Question about Honeywell Heating & Cooling
Snowflake blinking in one zone
Our AC unit is working in two other zones. The main zone will not kick on and the snowflake is blinking - I've changed the batteries in the thermostat. Any other suggestions out there?
Thanks in advance!
I saw that my snowflake was blinking while the unit was in the 5 minute lock out state (after power up), but went to steady after that.
Posted on Jun 15, 2008
Flashing snowflake on ac no idea name of thermostat
Usually a flashing snowflake means you are in a time delay for cooling. If the snowflake becomes solid, cooling should start. If it never stops flashing, possibly it's bad. Turn power off to air handler, remove stat and put red green and yellow together and turn power back on. If indoor AND outdoor work and cooling begins the tstat is definitely bad.
Aug 18, 2017 | Heating & Cooling
What does the snowflake mean on a Honeywell thermostat in cooling mode. Also had the problem in the heating mode.
The snowflake means it's cooling. If the outdoor unit is not running then the problem is likely outside.
May 21, 2017 | Honeywell Heating & Cooling
Flashing snowflake
The flashing snowflake means it is in the cooling mode, but is waiting for itself to 'time out' after a call for cooling. It should be about a 5 minute delay then should come on automatically. At that poing, the flashing snowflake becomes steady.
Try it one more time and set the timer on your smart-phone to ten minutes before you touch it again. If that time elapses and no cooling and it is still flashing there's possibly a problem in the thermostat that will necissitate replacement.
Aug 02, 2014 | Honeywell Heating & Cooling
I have a digital Honeywell thermostat that has a blinking snowflake. When the thermostat is on auto mode it does not turn on. When I turn the thermostat to fan I can feel and hear the air blowing out of...
If the thermostat has a blinking snowflake then it is in time delay mode which sometime can take between 5 to 7 minutes before it will turn the AC and Fan On......Then it will go to a solid snowflake.
When you turned it to fan On it starts the Fan right away..... After the snow flake has went to solid check to see if the fan is running and then look outside to see if the Fan Blade is turning on the AC..... The fan blade comes on the same time as the compressor does. Then with the fan running hold your hand above the air stream above the AC and if you can noticeablely feel warm to hot air comeing out the Top then the compressor is running also. If the outside unit is not running I would check to make sure the Main Breakers are turned ON.... After the AC has ran for a few minutes feel the copper lines that go into the house the smaller line should feel warm to hot and the bigger lines with insulation on it should feel cool to cold and sweating with beads of moisture on it..... That is a quick test to see if the unit is working properly.....If you have a Thermentor and can Check the Temperature of the Return Air and the Supply Air .. You should have about 20 Degree F Between the Supply and Return........ 75* Return - 55* Supply would Equal 20* TD Across the Coil......
That is about all you can do to check on your own....... If the compressor is not coming on or the lines are not the temperature difference then you will need to get professional help for your Air Conditioning System..... Goood Luck Hope this Helps.........
May 14, 2011 | Heating & Cooling
What is the snowflake icon that is lit in my 1999 mercury cougar
the red snowflake means its super cold outside so watch for icey roads, and when its yellow, its just bout freezing, but still be careful
Dec 06, 2009 | 1999 Mercury Cougar
I have a blinking snowflake icon on my air conditioner, my air will not work. My heater will work fine but the air will not come on
When the snowflake is blinking the thermostat in in a delay mode designed to protect your compressor. If it does not stop blinking in 15min the stat is bad otherwise something is wrong with the AC
Sep 26, 2009 | Honeywell Electronic Programmable...
Honeywell thermostat display has flashing snowflake /ac not working
the flashing snowflake is it telling you its in % min delay if it doesnt stop flashing within 5min it may be a bad tstat. if it goes solid and the unit is still not working its probably not the stat
Jun 13, 2009 | Honeywell Electronic Programmable...
Snowflake blinking and air conditioner won't turn on.
If it is blinking it is in a 5 minute time delay.
It should settle to a steady snowflake after 5 minutes and come on normally.
May 21, 2009 | Heating & Cooling
Re: 1998 Mitsubishi Diamante Air Conditioner problem
check the refrigerant it might have 2 be recharged
Aug 18, 2008 | 2002 Mitsubishi Galant
My Honeywell rth230b thermostat continues to give me a flashing snowflake signal and will not allow the AC to turn on.
Your snowflake should flash for about five minutes, that is the time delay built into the thermostat. It should stop after that and your system should begin to function.
May 28, 2008 | Honeywell Heating & Cooling
Heating & Cooling Logo
710 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
