Question about AMD Computers & Internet
Motherboard loops when starting. Will not boot up . Gets to Windows screen and then starts all over again
  • AMD Master
  • 27,725 Answers
Test your PSU or replace it
One bad lead can cause a computer to continue on a cycle or to shutdown
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your motherboard to your hard drive make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
hope this helps
Posted on Nov 05, 2010
Need help - black screen on Samsung 700A3D
Looks like the boot manager file could be damaged or a driver is missing. Use your windows disk to boot from and choose the repair option.
Aug 31, 2016 | Samsung Computers & Internet
When i switch on my acer aspire one notebook, its automatic reboot several time when it gets to the acer starting screen, i cant log on to windows. it just keep reboot again and again. what is the problem?
what were you doing last time you used pc?
did you change or permit an app to change any setting or install or upgrade a app?
your pc is in a boot loop caused by an incompatible registry program installation
suspect an app or upgrade not compatible to your hardware or os version or you did not install a needed os fix
can do a step boot to see where the boot is failing then bypass it on next step boot
then edit start up or registry to remove faulty step (be cautious!)
need to boot in safe mode & restore a previous state
or restore your installation from a bu or original - you will lose some data not saved
Oct 23, 2010 | Acer Aspire One PC Notebook
My laptop comes to a safe boot screen how do i pass that
if its a 1 time thing then the laptop wasnt shut down correctly the last time you used it. you can pick safe mode , press enter , let it get to the desktop and goto start button and pick shutdown. when you start it up again it should be fine.
if it goes to this every time and gets stuck in a loop you might need to reload windows
Sep 09, 2010 | Lenovo ThinkPad T61 Notebook
Did I fry my ASUS A7V8X-MX motherboard? I bought an old computer(with this moboard) that was working. I opened it and put in my old HD to slave it. Rebooted to get into the BIOS (just to check things...
I do not think that this problem is to do with your Motherboard. If you had fried your Motherboard, you would not see anything when you started the computer, you especially wouldn't be able to get in to the BIOS if your Motherboard was damaged because the BIOS is accessed straight off the Motherboard itself. You will notice that if you take out all the Hard Disks in your computer, you will still be able to access the BIOS.
This problem is probably due to a corrupt Hard Disk. Maybe you set the old Hard Disk to the Master or whilst moving your computer you damaged the other Hard Disk. This problem is known as the Windows Reset Loop, your computer will not get past a certain point in the start-up process and will then restart itself and do the same thing over and over again.
This could also be caused by a problem in your BIOS, when you did the CMOS reset, it would have probably knocked out all of the stored data. When your computer is starting up, you must go in to the BIOS and check which drive the bios is set to boot off. Even though your Slave Hard Disk is set as a Slave, you can still set the computer to boot off this drive, and if this drive is corrupted it will not boot, it will go in to the Windows Reset Loop.
If the problem still persists, i recommend that you remove the old Hard Disk which you have put in and try and boot off the Master as a single drive. If this still doesn't work, set your other Hard Disk as the Master and remove the other drive and try boot off that one.
If you would like further assistance with this problem, pleas do not hesitate to contact me on Skype (Skype Username: fixya-support)
Thank you for using FixYa! Have a great New Year and please remember to rate this solution.
Warm regards,
BearWeb
Jan 01, 2010 | ASUS A7V8X-MX (90-M7A780-G0EAY)...
Pc stuck in start up loop
Ram and Power supply are the main cause of your problem with this motherboard by replacing these one at the time could fix it
Jul 02, 2009 | Intel D865GBF Motherboard
Gateway 505gr became unresponsive, on reboot windows cannot load
Hello guys,
This problem would arise only when the motherboard doesn't work properly. Check with your nearest gateway service center to get your CPU work again. That would be the only thing to be done.
~REGARDS,
Jegan
Nov 20, 2008 | Gateway 505GR PC Desktop
My computer won't boot! It keeps restarting before Windows screen.
Make sure the cmos jumper is plugged in. Turn off your pc, unplug the power source. Remove the cmos battery for 30 seconds then put it back. Reboot your pc. Give us feedback! Hope that helps :-)
Jul 25, 2008 | Abit IC7-G Motherboard
Problems during boot
this is windows unable to get to passed the lower bios memory before windows takes over with the normal memory. Check your cmos battery is'nt low, or reset the bios JBAT1 terminal from pins 1-2 to 2-3 then back again as the loop could be corrupt bios or a peice of hardware that cannot be started.
Jan 17, 2007 | Gigabyte GA-8N-SLI Motherboard
Computers & Internet Logo
35 people viewed this question
Top AMD Computers & Internet Experts
Alun Cox
Robert Monigold
Robert Monigold
pankaj rautela
pankaj rautela
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
