Question about Zanussi ZWD1470W Front Load Washer / Dryer
My zanussi washer dryer has some problem When i set a program and lets say the program is 125 min it finishes after 40 min and it is not spining.Also when I try different programs I have the same problem
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 174 Answers
Check the drain filter is not blocked if it does not empty all the water it saves time on the next fill. also the spin will not happen if it has not emptied completley. a faulty pump would give the same effect.
Posted on Nov 05, 2010
Technician sent by Mastercare changed 4 temp sensors and a water valve on our Zanussi WJD 1667W washer dryer to try to get rid of problem of tumble dryer shrinking clothes. After he left found that tumble...
most likely it is a wire that has pulled loose while it was going into its spin fucntion or its agitate seeing how it did work at first and then failed after an amount of time technicians these days are always in a rush to get to the next job. He should stay and watch the machine complete all the cycles after he is done repairing.if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations Thanks Rick
p.s make sure there is no charge by his company for him returning to complete the job you have already paid for
Mar 17, 2011 | Zanussi WJD1667W Front Load Washer / Dryer
Hello.. I have a Zanussi Electrolux essential 1200 6kg machine. My problem is that during the wash (usually about 40 mins into it) the machine seems to think the cycle has finished and cuts out before...
Something could be stuck in the pump , drain the machine down drain hose next to drain plug when all water is out put a towel under drain plug unscrew then look in the drain plug and your see a little propeller, make sure it turns and nothing stuck there to stop it turning and leave clean then try again good luck
Dec 13, 2017 | Zanussi FC1200W Front Load Washer
Washing cycle stops before finishing
Hello, i have exactly the same problem. Did you find the solution?
Thanks
May 24, 2010 | Zanussi ZWD12270 Front Load Washer / Dryer
I have a zanussi washing machine mod fx1465w. I
If the drum is not turning this could be due to worn motor brushes,assumimg that its pumping out the filter will be clear and spin should follow @ program end.The motor brushes are secured by two screws each.....
Nov 24, 2009 | Washing Machines
I have a belling washer /dryer, that will not now open at the end of its cycle ? any ideas please ?
offten it takes a little time to release the door locks like 2 mins,, its all down to the programer how long it takes, but if you give it a little smack /thump down by the door lock on the mashine it will let the locks go
naughty but nice?
Oct 25, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi ZWD1261 works fine except doesn,t turn off at end.
There is an issue with the timer . Needs to be replaced if it worries you.
Sep 20, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
I have a zanussi turbo dry built-in washer/dryer built-in 1200, Mod zjd . 125, and I do not know how to use it. HELP! Thanks, Cindy
Hey, Just load the washer but do not over load. These combo washer dryers are strictly for smaller loads. You should have a drawer to the left that you place the soap and softer and bleach. Set to the washer to washer. The door should lock automatically. Then set your dryer setting to the the Heat temperature that you want. 100 degrees is ok to start with. then it will adjust itself as it goes through the cycles you have set. Enjoy the machine should work. If it does not look to make sure that the door is closed all the way. Sometimes you have to open the door and reset it and shut the door or while it is closed gently push on it till you hear a small clicking noise. ENJOY YOUR WASHER DRYER COMBO
Aug 28, 2009 | Washing Machines
I have a Zanussi WDA1055W washer/dryer. I never
the water should only be filling up to approc 2in above the drum bottom...........look inside when its filling..........if its filling to nearly the bottom of the door you either have a faulty pressure switch or grit/dirt in the internal filter.......as a result the machine will not spin if there is too much weight in the drum
Feb 23, 2009 | Zanussi F1045W Front Load Washer
Zanussi ZJD 125 on a timer switch
No prob, the washer never draws the full 3kw at any one time.
Plz rate this solution.
thanks.
Dec 18, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Put it on the drying program and it finishes after 5 mins
i suspect you have a blockage in the dryer duct - take top and rear cabinet off and the dfuct is exposed - it often gets blocked with lint
Nov 12, 2008 | Zanussi WJS1265W Front Load Washer/Dryer
Zanussi ZWD1470W Front Load Washer / Dryer Logo
93 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
