Question about Cyberhome CH-LDV 712 Portable DVD Player
Black screen i have audio but no picture
  • Cyberhome Master
  • 2,794 Answers
I got an idea. Why don't you take into Best Buy and have the Geek Squad look at it. See if it's the player of find the button to change the display were looking for. They can show you where it is.
Posted on Jun 14, 2008
I have no video ihave audio,the screen stay black
Hi Doug,
Please try a flash light on the screen. If you can see a faint picture, the fault is with the backlights. In samsung LCD TVs it is the bad inverter board which is often found responsible for this fault.
Good Luck.
Jan 25, 2016 | Samsung Televison & Video
Black Screen
If audio is present, the picture should also be there. If not, check the video output section circuit for fault. Check all the solder terminals for any loose soldering to this board. Audio output board can be located at the neck of the picture tube, will directly plugged on to its back. Re-solder all the suspected solder terminals; by applying a little more solder.
google.com/+GopakumarGopalan
Nov 07, 2013 | Ktv Televison & Video
Samsung TV LN40B500P3f - No Picture ; just audio Hello, Our Samsung LN40B500P3f TV audio display is black; audio works fine. If I turn TV off and then back on the picture does display for a few secon
The set will need to be properly diagnosed to narrow down the problem. You could be looking at a bad inverter, bad CCFL lamp, fault in power supply or main board.
Sep 06, 2012 | Samsung Televison & Video
Big black square in middle of screen picture top to bottom about 36 " wide good audio and picture 6" on right and left side displaying.
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 26, 2012 | Hitachi 55HDS69 55 in. Plasma Television
Was watching tv all of sudden screen turned black, with audio...
i was watcing tv afeter a while i realized there is no picture but we have sound
Jul 14, 2009 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
No picture, good audio. Replaced motherboard...
I think I may finally have the answer for the "black screen of death" for the 42" Polaroid LCD televisions. I was having the same issue with the screen going black after a couple minutes of being on. I would shut it down then turn it back on and it would work again for 5-10 minutes. On the "power board" which is the board on top, there is a little red light that turns on when the screen would go black. above that there are 4 little switches, the lower on says BURN. I simply switched that over and the television has been working for 2 days for 8 hours + each day. Hope this help. Let me know
Feb 12, 2009 | Polaroid 4241-TLXB 42 in. LCD Television
Half of the screen goes black
the light engine is defective and needs to be changed..this set is not that old..contact mitsubishi customer relations to see about having it done under a customer accomodation, as they have had a lot of problems with the engines
Nov 28, 2007 | Mitsubishi WD-73732 73" Television
Usuable signal/blue screen
No picture, just black screen
Check R3414, an SMD chip on the CRT board. There could be invisible bad solder joints
Noisy picture
Replace relay RY481 on S2 board
Picture int disappears leaving snow on screen
Resolder the Xtal in the tuner
Nov 23, 2007 | RCA 32V430T 32" TV
Cyberhome CH-LDV 712 Portable DVD Player Logo
70 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
