Garmin nuvi 200W GPS Receiver Logo
Posted on Nov 05, 2010
I have the tmobile garmin phone and my computer does not recognize it when I hook it to usb
Anonymous
Level 1:
New Friend:
  • Contributor 12 Answers
  • Posted on Nov 05, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
12
Questions
0
Helped
1303
Points
33
Upgrade the softwear, please take it where you bought it from and ask them for advise, because the softwear lacks behinde the new softwear! so your model urjentley requiers upgradiotan
1helpful
Computer does not recognize my garmin nuvi
Unplug... Install drivers and software 1st!... Then plug in usb
Computer doesn't recognize garmin
Your computer uses USB Mass Storage Mode to detect your Garmin unit. If your computer does not detect your Garmin unit, you can try these troubleshooting steps:
Unplug the USB cable from the computer.
Turn the unit off and then back on again.
Plug the USB cable into your computer.
The unit either automatically goes into USB Mass Storage Mode or displays USB Mass Storage Mode as an option on the screen.
Note: If your computer still does not detect the unit, make sure that you plug the USB cable directly into the computer USB port and not the USB hub. If the cable is already plugged directly into the computer, try plugging it into a different port.
If you still experience problems, please contact Product Support.
Garmin car gps
109helpful
41answers
Need unlock code for tmobile garmin-asus garminfone imei:357355030405960.
help unlock code Garmin asus
Imei 357355039129504
thank's all you
Sep 21, 2010 • Cell Phones
Screen broke how to hook up to computer usb without touching the usb button
take it to a computer that has windows vista on it. hook it up. in about 15-30 seconds it will recognize it as a removable disk under the computer icon in the start menu. you dont have to install anything or touch the screen. vista will recognize it automatically. it works, i have a pre as well.
7helpful
3answers
I can't get my computer to recognize my Garmin 255w on USB cable.
Change the mini usb cable. Some mini usb cable are for charging and not data. It happen to me and used the externo hard drive usb mini cable and zapppppp my computer nows read the gps and gave it a drive (h:\). hope it works for you.
The computer won't recognize the gps
When I hooked the nuvi 350 to the PC, the PC like a normal USB device. It could not recognize the drive on the nuvi. The solution is to change the drive letter as outlined in the manual. Google nuvi 350 manual (I got it at http://www8.garmin.com/manuals/Nuvi350_OwnersManual.pdf) , download the manual, and go to the appendix. Look under 'USB interface troubleshooting'. This worked like a charm
Apr 18, 2009 • GPS
My windows xp does not recognize my garmin200
Go to the Garmin site and download you USB driver. Install the driver with out the GPS connected. Aftter the USB driver is installed reboot you computer and then connect the GPS. Let us know if that works.
1helpful
THE USB PORT THAT MY GARMIN NUVI 270 IS PLUGGED IN TO IS NOT RECOGNIZED BY MY COMPUTER
If they don't give you a new one under warranty, are third party Garmin repair services that will fix it for cheap. Also, I found an DYI GPS repair guide,so you can do it yourself too, not that difficult to solder in a new USB port.
6helpful
7answers
Windows XP will not recognize Garmin 200W
I had the same issue. I would plug it in and it would recognize the device then it would disappear.
What I did to solve the problem was to first turn on my Gamin 200w. After it was finished loading maps then I plugged in in to the usb port. My machine recognized the device without any problems. I am running Windows Vista Home Premium. Hope that helps.
2answers
Computer fails to recognize smt5600
you can use any USB cable, there is nothing specific about any particular brand... now the computer has to recognize the phone. You need the software/driver.
Top Garmin GPS Experts
vince
Jesse Walters
Jesse Walters
Are you a Garmin GPS Expert? Answer questions, earn points and help others
