Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Can I use the Vacum cleaner for floors only without using the liquid. I do not want to wet the floors just sweep the dust away. I cannot find my manual.
    Novelist:
  • 147 Answers
First off your manual is right here....
http://www.hoover.com/pdfs/manuals/H3000.pdf
But more to answer your question, yes you can use it on the floor without the wet. You will want to turn your brush switch to the off position. Also, do not fill the water tank or press the spray lever for dry pick up only.
Hope this helps.
Posted on Nov 05, 2010
Having lots of drywall dust, vacuum cleaner is connected and hose is having suction but sander is kicking dust all over the place. Can you help .
Wet some old bed sheets and lay it on the floor where you are sanding.Sand by hand.Using a power sander will not only damage the wall;but will also damage both the vac and sander
Jan 21, 2018 | Vacuums
Tip
Dyson Hard DC56 or DC57 cordless vacuum cleaner - Getting started
How to assemble and use your new Dyson Hard DC56 or DC57 cordless vacuum cleaner. Our video also shows you how to attach and remove the wet wipe, and how to use the Double edge floor tool without the wet wipe for general hard floor vacuuming.
on Oct 04, 2013 | Dyson Vacuums
How to use on hardwood floors
yes but if they are laminate dont use wet cleaner vac
Jan 08, 2018 | Vacuums
Wont pick up anythimg
Check your pick up tube. Use a straitened wire hangar to push up tube and check blockage. You also may need to change the bag. Some bags sides will clog with fine dust and reduce the suction.
Jan 03, 2016 | Bissell Steam and Sweep Hard Floor Cleaner...
I have a Samsung SU3364 vacum cleaner have never been able to use the crevice tools as there is no suction when you take pipe off, only when you use it as a floor vac, any suggestions have tried every
If the vacuum is old, the intake path from the hose to the dirt receptacle may be plugged from years of dust, dirt and grime. This happened to one of our vacuums, and I had to take off the bottom guard, the belt and the sweeper bar to access the intake, and it took me about an hour to get it unplugged.
If this is a new machine, the hose may not be properly connected when you are using the crevice device. Check the manual for proper installation.
Jul 22, 2014 | Samsung 5490M Lightweight Upright Vacuum...
I have a 5.5 hp craftsman 20 litre wet Dry vacum . I have lost the manual. & have 2 questions 1) how do I change to wet vacum from dry? Also could i use the wet mode with some water in it and let it...
# 1 myou just take the bag out make sure ytou sponge filter is in place athe top and turn it on the power switch just turns on ,machine ther is no wet dry switch just an empty bagless cannister is all you need make sure the ball outlet in vacumn is working it stops water from overfilling cannister # 2 just use the proper bag and attachment to vacumn up the drywall dust a good building supply store has special sanding attachments for vacumn so you can sand and vacumn at the same time
Dec 18, 2009 | Vacuums
Bissell ProHeat Rug and Floor cleaner. Won't
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
sf
Oct 20, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Shark Floor Cleaner streaking on pergo laminate floor
Start with a clean pad. A dirty pad wil spread the wet residue around and strek the pergo. After steaming use a clean microfiber dust mop to buff the pergo. It will dry and shine yur laminate.
Jan 10, 2009 | Euro-Pro Shark Steam Mop - Gray/ Purple...
I don't have the aquamate shampoo that is recommended for the rainbow e2 aquamate floor cleaner. what is safe to use with it?
any shampoo made for extractor type machines will work fine, or mix liquid laundry soap 50-50 with water (after all, you AREwashing fabric}
Nov 26, 2008 | Rainbow E series Canister Wet/Dry Vacuum
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
64 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
