4x4papa
Posted on Nov 15, 2008
Snorky8758
  • 3 Answers
SOURCE: Need wiring schematic showing fuel tank to gauge in 1972 chev trk
There should be a wire that connects to the gas tank sending unit and maybe another wire connected to a spade terminal that could be screwed down to the in-tank sending unit. The brown wire from your gas tank sending unit goes to the back of the dash guage. All the gas tank sending unit does is give a "ground" signal to the dash guage. Whatever you do, do not connect the brown wire to a positive 12 volt wire as sending 12 volts through the gas tank sender will explode the gas tank! Take a look at this website and it will all clear up for you.
http://auto.howstuffworks.com/fuel-gauge1.htm
You did not say if your dash guage is wires with a plug-in or single wires connecting it. If what i've given you here is not enough to fix the whole problem then respond back with how does the wires connect to the back of the guage. Good Luck!
Posted on Jan 15, 2009
SOURCE: need wiring and 9pin connector diagram
Dell (Altec Lansing) A425 Subwoofer Pinouts
This is a standard female DB-9 serial port.
Here are the pinouts.
Pin 1 = Left Speaker Out +
Pin 2 = Left Speaker Out - (Common Ground)
Pin 3 = Left Line In +
Pin 4 = Right Line In +
Pin 5 = Left/Right line In - (Common Ground)
Pin 6 = Right Speaker Out +
Pin 7 = Right Speaker Out - (Common Ground)
Pin 8 = Power A
Pin 9 = Power B
Jumper (short) Power A to B to turn on.
If you want a volume control you need to put one on the inputs. You will buy buy a stereo volume control or potentiometer.
Here is some info on how to do this.
http://g4tv.com/screensavers/features/43665/Pump-Up-The-Volume.html
Cheers!
Posted on Mar 24, 2009
  • 79 Answers
SOURCE: Need spark plug wire to distributor diagram for 2000 dodge ram
Hi
Posted on Apr 09, 2009
I have a 1992 Toyota Celica convertible. Its an import from Japan (JDM) model. It is the Limited 300. The car is the ST183 version. My problem is the power windows and central locking have failed, i...
I suggest check the next diagrams (click over image for zoom); the legend "a", "b", etc. is the location...
Fig. 2 02 Door lock wiring diagram-1992-93 Celica
Fig. 2 03 Door lock wiring diagram-1992-93 Celica
Fig. 2 04 Door lock wiring diagram-1992-93 Celica
Fig. 1 64 Power window wiring diagram-1992-93 Celica
Hope this helps; keep us updated.
Jul 08, 2011 | 1992 Toyota Celica
Need wiring diagram for tsunami 1.2 farad capacitor cap.
After a bit of searching I found the instruction manual:
http://a248.e.akamai.net/pix.crutchfield.com/manuals/120/120pp912u.pdf
Hope it helps.
Mar 05, 2011 | Metra Tsunami 1.2 Farad Capacitor
What number of cable should use on rockford fosgate 1 farad capacitor thanks
If good brand name wire, jl rockford monster kicker, the 8 gauge wire will be fine. if buying it at walmart or somewhere, then use 4 gauage wire
Jul 19, 2010 | Rockford Fosgate 1 Farad Capacitor Cpc10...
How to wire a 10 farad power acoustik capaciter
With BIG wires from battery to cap and then to your amp.
Good idea to put fuse or fusible link between bat + and the cap. Protects against fires.
If one wanted to be safe from starter motor transients I would gate the + power lead with a power relay between the battery and the cap. This relay should close when you are in run or accessory position of your key switch. I recommend this as there are so MANY dead car audio amps. Just search for them on here! A bunch of them MIGHT be caused by inductive transients during starter motor shutdown. Note the inductance is in the grounding wire from teh battery to the engine/chassis.
Jan 23, 2010 | Power Acoustik PCX10F POWER ACOUSTIK 10...
Need diagram to install capacitor
Hello tommysgirl,
Here's a link to Car Audio Help's cap wiring diagram.
Hope this helps.
Aug 27, 2009 | Power Acoustik 1.2 Farad Capacitor Pcnc...
Diamond wire diagrams for capacitors 3 0 farad
i think you mean you want to know how to wire 2x 3.0 farad 12V capacitors into a 24V truck??????? let me know i can help with this,ben
Aug 13, 2009 | Car Audio & Video
Just got a ppi dcx1000.4 need to know how to bridge?
Use some good 4 gauge wire to the amp and ground - and getcha some like 12 gauge speaker wire(MONSTERCABLE) I recommend using streetwires brand but any reputable shop around your town should have some good solid 4 gauge. Might want to invest in at least a 1 farad capacitor too if your lights start dimming when the bass hits you'll know its time for that cap-they're alot cheaper than a new alternator-good luck
May 27, 2009 | PPI DCX-1000.4 Car Audio Amplifier
Serious contest
ok well to start are the subs 4ohm dvc or 2 ohm dvcs? heres some questions that will get you started. what kind of car do you have and what is your alternator amperage output right now. the kicker 2500.1 is big enough for 2 L7 15s. i would most deffinetly recomend a large capacitor for this system. with 4 l5s you will need roughly 3000 watts rms. so 2 of those amps, 1 amp per 2 subs will be more than enough. im not familiar with the kicker amp line. if they have anything more like a 2000.1 that would still be plenty power and less exspensive. if you have 4 ohm dvcs then you can wire to 1 ohm. is the 2500.1 1 ohm stable? thats something you need to find out. your deffinetly going to want to run atleast 2 gauge wire. i have 4 L7 15s and i run 0 gauge. if the subs are 2ohm dvc you will have to figure out how you would want to wire those. and when i say a large cpacitor i mean like 10 farad or more. i use a 30 farad power acoustik. alot of people would say this is a crappy cap. true it isnt the best one on the market but im running some serious power in my vehicle and this thing gets the job done for sure. if you havent already done THE BIG 3 is a good idea to upgrade. just look up the big 3 and you will find it easily on google. for 4 l5s you may need a High output alternator. 200 amp would be ideal. i know it sounds like alot but if you dont do everything the right way the first time you will end up doing it the right way at some point. if you dont get effiecent power to your system your not going to be happy with it at all.
just to give you an idea so maybe you can educate yourself alittle more before you get youself into this whole thing. im running 2 hifonics brutus bxi 2608s 2600 watts at 1 ohm rms. each one to 2 s15l7s 4 ohm dvc. a 300 amp alternator 2 batterys all 0 gauge wiring and the 30 farad cap. those subs and amps your talking about can pull serious amperage from your car in excess of 300 at a solid base note. let me know how you make out.... my email is motomartin315@aol.com if you have any more questions. just trying to help.
Aug 11, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Humming in woofer
A wiring diagram could be difficult if not impossible to find but you should'nt need one anyway.
You're correct in saying it's most likely a filter cap in the power supply, of which would be a larger electrolytic cap that may even display signs of being faulty. Look for leakage of crusty brown stuff on the end where the rubber seal and leads are, or possibly the other end, shrunken plastic skin, bulging or other signs of over heating. Replace any you find that have visual signs of failure.
Sometimes you cannot tell by looking if a cap is bad but it would'nt cost that much to replace the larger ones in there anyway. Open up the unit, write down the electrolytic cap values
you find, go buy replacements and replace em.
You're hearing 60 cycle hum so the filter(s) you need to replace will be quite large physically and have a fairly high micro farad value....such as 1000, 1500 or 2200.
When buying replacements, get as close to the micro farad rating as possible and buy at least the same voltage rating, or higher. Be sure to solder them in correctly, there is a negative and positive lead and you dont want to get those reversed or....
BOOM!
** Please re-comment if the suggestion did not work for you, there may be several other possibilities.
** Please add a comment before giving a rating other than Solved
Oct 23, 2007 | Altec Lansing ADA 885 Computer Speakers
Im not get any loud base, even with the gain at full turn
an orion 2500d requiers 2 4 gauge power and ground wires to work properly.
Aug 22, 2007 | Orion 2500D Car Audio Amplifier
Car Audio & Video Logo
71 people viewed this question
Top AlumaPro Car Audio & Video Experts
xxxxxx xxx
Are you an AlumaPro Car Audio and Video Expert? Answer questions, earn points and help others
