Question about RCA P52960 52" Rear Projection Television
Daed tv can't locate flyback and horizontal part,canyou help
    Novelist:
  • 97 Answers
Hi airbags29!
Does this set have one or three projection CRTs? If one, just follow the high tension wire that connects to the middle (front to back-wise) of the tube...this comes directly out of the flyback...
If three tubes, there MIGHT be three flybacks, or all three could share the same secondary anode supply voltage.
Don't do this with the set on, and be aware that the CRT(s) can act as giant capacitors and hold a SUBSTANTIAL charge even after being off for months! Discharge the tube with an insulated screwdriver or test lead, grounding the connection on the tube.to metal framework. I've accidentally stuck my elbow into a 25,000 volt SURPRISE more than once, and it is a SHOCKING experience !!! Ha !!!
Hope this helps you out, let us know if you need further assistance, or you can contact me directly at wldbil49@yahoo.com and GOOD LUCK!
-WB
Posted on Jun 14, 2008
Sony Wega KV-34HS510 standby blinks 7 times in red
Hi and welcome to the site,
Initially, the Sony KV-34HS510 uses the DA-4 Chassis. On this chassis, 7 blinks refers to the fault "Horizontal Deflection Stopped" indicating a problem with the horizontal section. Offhand, check, replace the HOut transistor and have the FBT (flyback transformer) ring tested.
Good luck and thank you for asking.
Aug 19, 2010 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Find a horizontal output transistor or flyback
Flyback transformer part number for a tv RCA F32648
Mar 06, 2010 | RCA F32648 32" TV
Tv shutting off timer light blinking
Your TV is in the protection mode. First, locate the horizontal output transistor. This is found very close to, or next to, the horizontal output transformer (also known as the flyback). The flyback should be on an aluminum heat sink, or on the side of the metal chassis. Disconnect or unsolder two of the three legs of the transistor. Measure it with your meter, or plug in the set with the light bulb attached across the fuse.
If the transistor is shorted, or the light bulb doesn’t glow bright anymore, replace the transistor and plug back in. If the light bulb glows bright again, you must replace both the flyback and horizontal output transistor simultaneously. In some cases this will fix the set, but sometimes there are multiple problems with a set.
Go to where the flyback is, and start measuring the diodes and capacitors on the flyback itself. If you don't find any shorts there, it could be a shorted vertical output IC, a shorted sound IC, a shorted disc capacitor in the Hi Voltage/sweep circuit, or in rare cases, a shorted capacitor or tuner.Feel free to ask and post whatever the result of your troubleshooting..
Hope this may help;
Regards,
VOTIT
DON'T FORGET TO RATE
Aug 30, 2008 | JVC AV-27D303 27" TV
Tv will not turn on
Hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Toshiba 32A33 32" TV
Please Help
Hope this may help;
Regards,
VOTIT
Aug 21, 2008 | Sansui DTV2760 27" TV
Tv is not wrking
Hope this may help;
Regards,
VOTIT
Aug 17, 2008 | Sansui DTV2760 27" TV
Dead set!
Hope this may help;
Regards,
VOTIT
Jul 30, 2008 | Televison & Video
Da?±a el transistor horizontal
Hola,
El transistor de salida horizontal es un 2SC5331 (Q303). Por favor también compruebe el transformador Flyback (FEA661).
Estará bien comprobar también Q103 (IRF740) que es el regulador de recorrido HV. En algunos casos, D123 defectuoso en el recorrido G1 puede causar el HOT a corto.
Un diagrama esquemático / manual de servicio está disponible aquí.
Tengo que hacer el uso de trnaslator en línea para contestar a su problema.
Buena suerte y saludos cordiales.
Jan 04, 2008 | ViewSonic G790 19" CRT Monitor
Tv problem
The F27442 uses the CTC203 series chassis and that symptom is very common. If the horizontal output is shorted you MUST resolder the coil in series with the base of that transistor and the pins of the small horizontal drive transformer. When they have been properly resoldered you can put in a new original horizontal output transistor. If the output transistor shorts out again then your flyback (high voltage) transformer is shorted and needs to be replaced.
Aug 08, 2007 | RCA F27442 27" TV
No power
Check the FBT and the Horizontal Output Transistor also.
Sep 18, 2006 | Panasonic TX-15AT1 15" TV
RCA P52960 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
