Question about HP Vs17 17" LCD Flat Panel Monitor
It want,turn on so we put a new fuse in it ,there is power going to the cord. but it still want come on.
    Guru:
  • HP Master
  • 453 Answers
check the bridge if shorted replace by a new one, check the chopper transistor:
Posted on Nov 05, 2010
    Problem Solver:
  • 12 Answers
Try a new fuse, if that does not work. You will have to buy another Cable for it. Commet or Curreys can sell you one for about 10 or 15 pounds
Put new turn signals front of 84 honda bvf 700.one shorts out now now power dead.shange out all fuses. what wrong
check power from battery to solenoid and the main power wire going to the fuse block... a good test light will help... oh, i suggest you unhook those new lights until you get the other issue resolved...
Nov 02, 2014 | 1984 Honda VF 750 S
I have a 1989 cobra 29 Ltd classic cb. It got water spilt on it sitting on my tabble so I took the covers off and took a heat gun to it and dried it. I also disconnected the internal speaker and left it...
# 1 you should never dry out a radio with a heat gun.#2 the reverse polarity diode is what is blowing out. take that wire you fixed and toss it.go to Rad Shak or a truck stop and buy a power cord with a lighter plug attached. .Then have someone you can trust replace d23. hook up your coax then your cord turn it on and you are good to go.
Aug 01, 2013 | Radio Communications
Spectroniq tv doesn't turn on, lights off.
The fuse is inside--power cord should go almost direct to it--beyond that if fuse good is power supply for the set.
Nov 06, 2012 | Televison & Video
I can't get my treadmill to turn on
1) test the wall outlet with another device such LAMP desk
2) test the c.breaker from your home if device is NOT turn ON.
3) If turn ON, go to reset the c.breaker or fuse replace, Try again.
4) Replace the power cord if is defective.
5) see the diagram attached for better troubleshooting.
Aug 27, 2012 | FreeMotion 750 Interactive Treadmill 12510...
Bought new power supply still power light won't light up and laptop will not turn on new battery as well it worked until new battery power was drained when i try to power it on the battery light...
Look to see if the charge light is on when you connect the power.
If not, try moving the power jack around slowly in a circle.
If you get power with the cord/connector at certain angles, then the motherboard will need to be removed in most cases and the power connector on the motherboard will need to be resoldered to the board, and then the unit will have to be reassembled.
If moving the connector doesn't ever put the charge light on, then there is either a picofuse blown or more likely some SMT MOSFETS are blown.
If you have the skills, identify and replace the MOSFETS and you should be ok.
If a picofuse is blown, replace it with the same type and rating fuse.
DO NOT JUMPER the fuse...sometimes they just go, but most often they go for a reason.
If the new fuse blows, start looking to the MOSFETs and electrolytic capacitors in the DC/DC converter section.
Jul 19, 2011 | Computers & Internet
Toshiba 32A33 After a power spike
The main power fuse inside the TV may have blown. The rear cover must be removed to check it. Unplugging the power cord from the wall outlet is the first safety item. Finding all the right screws to remove the cover (without taking out some you shouldn't) is sometimes tricky. When you remove the cover the power cord will still be attached inside, so remove the cover carefully. There is a danger of touching residual high voltage near the picture tube. Carefully look for a fuse near where the power cord attaches to the circuit boards. Often the fuse will be obviously burned open (the small conductor inside the clear glass is melted or the glass is blackened). Replace only with a fuse of the same type and amp rating. Putting a higher amp rating fuse or slower acting fuse can have costly and possibly dangerous consequences. Be sure to plug the power cord in when you do your test with the new fuse. If you haven't done anything close to this before, you may want to refer this job to an expert.
Aug 11, 2009 | Toshiba 32A33 32" TV
No power
You may try to reset the AC adapter by following steps below.
1. Unplug the Wii AC adapter at both ends (from the back of the Wii system and from the wall outlet or power strip).
2. The AC adapter must remain unplugged at both ends for a full 2 minutes.
3. While you're waiting, unplug/remove all accessories from the system (including game discs, SD Cards, Nintendo GameCube controllers, memory cards, hookup cables, and Sensor Bar). Remove all of these from the outlet and the Wii.
4. Also check to see that controller cords, AC adapter, and Stereo AV cables/Component Video cables are not frayed and do not have exposed wires. If you find any frayed cords or exposed wires, you should replace those parts.
5. After you've waited 2 minutes, plug the AC adapter into the Wii system and directly into a wall outlet, not a surge protector or power strip. Check to see if the power light comes on.
If the steps above didn't work, I suggest you go at http://www.nintendo.com/consumer/repair/wii_repair_home.jsp?problem=PWRNOPOWER and send the unit and power adapter for repair.
Jul 27, 2009 | Nintendo Wii Console
Help
If your power cord starts to melt before the fuse blows it means you have *way* too thin power cables. Then the fuse probably blew because of a short to ground due to the melted insulation. This is one of the things that can start car fires.
I use cables of similar thickness as jumper cables to my slightly bigger amp, maybe a little overkill but better safe than sorry.
May 28, 2009 | Northgate (STAX2517C2) PC Desktop
Panasonic ct-32sl13g blowing fuse by power supply
You will need to remove the back of the TV. Don't worry, it's not that bad.
There are 4 screws across the top, one on each side, one right next to where the power cord goes into the back of the case, and the two more by all of the video connections **These are the most important to remove because they attach the main board to the back of the case.
Once you have remove the screws then the entire back of the set will slide off. If you look where the power cord attaches to the board you will see a small fuse. This is a 6.3 Amp 125 volt fuse. You can replace it with a 6.3 Amp 250 volt fuse from your local Radio Shack. A four pack costs between $3 and $5.
Make sure that you check that it works before putting it all back together. Check for any loose connection cables while you're back there. I found a few when I did this.
Apr 15, 2009 | Panasonic CT-32SL13 32" TV
Using Convection Oven and lost power Sharp R-7A85
Replace fuse with slo blow from Ace Hardware. Plugged unit in, clock worked. Turned unit on and immediately blew new fuse. Will fix it with a new unit.
Mar 21, 2009 | Sharp R-7A85 Microwave Oven
HP Vs17 17" LCD Flat Panel Monitor Logo
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
