Question about HP OfficeJet 4215 All-In-One InkJet Printer
4215 All in one scanning problem
Had new hard drive installed.
when using scan faeture for documents, scanner feeds and records doc preview fine. When trying to process as PDF, as I have done successfully done countless times before , internal error messges shows up as final processing is being done.
  • 549 Answers
Check out this link for your unit.
It could be that you need to reinstall the drivers for it from cd rom.
If you have no cd rom for it, you may be able to find it at the link.
Posted on Jun 14, 2008
What is Apostille definition and How can you apostille a document?
This is a document certification scheme which applies in countries which are signatories to the Hague Convention on Private International Law, eg not in Brazil.
It notarizes or certifies a government issued document as a genuine one for use in another signatory country eg a US birth certificate for use in say, Spain.
Such a certificate is called an apostille. It is issued by any approved office in the issuing country. In the US this is generally any approved agent of the US Dept of State:
http://travel.state.gov/content/travel/en/legal-considerations/judicial/authentication-of-documents/office-of-authentications.html
http://www.usauthentication.com/index.php
Nov 29, 2015 | Office Equipment & Supplies
B&w/gray Scanning Is Okay But Color Scanning Problem
Run ink head cleaner routine. If you cannot the list make and model of printer. Thanks.
Dec 25, 2014 | Office Equipment & Supplies
Scanner computer cant comunicate
What do you want Darrell?
Code reader or Professional scan tool?
I think your going to need a shop to work on it
Without wiring diagrams your done
You have to chase every wire from the under dash
connect to their ends, until you fix the issue & can
connect to the Bus & Data stream,we can't help with that
Jul 17, 2014 | Office Equipment & Supplies
Hp laserjet m1522f error 5 turn off and on
Hi, Error 5 is a Scanner error. When turning the printer on, have the lid up so you can watch the scanner movement. Does it move smoothly? It should go through a warm up and you should be able to watch the scanner movement. If there is a problem with the scanner, there isn't a lot you could do except. The service manual says the scanner assembly should be replaced. If it was my printer, I would try to take a closer look at the scanner assembly and check to see if the scanner unit is bound up somewhere, or maybe a drop of 3 in 1 oil on the scanner rails. Let us know what happens.
thanks
Oct 02, 2013 | Office Equipment & Supplies
Samsung SCX-3201G printer driver free download
Samsung SCX-3201G printer driver no download plzzzzz help me
Jun 21, 2012 | Office Equipment & Supplies
"Error sent to printer" problem with ZDesigner TLP 2844
have you gone to printers in control panel and made this printer with a tick in it so its the one the computer recognises
Dec 24, 2011 | Office Equipment & Supplies
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
Why does canon MP258 printer with scanner can't scan japanese yen paper bill amount 10,000. I tried it over 10 times but it stops,. And when i tried US paper bill, it works well. I need some explanation...
When you scan with any scanner it utilised the software with "Optical Character Recognition functions, usually abbreviated to OCR -> OCR is a field of research in pattern recognition, artificial intelligence and computer vision." to scan and record the scanned object, sometimes it does not or cannot recognise certain symbols or characters because of man made software & hardware have its limitations too.
Hope it helps.
Nov 12, 2010 | Office Equipment & Supplies
HP OfficeJet 4215 All-In-One InkJet Printer Logo
111 people viewed this question
Seeker5211
Seeker5211
mukhtar21 shaikh
mukhtar21 shaikh
