Question about Brother CS-8060 Computerized Sewing Machine
I have a Brother Innovis CS8060, the bobbin no longer winds completely, only halfway, can you advise?
    Problem Solver:
  • 17 Answers
Being a computerized machine i would take it to a service center, if this isn't an option at this time next to the post you put your bobbin on is the depth adjustment, there is a screw in the top of it very gently loosen scew and slowly rotate the depth gauge until you think it is where you want it . you may have to sdjust it a couple of times before you get it where you want it so go slowly and carefully
Posted on Nov 06, 2010
Issues with unthreading
when does the machine unthread itself? when you are sewing? or embroidering?
1. check top tension.
2. leave longer threads from bobbin and needle before you begin sewing.
Jul 21, 2014 | Brother InnovIs QC1000 Electronic Sewing...
How to remove front casing from innovis 4000 brother sewing machine
I would contact Brother, they have an outstanding service department. But if the thread is only around the hand wheel, try pulling it outward to see if you can access the thread that way. Many hand wheels pop out, to disengage the needle mechanism so you can wind a bobbin.
Jul 17, 2014 | Brother Sewing Machines
Bobbin thread wont form a stitch
Hai, Please check the bobbin tension and winding. And cleaning the machine.
Mar 20, 2014 | Brother InnovIs 4000D Computerized Sewing...
Bobbin doesn't wind on my cs-8080 innovis
On my one the rubber ring had degraded into a sticky mess and come off the pulley-shaped wheel on the bottom end of the winder shaft. It had stuck itself to the casing by the shaft bearing. Using Q Tips and nail varnish remover I managed to clean it all off.
To access the screw that holds the bobbin winder mechanism in the case; you first need to remove the screws that hold the circuit board in place and ease it out of the way.
Aug 08, 2013 | Brother CS-80
Brother innovis 10
After e6 came up I die tangled thread, all is now good but the start/stop button is no longer lit up at all it usually turns to Amber when bobbin wining red for stop and green for go but it isn't lit at all, light bulb is still ok, what do I need to do please.
Oct 05, 2011 | Brother Sewing Machines
I have the Brother SE270D and when I was winding the bobbin the thread somehow slipped under the bobbin and was wound around the peg under the bobbin winding area. I thought I could remove the screws and...
You can either take the machine in for repairs or, use another sewing machine (if you have one that uses the same type of bobbin) for bobbin winding or purchase a Sidewinder Bobbin Winder - search the Internet for the best price.
Mar 02, 2010 | Brother SE-270D Computerized Sewing...
What does E-1 mean? My CS8060 Wont sew. It has been f ine but now is very stubborn. Ive tried to sew on 00 and 04, now it won't cooperate.
E-1 is an error. You've probably pressed the foot peddle without the pressure foot being down. That will cause me to get the E-1 error. If this isn't the case, turn the machine off and then on again--that usually clears any errors.
When you say the machine is very stubborn and won't cooperate, what do you mean? I've found my CS8060 is extremely sensitive to lint buildup--that will make my machine get screwy really fast!
Take off the guideplate, the bobbin case, unscrew the throat plate, and take it off. Now use your little brush and brush out all the lint down under there. Brush off the bobbin case, guideplate, throat plate, and as deep inside the machine as you can reach. Don't use canned air--that will push the lint deeper inside the machine. You may have to use long tweezers to get some of the lint out.
Generally speaking, whenever a machine becomes uncooperative, the problem is:
  1. the machine needs cleaning/oiling (but our Brothers don't ever need oil!)
  2. the threading is somehow off--rethread the machine completely, even if you've used the machine a gazillion times (top thread and bobbin)
  3. the needle needs to be replaced
  4. the needle and thread aren't compatible (not nearly as common as the other three possibilities)
Hope this helps!
Dec 21, 2009 | Brother CS-8060 Computerized Sewing...
Unable to wind bobbin on Brother Css-8150 stopped suddenly
Checking to see if in fact that the bobbin shaft is turning. Run it without any bobbin on the bobbin shaft. Make sure that it is push over in the correct position and run it. I checked on mine and it does make the whirring sound and the the shaft does spin. Also check underneath the shaft to see if there is any thread wrapped around it. ( I had problems with that in the past). I hope this helps,
Sep 26, 2008 | Brother CS-8150 Computerized Sewing...
Brother CS-8060 Computerized Sewing Machine Logo
119 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
