Question about Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control
Have a L3H Fan ST controller - Fan runs but Remote won't control it.Remote appears to be reacting to functions requested but fan doesn't. Is there a DIP switch match between the fan and the remote that needs to match or is there a way to program the remote. we have 3 of these 2 work ok one doesn't?
  • 15 Answers
SOURCE: no connection between the fan remote and Ceiling fan
The remote-controlled fans that I've seen all have DIP switches in the transmitter (the "remote") and receiver (up by the fan). For the remote to operate the fan, both sets of switches have to be set to the same code. If you happened to bump the DIP switches (and change the code) while replacing the battery, the fan would no longer respond to the remote.
It's been four months since you posted this problem, so you've probably figured that out by now. Still, other users may run into the same problem occasionally.
Posted on Apr 17, 2008
  • 8 Answers
SOURCE: Program codes for tv and satelite.
https://fjallfoss.fcc.gov/prod/oet/forms/blobs/retrieve.cgi?attachment_id=305485&native_or_pdf=pdf
The manual
Posted on May 25, 2008
  • 14 Answers
SOURCE: Two ceiling fans, both remotes control the same fan
One of the dip switches is located under the globe, near the ceiling.
The other dip switch is located in the remote control. You have to take the battery out and look in the space where the battery is, usually towards the top of the remote.
On mine, there are four settings, the dip switches have to be in the same position, on both your remote and the fan unit, for them to work. You might have to reset them if you do not want both fans to work from one remote. Maybe one fan and remote have the first switch up and the other three down, that would let them both connect. The other may have the first one down and the others up, then it would only work from the remote that is set the same way.
Usually you can reset them by using the point of a pencil to move each dip switch setting.
Posted on Mar 26, 2009
SOURCE: Hampton Bay ceiling fan remote control
i have a problem with remote ceailing fan and light i tried push on light key - dim light low to high working but fan isnt working hi to low. i checked the supply wire red, white and black so i have a installing receiver and receiver have red receiver wire to black supply wire, white receiver wire to white supply wire , but what i do with red supply wire to QQQQ
Posted on Aug 09, 2009
  • 41 Answers
SOURCE: I need the codes to program the ONE ALL URC-2060 universal remote
Don't know the codesbut you can scan for it by doing the following:
If your remote has a 'Scan' button, do the following:
1. Press the VCR button
2. point the remote at the VCR and press the 'Scan' button.
This will get the remote to go through all of the codes it knows for VCRs at about 3 second intervals. Once you see the VCR state change, hit any key on the remote and it will be programmed for the proper code.
Posted on Sep 15, 2009
Fan only runs on slow speed
The receiver in the fan housing may have failed.
Apr 20, 2017 | Hunter Dryers
Remote wont work for fan.
http://www.ehow.com/how_6104129_instructions-hampton-bay-fan-remote.html You may need to reprogram the remote
May 15, 2013 | Televison & Video
My control won't activate the light on my Hunter fan. The light comes on via pull chain fine, and the control works the 3 speeds on the fan, but the light won't respond.
Check the wiring on your receiver to make sure the light wire is connected.You have to have the light on with the pull chain and then use the remote to turn it on/off.
Jan 06, 2013 | Hunter 52" Ceiling Fan With Light And...
Remote doesn't work
Have it tested with a tester or with a digital camera since many will react on their display screen in a dark room.
Jun 11, 2012 | Samsung AK59-00104R Remote Control
CEILING FAN WORKS,BUT REMOTE ONLY WORKS THE FAN SECTION, WILL NOT DIM LIGHTS NOR TURN OFF LIGHTS ONLY SO WE CAN USE FAN ONLY. WHAT DO WE HAVE TO DO?
Fist, make sure the bulbs are good. Check in another fixture to verify that they indeed work. Since the remote works the fan, dead batteries can be ruled out. The problem will be confined to either a bad receiver in the fixture, or a bad remote.
Since Hampton Bay is a line carried by Home Depot, you may have some luck bringing your remote to HD and trying it out on the display units. You may need to try different address settings on the remote to find one that works if you don't get results the first time. This is usually several two position switches often called "DIP Switches". Change the positions of them one at a time until you find one that works. Try to control a fan first. Once you find a fan the reacts to the commands from the remote, try to control the light. If the light doesn't work - the remote has a bad transmitter or light switch control. You could attempt to disassemble the switch, but most don't have parts that look different when they're bad. You'll probably have to replace the remote.
If the lights work, then the problem is with your fixture. You can remove or simply bypass the radio controller in the fixture and install an after market receiver and remote to control it again. These are sold at Home Depot and work with any paddle fan.
I hope this helps & good luck!
Oct 26, 2011 | Hampton Bay 48670 Flemish Pewter Finish...
1995 chevy lumina sensor went out and fan wont turn
How did you determine that the sensor failed. Did the check engine light come on? When you say that the fan won't turn, do you mean that it won't turn on and run or that you can't physically turn it by hand. To determine this, disconnect the electrical connector to the fan and try to turn it by hand. It should turn easily. If it doesn't then it must be replaced. If it does then reconnect the electrical connector to the fan and try to operate it by disconnecting the temperature sensor lead and placing a jumper wire between the terminals of the harness. turn the AC control to AC/MAX and turn the ignition key to on. If the fan runs then the problem is the sensor. If it doesn't then check the fan control relay and any related fuses. WARNING : Use extreme caution when testing the fan circuit. Never attempt to turn the fan with the electrical connector in place. The fan can operate at any time even if the engine is off.
May 14, 2011 | 1995 Chevrolet Lumina
Fan speed control UC7058RY produced by RHINE, need to order replacement? For St. Regis 60" Hampton Bay Ceiling Fan.
hi Januszkop,
I have the same ceiling fan. However, I lost the remote control. Do you know where I can buy it? Thanks.
Oct 24, 2009 | Hampton Bay 60 In. St. Regis Fan, Ancient...
Ceiling fan remotes
If you know where the remote receiver is located on the fan (probably in the canopy or the compartment where a light kit would attach), you may want to see if you can find the wire antenna that is hanging off of it. If possible, run that wire outside the canopy so it is exposed, this might give you a better response.
Dec 23, 2008 | Hunter 52" Ceiling Fan With Light And...
The Hampton Bay Altura Ceiling fan functions only with remote.
I contacted the manufacturer (kingofffans.com) after my Altura fan would run on high speed only and the remote would not control any thing. They said their was a manufacturing defect with a capacitor that affected many of the Altura fans. We are now on a waiting list for a new capacitor and housing, because they did not have enough replacement parts.
Nov 26, 2008 | Hampton Bay 52 In. White Redington...
Universal Remote Control Hampton Bay Universal Ceiling Fan/TV/DVD/Satellite Remote Control Logo
139 people viewed this question
Top Universal Remote Control Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an Universal Remote Control Televison and Video Expert? Answer questions, earn points and help others
