Question about DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale
When i turn my scale on it reads, "24C02" for
Resetting my accur 8 digi scale cp-1000
please preform the following procedure
Calibration
1. Place the scale on a leveled surface & turn off the scale.
2. Press and hold the "MODE" key and ON/OFF key until the LCD
displays a random number.
3. Now release both keys and press the ON/OFF key once. The
display will read "CAL" and then "1000.0".
4. Place a 1,000g weight on the center of the platform and wait 3 to 4
seconds. The LCD display reads "PASS", then "1,000.0g". Remove
the weight and turn off the scale.
5. Calibration is complete and the scale is ready for use.
check this link for manual:
Untitled Page
Apr 25, 2014 | Health & Beauty
Dashes
I have a Health-o-meter but not the same model. Mine still has the instructions pasted (loosely) to the bottom.
The secret is that you must initially press the lower (left or right side) corer for just a second or two. That causes a few dashes and then the scale reads 00.0. Then get on the scale and get your reading.
Alternative behavior:
If you initially press the corner for more than a few seconds it will cycle through User Numbers one through four. If you use that feature it remembers your weight from the last time so you can see the difference.
Apr 15, 2014 | Health-O-Meter Health o meter 844KL...
The screen displays a code of 24C02 after new batteries are installed
spam,only 1 is needed,it was already answered,the code is what scale it is,it is nothing for you to worry about
Sep 23, 2013 | Salter Brecknell 311 Digital Postal Scale
Dude, Can you send me a Bootable ISO CD of Dell Asset/Service Tag BIOS Reset Tool........Please
Hello, you can download this tool here:
http://www.cgsecurity.org/wiki/CmosPwd
Dell
The official method is to contact Dell Technical Support. Dell Technical Support will request the Service Tag and Express Service Code from the bottom of the Latitude. If the current user is not the original Latitude owner, Dell will transfer the used Latitude's registration from the original owner with only the Service Tag and Express Service Code from the tag on the laptop.
  • Dell Inspiron 5100: eeprom 93lc46, password in scan code at 0x310
  • Dell Inspiron 7500: eeprom 24c164
  • Dell Inspiron 8100: eeprom 24c02
  • Dell Latitude C600: eeprom 24c02, password in scan code at 0x00, 0x10 and 0x90
  • Dell Latitude C610: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80 and 0x90
  • Dell Latitude C640: eeprom 24c04, password in scan code at 0x100 and 0x180
  • Dell Latitude CPI: eeprom 24c02, password in scan code at 0x00, 0x10, 0x80
  • Dell D600: eeprom 24c04, password in scan code at 0x110
  • Dell Optiplex: Remove the PSWD jumper
  • For most Dell Dimension desktops, the steps to reset a BIOS password and clear all CMOS settings are:
    • Locate the 3-pin CMOS password reset jumper on the system board.
    • Remove the jumper plug from pins 1 and 2.
    • Place the jumper plug on pins 2 and 3 and wait approximately 5 seconds.
    • Replace the jumper plug on pins 1 and 2.
Try the backdoor password: Dell
The another method is: by Using the Motherboard Jumper: In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off, and remove the battery and power cord
( if it is a laptop ) before you continue.
Here is a picture how it looks like:
The default setting is:pin 1 to 2, to clear cmos: 2 to 3.
Best of luck :-)
Feb 05, 2013 | Computers & Internet
How to fix an easy weigh digital scale
the 24c02 is a memory chip inside. Unless your a tech - you can't repair.
Jun 07, 2012 | DigiWeigh 100 X 0.01 Gram Digital Jewelry...
How to calibrate 1000xr us-magnum digital scale
magnum 1000xr pocket scales turns on calibrates goes to different modes but wont show the weight when object placed on the scale,a lock appears in top left of window, is scales broke or do i have to make lock symble dissappear?
May 28, 2011 | Kitchen Appliances - Others
Err 1 message on Taylor Lithium Elec Scale model 7346
This is a reply I received from Taylor customer support. I have followed this procedure enough times to wear out the original battery and still get the Err 1 message. You may have better luck.
Thank you for your e-mail. The reboot below may clear the error from
your scale. You may need to do this several times to completely reboot
the system. Please let us know if you have any questions or continue to
display the Error.
1. Remove the battery from the scale
2. Set the scale on the floor without the battery in place.
3. Stand on the scale for 10 seconds (still without the battery)
4. Carefully replace the battery without turning the scale on.
5. Using only one foot, tap the scale or apply just enough pressure to
turn on the display. (It should show dashes or zero's) IMMEDIATELY
REMOVE YOUR FOOT.
6. Let the scale turn off
7. Step on the scale for a weight reading
Regards,
Linda DLT
Consumer Relations
Taylor Precision Products
& Salter Housewares
2220 Entrada del Sol, Suite A
Las Cruces, NM 88001
Toll free - 800-289-0944
866-843-3905
Direct - 575-526-0944 ext 3172
Feb 11, 2009 | Taylor & Digital Scale Lithium Scale
DigiWeigh 100 X 0.01 Gram Digital Jewelry Pocket Scale Logo
989 people viewed this question
Top DigiWeigh Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a DigiWeigh Measuring Tool and Sensor Expert? Answer questions, earn points and help others
