Question about Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive
What is the jumper configuration when used in a pvr
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 106 Answers
You must chose cs , is the best way to make it work !
Posted on Nov 05, 2010
Shaw pvr expander not working
Take your Shaw remote control.
Press SETTINGS.
Use the LEFT/RIGHT keys to highlight PVR.
Click OK.
Use the LEFT/RIGHT/UP/DOWN keys to highlight PVR HISTORY.
Click OK.
Scroll through the entries, looking for any "hardware failed" or "hardware error" messages -- finding any implies a failing disk-drive inside the Expander.
Need more help? Telephone Shaw, and ask for "technical support" for TV/PVR.
Jul 21, 2012 | Motorola Televison & Video
I want to reset BOIS password for Gigabyte GA EP43 motherboard which has no jumper, i try to remove battery but the problem unsolved~
There is a CLR CMOS jumper on that MB next to the SYS FAN 2 connector by the IDE header
open = no clr
jumped= Clear CMOS
From the manual page 32
Use this jumper to clear the CMOS values (e.g. date information and BIOS configurations) and
reset the CMOS values to factory defaults. To clear the CMOS values, place a jumper cap on the
two pins to temporarily short the two pins or use a metal object like a screwdriver to touch the two
pins for a few seconds.
• Always turn off your computer and unplug the power cord from the power outlet before
clearing the CMOS values.
• After clearing the CMOS values and before turning on your computer, be sure to remove
the jumper cap from the jumper. Failure to do so may cause damage to the motherboard.
• After system restart, go to BIOS Setup to load factory defaults (select Load Optimized
Defaults) or manually configure the BIOS settings (refer to Chapter 2, "BIOS Setup," for
BIOS configurations).
Jul 20, 2011 | Gigabyte GA-EP43-UD3L Motherboard
I want to know the Jumper settings (Master and Slave) for IBM Travelstar 15 GB Hard drive. I would be glad and thankful if you will solve this problem for me. Ari Kiviharju
This solution will reference the picture below:
To configure the drive in Master mode, no jumper setting is used (Figure A1).
To configure the drive in Slave mode, the jumper must be placed over the two vertical pins on the far right (Figure A2).
To configure the drive in Cable Select mode, the jumper must be placed over the two pins in the bottom row (Figure A3)
If you find this solution helpful, please leave a positive rating!
Jun 20, 2011 | Computers & Internet
I want to disable the system password on my dell computer
I assume that you have the password? Restart your computer. As soon as you see the dell screen, hit the f2 key. This will take you into setup. Look through the different menus and you will find the password options somewhere. You should be able to disable it there.
Mar 02, 2011 | Intel D865GBF Motherboard
How do i configure this hard drive for a 'slave' ?
Hello
Ok, you ill be able to see the jumper configuration on the hard drive itself. Here is an example on what the jumper diagram will look like on a hard drive.
Now, all you need to do is to have a look on your hard dive and see where you need to place the jumper for the slave configuration. Here is what a jumper looks like.
After you have done this, you only need to plug the hard drive into your pc.
Hope this can be of help.
Kind regards
Aug 13, 2010 | Quantum Fireball 15 GB ATA-66 Hard Drive
Maxtor hard drive jumper setting for model 6v200e0
here is a poster of Maxtors jumper settings for each kind of drive.
Nov 12, 2009 | Computers & Internet
GA-EP43-UD3L Having problems installing motherboard. Will not boot. Phase Led lights flash on then off. Help
CLR_CMOS (Clearing CMOS Jumper) (next to the battery)
Jun 20, 2009 | Gigabyte GA-945GZM-S2 Motherboard
Can I use a WD3200AAJS as a slave drive. If so what is the jumper configuration.
Hello!
The drive you have is a SATA drive, and has no master/slave configuration as such.  There is a connector block on the back to configure other options such as spread spectrum clocking.  Normal configuration is a jumper between pins 1 and 2 (all the way on the right side, facing the back).  A picture of the other configuration options is shown below.
Hope this helps you out,
Ken
Jan 07, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Hi i have a 10.1gb Maxtor model 31024H1 IDE hard drive and i need the jumper setting for slave
slave is NO jumpers at all
(Master) - The vertical jumper over the J50 pins is configuring the drive as a Master. The horizontal jumper over the J48 and J46 pins is in the Storage position.
(Master with CLJ) - The vertical jumper over the J50 pins is configuring the drive as a Master. The vertical jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Slave) - No jumper is required to configure the drive as a Slave. The jumpers over the J48, J46, J44 and J42 positions are both in the storage position.
(Slave with CLJ) - The jumper over the J44 and J42 positions is in the storage position. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
(Cable Select) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J44 and J42 pins is in the storage position.
(Cable Select with CLJ) - The jumper over the J48 position is configuring the drive for Cable Select. The jumper over the J46 pins is in the Cylinder Limitation position (CLJ).
Oct 13, 2008 | Computers & Internet
How do you convert video to work on the PVR-H140?
The PVR h140 works on mpeg1 or mpeg4 format. If you need to convert avi files for example you will need a third party conversion programme such as Nero7 or similair free programmes. Check here for a 'how to' page. http://www.sharewareguide.net/article/Guide/guide:how-to-convert-video-to-mpeg4,-such-as-avi-to-mpeg4,-mpeg-to-mpeg4-and-vob-to-mpeg4-with-this-mpeg4-converter.html
Mar 06, 2007 | Mustek PVR-H140 Digital Media Player
Western Digital Caviar WD1600 (1600YD) 160 GB Hard Drive Logo
103 people viewed this question
Top Western Digital Computers & Internet Experts
Alun Cox
Marvin
Marvin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
