Question about Teac Audio Players & Recorders
Teac CD X-9 player (single disk, two speaker system) purchased at COSTCO about 2 years ago. Problem: CD will load and spin but not play.
Try to sleep more and have a good time.
Posted on Jun 14, 2008
Is the CD player replaceable if we can get the correct CD replacement? I've tried to get the info from TEAC and they don't answer my email.
See if you can get the exact unit on the cheap on ebay. Teac obviously does not give a rat's a-- about your dilemma .
Your laser assembly is fubar and not repairable - not cost effective.
Time to move on after 9 years of use.
Aug 02, 2015 | Teac Audio Players & Recorders
I have a teac x-9, and during cd play, the cd doors randomly open and close causing me to restart cd play all over again. it does this on its own, and i don't push any buttons for it to occur. is this...
clean your eject button or check it 2 see if it is broke. if u have a remote try 2 play a cd with the cd player with the batterys out of the remote. last 1. the cd door could be off trak witch wood make the cd off balance when the eye goes 2 read the data on the disk it misses its data an will cause your cd player 2 open.
Mar 15, 2011 | Teac Audio Players & Recorders
Teac CR H100 CD player just clicks when I press play and if it plays, it stops very soon. Is this teminal
it sounds like it is the motor that spins the disk most likely not worth replacing unless the unit has high sentimental value to you
Sep 23, 2010 | Teac Audio Players & Recorders
Cd x-9 teac will load cd spin but not play lcd reading says 'no cd'
If this problem occurs only at this cd/dvd it's a disk problem. If it occurs on various disks try using a cd/dvd cleaner set, a wet one is better. Follow the instructions on the set. The main idea is to put one drip of the included liquid at the set (usually isopropyl alcohol) at a specific place (like small brush) on the disk surface and play this disk. This way the "brush" will clean up the laser lens and after that the cd/dvd player will be able to read the disks. BE CAREFULL not to put too much liquid on the "brush". In case you can, use a Q-tip with isopropyl alcohol to clean up the cd lens manually. In case this doesn’t solve your problem, the cd player needs laser lens replacement by a technician.
In case of a problem or clarification, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
May 14, 2010 | Audio Players & Recorders
We have a TEAC stand alone CD copier which has stopped working. It won't copy audio files to the slave disk and we've tried using different blank CDs and different master discs. Sometimes ti looks as if it...
It sounds (pun intended) like the laser part of CD-writer "inside" the unit has failed, thus resulting in "blank" disks.
Disassemble the unit, and replace the CD-writer with any IDE (not SATA) unit.
May 13, 2010 | Teac CD Copy Station CS-Single 12...
Emerson ms3105 won't play cd's wont even spin
kungfuz...I have had two of these emerson cd players. One is in my home and is still working after 3 1/2 years. The other was purchased for our church just over a year ago and it has stopped working. The disks will turn a little then stop. Occasionally it will still play a complete hymn but this is rare. Also a grinding sound can be heard with the ear close to the unit. I think when you pushed the combo of buttons and it stopped working, this is likely just a fluke and it was probably going bad anyway. I may be wrong but I have been down this road myself and your problem sounds very similar to mine. I can't offer you much encouragement...sorry...!
Jan 28, 2010 | Emerson MS3105 CD Shelf System
Audio problems
Did you connect both left and right RCA cable to aux1 forTV?Are you playing CD through your dvd player?
Also,double check your connection from your speakers to subwoofer.
Feb 27, 2008 | Teac PLD-2200 System
DVD stuck in player
We've been ripped off! I've learned my lesson about "Mintek" have you?
Feb 22, 2008 | Mintek DTV-263 26 in. LCD Television
158 people viewed this question
Top Teac Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Teac Audio Player and Recorder Expert? Answer questions, earn points and help others
