Question about Kenmore 53202 / 53204 / 53209 Side by Side Refrigerator
Hi there my ge profile refridge model psc23ngsa the control panel on the door is blinking HRS what does that mean?
Locked light blinks but oven is not locked
This does not necessarily mean the DOOR is locked but that the control panel may be in a "locked" mode. This prevents children from playing with controls. Look closely at the touchpad for one selection that shows a tiny padlock under or on it. When found, push and hold for 5 seconds. You should hear a beep which will confirm the unlocking of the control panel.
Nov 19, 2012 | GE Profile PGB918 Kitchen Range
Our GE Profile refridge stopped working and all of the food getting warm. The model number is: Psw26sgrbss. What do we do?
controls inop.? replace main control. is compressor running and controls responsive? then check for defrost problem. comp ok but no frost either then sealed system problem.
Sep 14, 2012 | GE Refrigerators
The refridg part of my ge side by side stopped working but the freezer still works
HI,CHECK IF THE EVAP MOTOR IS WORKING,IF MOTOR IS WORKING ,PROBABLY YOUR REFRIG HAVE A BAD CONTROL BOARD CHECK BOTH OR REPLACED BOTH ALSO CHECK AIRFLOW CONTROL DAMPER..
Jul 05, 2011 | GE Profile PSW26P Stainless Steel Side by...
Icemaker over fills G E profile
To be sure I would need your model number of your profile. If the electronic it will not be adjustable. Do you know for sure that the water control valve is not leaking? I am going to point you to a site that may help you locate model numbers. GE now makes the bottom freezer profile and I don't want to mix it up by guessing.
Mar 19, 2010 | GE Refrigerators
Power is on but no control indicators are visible and the letters HRS are flashing inside one of the indicators inside the door. The refrigerator model is a pss26ng GE Profile Arctica
Unplug this refrig from the wall, let sit for one hour, then plug back in, if it starts then you may have a start device on compressor that is bad, more than likely it won't, normally the HRS means there is a "main board" problem. Main board is located on rear of refrig.
Oct 17, 2009 | GE Profile PSW26P Stainless Steel Side by...
GE Profile Performance Spectra Range error code F0
F0 - F1 - F7 Stuck keypad may mean relay is turned on. Determine if problem is with the Key Panel or Control by:
1. Pushing CLEAR/OFF pad.
2. Disconnecting Ribbon Cable from control and waiting at least 32 seconds to see if Code recurs
If code recurs, problem is in the control. Replace control.
If code does not recur, problem is with the Key Panel.
Jun 20, 2009 | GE JKS05 Electric Single Oven
HRS flashing, nothing getting cold
Your refrigerator has a control board on the back behind a metal panel. Unplug and look at both sides to see if you see burn marks or loose solder. Go to this site and place model PS123NCRBV into the model search feature.That will take you to 13 similar models. The board on back is my first concern and the control inside will need to be looked at also if you find no problems on the back. The control board number is WR55X10656 let me know what you find, Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
May 19, 2009 | GE Profile PSI23NCR Side by Side...
GE Arctica
there is a board in the back right side behind a panel embedded in the back of the unit just above the back cover. it is a Part # WR55x10552 this is most likely your problem it controls all functions of the unit
Aug 01, 2008 | Refrigerators
Kenmore 53202 / 53204 / 53209 Side by Side Refrigerator Logo
87 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
