Question about Technics SB-T200 Main / Stereo Speaker
Do I need minimum gauge wire for my speakers to work?
  • Technics Master
  • 5,151 Answers
I wouldn't have thought so. The better the quality of the wire the better the sound you will get.
Posted on Nov 06, 2010
Gauge wire ohm speaker
if the subs are different models or sizes don't install anything.
use the best subwoofer you have, if you use both you can have cancellation with uneven woofers or damage them. use a large ported box and tune it close to the music you listen to.
use a minimum of 4 gauge copper or cca wire. anything smaller and you risk burning the wire, the brand doesn't matter. use 14 gauge or larger for speaker wire and setup your impedance of your subwoofers in the pattern that will give you more power.
see here.
http://www.the12volt.com/caraudio/boxcalcs.asp
Nov 13, 2013 | MTX Thunder 4202 Car Audio Amplifier
Performance teqneck 3000 watts cut out when volume turn up
needs more power, or how your wired impedance is too low.
1.upgrade your power cable
2.buy a second battery not a capacitor
3. run power cable to the second battery from the + of the from battery the battery from the front
4. run at minimum of 4 gauge power wire
5. run 4 gauge wire from the alt to the main battery
6 run 4 gauge from the negative of the battery to the ground chassis
7. run 4 gauge + to the rear battery
8 run 4 gauge ground near your amp
9. turn down the gain and bass boost, set it a moderate level where you wont hear distortion
10. set the bass level from your stereo deck at a moderate level also.
find your impedance.
look at your woofers and find have a number like 1,2,4 ohm.
find out what your amplifier minimum needs to operate in OHM's.
look here.
Nov 13, 2013 | Alpine PDX-1.600 Car Audio Amplifier
My amp just stopped working one day almost new dont known why
DID YOU CHECK YOUR FUSES? Is there anything lighting up on it to see if it is in fact turning on? If it's lighting up and there is no protection lights lit up then check your speakers to make sure you didn't burn them up. If there is a protect LED lit then unhook your speakers and see if it stays lit or not. If it stays lit then check to make sure you're getting enough voltage at the amp connection, minimum of 11.0 volts is required just to get it to turn on. If it has under voltage and over voltage protection LEDs see if they're lit. If you do all of these things and are getting enogh voltage, your speakers are not burnt, your protection LEDs are lit no matter what then you need warranty repair that amp. If your speaker wires are shorted it will make your amp shut down also, but since you were using it for a day or so my bet is that you burnt up one of your speaker voice coils and it's internally shorted and that will cause your amp to shut down in protect mode. Otherwise you probably internally fried your amp by too low of voltage or not enough current (amperage) due to not large enough conductor (too small gauge wire) should be minimum of 8 Ga. for each amp, 2 amps will require 4 Ga, 3 or more will need 2 Ga, or 0 Ga. wiring to keep the voltage and current flow high enough to keep from damaging the amps. Good Luck!
Aug 20, 2013 | Phoenix Gold RSd1200.1 Car Amp
How to get amp out of safe mode
first check all connections, fuses and speaker wiring. Check to make sure that the amp is getting enough power to keep it running, meaning a piece of 4 to 8 gauge minimum wre from your battery to the amp. Make sure no wires are touching ground on the speaker outputs all the way to where they connect to the speakers. You can check this with a Ohm Meter to see if their is a direct short to ground. Or unhook all speakers and 1 by 1 touch them onto the amp to see if it cuts out. If the amp is going iinto protect mode without any speakers hooked up to iit (I have a bad keyboard sorry for the extra or missiing I's) and all other things I mentioned are OK then your amps bad and needs to be serviced. Hopefully It's just be a shorted speaker or wire.
Aug 07, 2013 | Jensen XA4100 Car Audio Amplifier
What gauge speaker wire use for yamaha R-v905 Receiver
The usual gauges range from 18 to 16 with one limiting factor being the ability of the receiver and speaker terminals to handle larger gauge wire
Jan 28, 2013 | Yamaha R-V905 Receiver
I have a wall oven that I am installing. Three wires - 12 gauge Black, 12 gauge Red, and a smaller gauge White (no number) looks like 14 gauge. What gauge do I need to run to the panel and what color to...
all wall ovens and freestanding stoves require a 50 amp breaker
you need to check the electrical codes in your area but i would use a minimum of 12 gauge wire if not even 10 gauge
Jul 21, 2011 | Kitchen Ranges
How to wire the tuner and amp what wires do i need to get it to work
In most cases, you need a pair of Red/White RCA cables. Connect one set of ends (1 red + 1 white) to the external tuner's output and the other (white + red) to the input on the Amp.
Then you need double stranded wire to connect the speakers to the amp. one x double stranded wire for each speaker. You can use electrical cord from the hardware store (e.g. 18 gauge wire) or you can buy some speaker wire (16 to 20 gauge - use lower number wire (thicker) for higher power amp). 16 to 18 gauge wire for a 100 watt per channel amp if your speakers are less than 15 feet from the amp (wires are less than 15 feet long). If longer than 15 feet, use the 16 gauge wire. You can use 18 gauge for most anything else.
Jun 20, 2011 | Kenwood Audio Players & Recorders
Don't know if my amps wired right it has 2 power inputs and 2 ground inputs do I bridge them or run seperate wires?
If I am not mistaken one power input goes directly to the pos + side of your battery (Use minimum 10 gauge stranded copper wire for this) and the other goes to the stereos (usually blue wire and can be regular 16/18 gauge wire) that is either used for (an amp or power antenna) In your case, an amp. So when you turn on/off your stereo your amp will also turn on/off . For the 2 ground wires just make sure you run at least one of them (preferebly with 10 gauge stranded copper wire directly to the neg - side of the battery and the other one can be ran to chassis ground and may be 16/18 gauge wire. Good Luck.
Jun 27, 2010 | Car Audio & Video
Protect mode on. All wiring is operative without incident. Power and all is working, but will not come out of protect mode and all fuses are brand new.
it could be one (or more) of several issues. ensure none of the speaker wires are connected to the ground of the car, or to each other. ensure the speakers are not blown. check to see if the amp comes on ok without the speaker wires hooked up. your battery may be low - check voltage at the power terminals of the amplifier to ensure you have operational voltage. you may not have a sufficient ground connection - ensure the ground wire is less than 18 inches, is of proper gauge (minimum 10 gauge, the lower the gauge the better), and is connected to a sturdy connection going right to the ground plane of the car - make sure the paint is scraped off from under the point at which the ground wire terminal is screwed to the ground.
Jan 17, 2010 | Boss Exxtreme BLX5000 2-Channel Amp -...
Onkyo tx-sv727 Protect displayed
first thing if it says protect, check the fuses inside the system they may of blown .When choosing wire gauge, consider the quality of your components and speakers, the overall sound quality you're trying to achieve, and the budget you're working with. Also, keep in mind the distance between your receiver or amp and your speakers long wire runs can cause significant power losses, and thus require thicker cable. You can use this as a guideline
Distance from speaker to amplifier Gauge
Less than 80 feet 16
80 to 200 feet 14
More than 200 feet 12
Nov 02, 2008 | Onkyo TX-SV727 Receiver
Technics SB-T200 Main / Stereo Speaker Logo
99 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
