Question about Fuji FinePix A350 Digital Camera
When i take a picture, press te button, the camera lens goes back into camera and shuts off, why?
Normally an indication of flat batteries. Low batteries do the same. Even bad quality batteries will do this. You should get 2 AA Lithium which will last a long time but when ready to go will die instantly.
Posted on Dec 19, 2010
Canon Powershot A495 Wont power on using the ON/OFF button
The problem is short on playback button due to humidity (see differences between the buttons on foto no.1), wich can be removed mechanically using a pin and making two holes(inlet/outlet) at the side of the button where no wiring running(!) and with a hypo carefully shooting air beetween the foils. It is useful to lift up little bit the spring button from the bottom foil to remove the short. A hair dryer can be also helpful to dry out the space between the foils. Please check the fotos and link too.
The camera will not power on by battery insertion when short is over. To protect buttons against repeted defects I used an adhesive tape to close the openings on the top of the buttons.
Canon Powershot A495 Wont power on using the ON OFF button page 2 General...9475eddd-e98e-40e1-9ff5-48f2b88aa22a.jpgimg_3172a-qpgfxpscyuxnmpq5faoemdbh-2-2.jpgimg_3180a-qpgfxpscyuxnmpq5faoemdbh-2-3.jpg
Nov 08, 2011 | Canon PowerShot A495 Digital Camera
My digital camera FinePix A900, keeps turning off when I turn it on. Unable to pull any menus. Batteries are good. any suggestions, is it fixable or do I have to buy a new one?
Try pressing the playback button to turn the camera on. This should turn the camera on just so that you can view any pictures stored on the card or internal memory. You can also access the menu functions this way. Also try pressing the picture/shutter button and see if the lens extends. If the camera shuts off when you press the picture button and the lens does not move or only moves a fraction then the problem is probably to do with the lens
Dec 18, 2009 | Fuji FinePix A900 Digital Camera
Olympus Stylus 730 shuts off after few seconds. Battery is fully charged, tried a resetting: no change.
To save battery power, the camera automatically goes into sleep mode and the monitor turns off if there is no operation when the camera is turned on (when the lens cover opens and the monitor is on). No picture is taken even if the shutter button is fully pressed in this mode.
Operate the zoom lever or other buttons to restore the camera from sleep mode before taking a picture. If the camera is left for 15 minutes, it automatically turns off (the lens cover closes and the monitor turns off). Press POWER to turn the camera on.
Mar 26, 2009 | Olympus Stylus 730 Digital Camera
Camera won't turn on - makes strange sound
This is a very common issue with digital camera on either the lens gears have to be replaced or the lens barrel need replacing. I rebuild these lenses all the time for 75.00 plus shipping and the turn around is normally less then a week. if you still need help fell free to contact me at mike@digitalcamrepair.com
Feb 26, 2009 | Casio Exilim EX-S600 Digital Camera
It just shut off....
it normally indicates a problem with the batteries. Try inserting disposable alkaline battieres in the camera and turn it on.
If the lense is still out at the moment try pressing the play button the back of the camera to view the pictures taken, even with a very low battery this normally close the lense properly and enables you to view the pictures.
Nov 15, 2008 | Kodak EasyShare C613 Digital Camera
Changing lenses
hmm the correct way is to turn the lens to te left by pressing the release button, and keeping it pressed untill the lens is of (either turn the camera on the back, facing the NIKON brand on top , te bottom of the camera away form you and the internal flash and front lcd towards you
Jun 08, 2008 | Nikon D50 Digital Camera
Optio M20 Camera: Press on/off button to power up camera, the camera opens the lens cover, turns on a red led inside the lens, cycles the lens out and back in,then makes about 5 little popping noises. The...
i got it!!! on my cam i hold down the menu button at the same time power on, it will showup a " ver 1.00" and lens move a little maybe u have to do it 2 times but second time it should work
Mar 29, 2008 | Pentax Optio M20 Digital Camera
Digicamera model S820
My camera had a similar prob. Instead of pressing the shutter button half way just press it all the way down and see if that works.
Jan 04, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Fuji FinePix A350 Digital Camera Logo
29 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Are you a Fuji Camera Expert? Answer questions, earn points and help others
