Hp photosmart all in 1 printer model c6180 receives 0xc18a0206 error message. installed all new ink with current dates. unplugged usb, removed catridges, powered off, plugged back in and still receive the same error message. please help!
  • msyolanda Nov 06, 2010
    yes i tried that per my initial question. i should also add there is a clicking noise when it reboots or when i turn the machine on. does this help with clarifying my question? thanks again!
    Genius:
  • 1,456 Answers
Hello
Turn off the printer and open the cover where the ink cartridge is located.
Remove the print cartridge from its slot. Look for a sticker on the cartridge stating it is the right HP print cartridge. If it is the wrong type of cartridge, or if the cartridge has been refilled, replace the cartridge with the right HP cartridge..
Remove the cartridges again and unplug the printer. Dampen a lint-free cloth with water and gently wipe down each one of the cartridges. Avoid touching the nozzles or the electrical strip on the cartridge.Wipe from the top of the contact to the bottom. Do this for each contact Place the cartridges back into the printer and turn the machine back on.
Turn the HP printer on. Use the printer to print a test page. If this does not correct the problem, move on
Remove the cartridges and check to make sure the electrical strip along the bottom of each cartridge is not damaged or ripped. If the cartridge is new, make sure the plastic protective tape has been completely removed. Place the cartridges back into the machine and turn it back on.
This should clear it.
Posted on Nov 06, 2010
    Genius:
  • 1,035 Answers
This is the proper procedure andif this fails, take it in for service.
Disconnect the Universal Serial Bus (USB) cable from the back of the product, but leave the product turned on.
Open the cover of the product and remove the print cartridges.
Close the cover and wait for the Insert Ink Cartridges message to display.
Disconnect the power cord from the back of the product and wait for one minute.
Reconnect the power cord. If the product does not automatically turn on, press the Power button.
Open the cover and reinsert the print cartridges.
Close the cover. If prompted, print a calibration page.
Reconnect the USB cable, and try to print a print job from the computer.
Posted on Nov 05, 2010
I have an HP Photosmart C6180 i get error 0xc18a0206
Welcome to Fixya.
Here's how to resolve this issue :
HP Photosmart Reset
Basically, this error denotes "Ink System failure" and can be resolved by Printer reset. Follow the easy steps and you should be good to go.
Thanks for using Fixya.
Aug 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
Error 0xc18a0206 for HP Photosmart 3310 All-in-One
Hello and Welcome!
The error
0xc18a0206 is mostly occurred in HP printers
To solve the error code
0xc18a0206, Follow the given steps
  • Reset the printer without turning off the printer, disconnect the USB cable from the rear of the printer
  • Remove the cartridges from the printer
  • Wait for the 'Insert Cartridges' message to display on the control panel
  • Disconnect the power from the back of the printer
  • Now wait 60 seconds
  • Now reconnect the power If the product does not automatically turn on, press the Power button
  • Reinsert the cartridges, and then close any open doors on the printer.
  • If you receive a prompt to print a calibration page.Print it
  • Reconnect the USB cable to the port of the printer & then try printing again
Error will automatically remove.
But if u face still this error then printer service required.
In that condition best option is to Contact HP Service Provider
I hope this solution helps you
Thank you for using FixYa
Apr 19, 2011 | HP Photosmart C6180 All-In-One InkJet...
I have a HP C5180, receiving error message 0xc18a0206 Ink System Has Failed. I have replaced all cartridges, unplugged power supply and USB cable for reset and am still receiving error message. Help! ...
Issue An 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
  1. Press the On button to turn the printer off.
  2. Unplug the power cord from the back of the printer.
  3. Remove all the ink cartridges.
  4. Wait two minutes.
  5. Plug the power cord into the back of the printer.
  6. Press the On button to turn the printer on.
  7. Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved. If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Mar 09, 2011 | HP Photosmart C5180 All-In-One InkJet...
I haven't used my HP Photosmart printer in awhile and now I'm getting a 0xc18a0206 error - I've tried taking out the ink cartridges, powering off, unplugging the usb cable etc. and I still get the error. ...
Apparently some defective components were used in the construction of the logic board (see photo). On my C6180 there were 3 failed capacitors (the green cylinders - the puffed top indicates failure) and a 4th from the same manufacturer (TEAPO - many unfavorable web references to this manufacturer). I purchased 3x 330uF 16V and 1x 680uF 10v rated to 105 degrees Celsius (total about 60cents). On the logic board, the capacitors I replaced are labeled C613, C614, C660 and C662. If you are not comfortable replacing the parts yourself (or don't have a soldering tool), you will have to find someone who will. The time to repair should be less than 30 min - I did it in 25 min with only a solder pen. This fixed the on and off problem and also fixed the ink system failures the printer was having. A similar fix may apply to other HP printers. acca299.jpg
Jan 20, 2011 | HP Photosmart C6180 All-In-One InkJet...
I just replaced every ink cartridge for me hp c5180 and the caption is still coming up "ink system failure. error: 0xc18a0206". What do I do next so I can just print?
Hi there you can try this may work,
Your error 0xc18a0206
Solution one: Reset the product
1. Without turning off the product, disconnect the USB cable from the rear of the product.
1. Remove the cartridges from the product.
2. Wait for the 'Insert Cartridges ' message to display on the control panel.
3. Disconnect the power cord from the back of the product.
4. Wait 60 seconds.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
6. Reinsert the cartridges, and then close any open doors on the product.
7. If you receive a prompt to print a calibration page, do so.
8. Reconnect the USB cable to the rear of the product, and then try printing again.
9. If you have completed all the steps listed above and are still experiencing a problem, you need to service the product.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Mar 10, 2010 | HP Photosmart C5180 All-In-One InkJet...
Installed all new HP ink cartridges, receive error Oxc19ac3ff. Now will not print.
Hi
This error means ink system failed. To troubleshoot this issue you'll need to remove the ink cartridges and would need to turn off your printer, unplug it and swap its USB port with other device and then insert the cartridges and switch on the printer. This will reset the internal error code.
Please do accept this solution and revert for further assistance.
Thanks
Rylee
Jul 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
This is for an HP Photosmart 3310 all in one. The display shows message Ink System Failure Error 0xc18a0206. Tried the troubleshooting steps on HP website: remove ink cartridges, unplug printer from...
Reset the product:
  2. Remove the cartridges from the product.
  3. Wait for the 'Insert Cartridges ' message to display on the control panel.
  4. Disconnect the power cord from the back of the product.
  5. Wait 60 seconds.
  6. Reconnect the power cord. If the product does not automatically turn on, press the Power button (c01602202.gif ).
  7. Reinsert the cartridges, and then close any open doors on the product.
  8. If you receive a prompt to print a calibration page, do so.
  9. Reconnect the USB cable to the rear of the product, and then try printing again.
Mar 07, 2009 | HP Photosmart C6180 All-In-One InkJet...
Ink System Failure HP C5180
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print. Solution
Wait two minutes.
Jan 23, 2009 | HP Photosmart C6180 All-In-One InkJet...
Printer error
Hi ok try I found this I know your error not in here but it may work for It worth a try nothing to lose and it may work. I know your error code is not in this but it some times it clean the error with this type of error number you can gave it a go try not harm it Error code: 0xc18a0201, 0xc18a0206, 0xc18a0306, 0xc18a030a, 0xd0620130, 0x887dd03a, 0xd05d010d, 0xf0af8004, 0xc19ac3ff, 0xc18a050...
Reset the product:
5. Wait 60 seconds.
6. Reconnect the power cord. If the product does not automatically turn on, press the Power button ( ).
Dec 19, 2008 | HP Photosmart C6180 All-In-One InkJet...
jasbo
jasbo
