Question about White Sewing 979
White Sewing Machine 979
I was sewing along smoothly, and then I used the "backstitch" button and then there seemed to be no connection between machine and foot pedal. I pressed the foot pedal and nothing! I shut off machine, pulled plugs, waited - hoping it would reset itself, but so far it has not.
Any solutions to this problem?????
Thank you!
  • 1,036 Answers
I'm sorry I don't know this model, but will try to help you.
Are the buttons still functioning - or is one deffinately seeming broken?
Try selecting other functions and see if there is any life at all.
If there is no life in it whatever, remove the fuse (test it) and replace.
If still nothing, There is an electrical fault either in the foot pedal, or motor.
These can be tested with a meter to determine the fault.
Repair of the motor or footpedal (dependent on tests) may be required - usually the motor.
Hope this helps - if so, rate as fixya!
If not, I'll try and Identify the fault.
Thank you for using Fixya!
Posted on Jun 14, 2008
CS6000-i E5 showed on screen, now my backstitch doesnt work. Is this an adjustment I can make?
The start/stop button was pressed while the foot controller
was connected.
Disconnect the foot controller,
and then press the start/
stop button. Otherwise,
operate the machine by
using the foot controller.
Hope this helps.
Feb 13, 2014 | Brother CS6000i Computerized Sewing...
Singer 4423 stuck on backstitch!
Is sewing machine set for buttonhole making? Sounds like it got "confused" in the process of a buttonhole revolution making a reverse stitch, and so you need to change adjustment settings top left, bottom right, remove extension table and turn feed dogs switch back left of machine to UP position.
Did this help?
Dec 13, 2011 | Singer 4423 Sewing Machine
I have temporarily misplaced the instruction manual to my White 979 sewing machine. I need to put this shirt in todays mail and I have forgotten the direction to make a buttonhole. I s there a place I...
Automatic BUTTONHOLE making with 979:
  1. Carefully mark the position of buttonhole on your garment.
  2. Slide the button carrier and insert the button.
  3. Attach the buttonhole foot.
  4. Place the garment under the foot so that the needle pierces the fabric at the beginning of buttonhole.
  5. Lower the buttonhole lever and the presser foot lever.
  6. Push the buttonhole lever away from you.
  7. Start machine to complete entire buttonhole.
  • While making buttonholes, maintain an even sewing speed for uniform buttonholes.
  • When buttonholes are completed, be sure to push up the buttonhole lever as gar as it can go.
Feb 11, 2011 | White Sewing 979
I have a singer white model 979...everytime I sew stretch fabrics and satin it seems that either my material sort of scruntches or it stretches after I sew the hem. what am I doing wrong and how do I do...
Do you have a walking foot attachment? Also, called an evenfeed foot. You can also try using tissure paper under your fabric as you sew for a quick fix.
Sep 19, 2010 | White Sewing 979
My bobbin isn't catching. cleaned it 2
try new needle
try rethreading
Jul 23, 2010 | White Sewing 979
Bobbin won't thread
I just bought my White sewing machine used and the model #967.I had problem winding a bobbin so my husband helped me. what I had to do was hold the arm with the bobbin on up agains the wheel. I know it seems to be a pain but this machine has all kind of attachments.
Apr 01, 2009 | White Sewing 979
Viking 190 sewing machine stuck on backstitch
Found the problem (s) with Viking stuck on backstitch!!!
Two problems:
A: machine is "gummed-up" form old grease.
Solution: degrease machine with a high quality degreaser.. I used a spray electrical degreaser from an automotive store. Turn the machine up-side-down to preform this!
Then relubricate machine. Use a high quality sweing machine lubricant! Also lubricate the inner parts with a qigh quality "Sewing machine" oil.
B: Found that the return spring from foreward to backward was tired.
Soultion: Replace with slightly stronger spring from local hardware store.
If you need pictures, I took very detailed pictures of the reverse mechanism and "return to forward" spring.
Write to
Jan 16, 2009 | Husqvarna Viking 1
White Sewing 979 Logo
134 people viewed this question
Top White Sewing Sewing Machines Experts
Tally Girl
Tally Girl
Are you a White Sewing Sewing Machine Expert? Answer questions, earn points and help others
