Question about Sony Playstation 3 (PS3) Console
Ps3. On the screen. Say. New hard disk not found
  • 1,472 Answers
Hayyoutcv
If you are getting a hard drive detection error message then one of 2 things have happened ether the master boot record on the hard drive got corrupted or the drive has gone bad. The link below will take you through formatting the drive with your computer. If this does not fix the problem then you will need to replace the hard drive.
http://www.fixya.com/support/r4853494-fix_playstation_3_corrupted_hard_drive
Let me know if you have any more problems or question
Issken
http://www.fixya.com/users/issken
Posted on Nov 10, 2010
Ps3 cannot start hard disk not found
The hard disk may be faulty. Try reseating the hard disk if the PS3 still cannot find the hard disk then it is faulty and a new hard disk is needed and the PS3 software needs to be installed on the new hard disk.
Dec 05, 2011 | Sony Video Game Consoles & Games
My screen says cannot start. The correct hard disk was not found. what do i do?
Id say you have a corrupted HDD..
This happens if you turn the ps3 off alot by the switch instead of going to shutdown.
New HDD should fix it
Feb 03, 2011 | Sony Playstation 3 (PS3) Console
I have a slimline ps3 and my hard drive was corrupted so i downloaded a new system update it installed the update it let me adjust the time and date settings and just before it goes to the screen that...
  1. KINDLY REMOVE THE HARD DISK FROM THE CONSOLE
  2. LOOK FOR AN EXTERNAL HARD DRIVE PACK
  3. PUT THE PS3 HARD DISK INTO THE EXTERNAL HARD DISK PACK
  4. CONNECT IT TO YOU COMPUTER
  5. AND FORMAT IT.
  6. REMOVE IT FROM THE EXTERNAL PACK
  7. PUT IT BACK INTO THE PS3 CONSOLE AND TURN IT ON.
  8. IT WILL ASK FOR UPDATE
  9. THEN YOU UPDATE IT.
  10. IF AFTER DOING ALL THIS AND IT DOSEN'T WORK
  11. CHANGE THE HARD DISK INSIDE THE PS3.
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Playstation 3 screen says " cannot start, the correct hard disk was not found." after turned on. will do nothing else. any ideas?
A long shot but it sounds like your hard drive has basically "switched off". If you have a USB sata hard drive dock I can help but its a bit of a complicated process. You need to remove the hard drive from the PS3 and plug it into the USB sata dock then connect it to your computer. Goto Control Panel -> Administrative Tools -> Computer Management -> Disk Managment. Look in the lower area of the screen that appears for your PS3 drive, probably E:, and look if it says "Not initialized". If it does, right click where it says that then click Initialize Disk. Put it back in your PS3 when it is done and hopefully it will turn back on. You will lose all saved data though as the hard drive will need to be formatted.
Hope this helps
Jul 24, 2010 | Sony Playstation 3 (PS3) Console
My ps3 says, cannot start, the correct hard disk and whines
yes this should solve your problem. however this will void any warranty so if there is still warranty then send it off. otherwise replace it and the problem should be solved
Nov 17, 2009 | Sony Playstation 3 (PS3) Console
PS3- cannot start. Correct hard disk not found.
when your ps3 is standing upright the tall way tip it over and look at the bottom there should be a plate that says something about the hard drive. get a flat screwdriver and pry on the right side of the plate. The hard drive is directly behind that plate and is secured by a blue screw. take out the screw and flip out the little u shaped handle and slide it to the right and pull out your hard drive. Try blowing out all the connections and putting it back in hope this helps
Aug 06, 2009 | Sony Playstation 3 (PS3) Console
Cannot start. The correct hard disk was not found.
u will have to get a new hard drive i would get this one it is cheap http://www.walmart.com/catalog/product.do?product_id=10710953
you will have to take the cover off the hard drive.
Jun 30, 2009 | Sony Playstation 3 (PS3) Console
Hard disk problem
I have a problem with ps3 Cannot start the correct hard disk was not found. can any one help me on this.
Dec 31, 2007 | Sony Playstation 3 (PS3) Console
Hard disk
try removing and reistalling the HDD then use the ps3 format utilitl , or get your hHDD tested to eliminate it from the problem
Dec 28, 2007 | Sony Playstation 3 (PS3) Console
Hard disk not found?!
i thik u have to format the hard disk and try it again. or may be u have change to the security settings.
Dec 25, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
32 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
