Question about Seiko Lorus LO111 Watch
How do I set wintertime - Seiko Lorus LO111 Watch
    Sergeant:
  • 209 Answers
The winder screw should unscrew and then pull out one click to adjust the date and two clicks to adjust the time
Posted on Nov 05, 2010
Instructions for Bowflex WR30M?
In time mode, hold set (bottom right button) to change date and time. The selected (flashing) item can be changed in one direction only using the up (top right) button. Press set again to cycle through each item until desired settings are chosen.
In stop watch mode, the up button starts and stops the stopwatch, the set button will take a split time while the time is running. To reset the stopwatch, press set once while the time is stopped.
In alarm mode, the up button turns the alarm on and off. There are three alarms available. To cycle though alarm times, press set. To set an alarm, press and hold set until the time flashes, then set the alarm time using the up button, cycle through hour and minutes using the set button. When finished, press set again.
Timer mode. To set the timer time, press and hold set until the time flashes. The timer goes up to 23h:59m:00s. You cannot set seconds. Once set, the timer can be started and stopped using the up button. There is no reset for the timer, to start a new timer the time must be manual changed again.
To check heart rate, press and hold mode until PUL is shown, place two fingers, one each on the top and bottom metal contacts for 6-10 seconds to get reading (This works best when not in motion).
Apr 13, 2012 | Watches
I have an armitron all sports mens watch I need to know how to set date and day of week
press in the mode button lower left or the top may say set hold to set, when blinking hr set number by using the right button set up or down , set press mode again goes to mins, then sec. then day and time. press until all set and all showing corrct numbers. then it is set
Jun 17, 2011 | Watches
I have a model 31420E skyscan & have lost the instruction manual. Also I live in Sydney Australia and don't know anywhere here to get help.
I couldn't find the manufacturers' web site but I found the following , which may help;-
The unit automatically receives the time signal everyday at midnight and makes any required adjustment to the time displayed.
The WAVE OK indicator and the Tower Icon on the display will show if the time signal is successfully received or after manually pressing the SET/WAVE button
You can trigger a Signal Receive operation at any time by pressing the SET/WAVE button, which will activate the Signal Search function of the unit.
To Manually Set the Clock
To Set the Year and Date
1. Press SET/WAVE button after setting TIME ZONE and DST
2. Press + or - button sequentially to set the year (holding down the button will change the year at a high speed)
3. Press SET/WAVE button to confirm the year set and start the date process
4. Press + or - button sequentially to set the current date (holding down the button will change the date at a high speed)
NOTE: The weekday changes automatically depending on the year and date
To Set the Time
1. Press the SET/WAVE button after setting the calendar
2. Press + or - button sequentially to set the minutes (holding down the button will change the year at a high speed)
NOTE: Once you the press + or - button, the seconds will reset to 00
To set the 12/24 HR mode and the Temperature Mode
1. Press SET/WAVE button after setting the time
2. Press the + button to toggle between between 12HR and 24HR (military) modes
3. Press the - button to toggle between C and F temperature display mode
4. Press SET/WAVE button to confirm and quit the set mode
Dec 20, 2010 | Watches
How do you set a timex ironman wathc and how do you use the stop watch and alarms
Hi hdirkse,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Sep 25, 2010 | Timex Ironman 53151 Wrist Watch
Settiongs for Weather Data World Clock
Citizen Weather Data Clock Settings.
To set time press and hold for 5sec "set" button
Use advance to add days, years, hours seconds.
Press SET to hold.
Oct 17, 2009 | Citizen Watches
How do I set the High hr and the low hr by the chart?
To change any of the settings, press 'set' until 'settings' is displayed, press 'ok', now you can either set the heart rate manually in 'limit set' (press 'ok' to change the settings and press 'set' to change)
or input your personal data to let it choose heart rate settings itself in 'user set' where you input weight, height, age and *** (sadly yes please is not one of the options ;¬) )
if you go to www.polar.fi the user manual is on there if you need more clarification.
Hope that helps,
Andy
Sep 18, 2009 | Polar F4 Heart Rate Monitor Watch
Rolex oyster perpetual datejust time/date setting instructions
Depending on how old the watch is, It may be quick set or older models are not quick set. In older models you need to unscrew the crown, pull out the crown and rotate the crown to set the time, and in order to set the date rotate the hour hand past 12 twice in order for the date to change. Set the date first and then set the hour and min. For quick set models unscrew the crown and pull it out to the fist click this position you can "quickly" set the date by rotating the crown. Set the date and then pull out the crown to the second position out. Rotate the crown to set the hour and min. Then push the crown back in and screw it down.
Dec 12, 2008 | Rolex Datejust SS
Setting the date and time on watch
time:
hold left button -- hour will appear and begin flashing.
press right button to set.
press left button to advance to minutes, press right to set.
date:
press left -- date will appear. now hold left until day flashes.
press right to set.
press left to advance to month, right to set. then same again for year.
Nov 11, 2008 | Nike Imara Soar WR0103 201 wristwatch
Old model timex compact disc digital audio
Hi catlady05,
Setting an Alarm
Hope it helps.
Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
Seiko Lorus LO111 Watch Logo
70 people viewed this question
Top Seiko Watches Experts
Jerry Greenberg
Jerry Greenberg
just-ice
Are you a Seiko Watch Expert? Answer questions, earn points and help others
