Question about Maytag Atlantis MAV7551 Top Load Washer
Maytag Atlantis MAV7650AWW. Spin cycle makes loud screaching noise. Belt looks ok. Appears to be oil on the floor behind the washer. How do i get the front cover off? (clips on the bottom).
jsrock516
  • 5911 Answers
SOURCE: Maytag Atlantis Washing Machine
The loud squeak at the end of the spin cycle is usually attributed to a worn snubber ring and/or brake assembly. You cannot lubricate the snubber to get rid of the noise. In fact, you may damage the washer if you do. A small amount of corn starch can be sprinkled under the bottom tub support where the snubber ring is to get rid of most noise related problems (this will be the bottom round plate where it meets the casing of the machine). A worn snubber will also cause some vibration or out of balance problems. The brake tends to glaze over after it has become worn and will squeak or cause sudden jerking (causing movement of the washer) went the spin cycle stops. I would recommend replacing the following parts:
Brake Stator: 1057484 Price: $7.45
Brake Rotor and Lining: 1032674 Price: $16.70
Snubber: 1055142 Price: $4.35
Brake Removal Kit: 997909 Price: $99.40*
*Brake removal tool is required in order to remove the brake assembly and/or to replace the snubber. There is a 200lbs spring located under the Brake Stator that must be compressed PRIOR to removal or you could cause injury to yourself. NOTE: There should be a warning label explaining this
You can find all your parts and information at repairclinic.com. Just type in your model number in the search menu.
The parts required to make the repairs aren't very expensive, but the tool required to do it can be a bit pricey. If you've never worked on this type of washer before, this is not a job that I would recommended to the average do-it-yourselfer. Maytag is real good about providing the necessary instructions with their parts, however.
In summary this job involves the following steps:
1. Removal of the front case to access the washer interior.
2. Removal of the drive belt and pulley from underneath the washer.
3. Removal of the drain hoses from the wash tub.
4. I usually remove the entire wash tub with transmission still installed at this point and place it upside down outside the washer for ease of accessing everything. (There are other methods, but I find this one easier).
5. This is where the brake compression tool will be required to remove the brake rotor, stator and snubber ring.
Now, I am summarizing this job quite a bit. If this is something you wish to try to repair yourself, and you need more instructions, let me know. I hope this helps you.
Posted on Feb 09, 2008
huuum
  • 750 Answers
SOURCE: maytag atlantis washer mav-31
Hello
Welcome to fixya.
I'm Huuum and happy to assist you,
Is t your washer cleaning the clothes and operating fine other than the noise?
If so do not spend any money on it unless it breaks or does not operate!
"If its not broken do not fix it!"
I know this is not the what you wan to hear!
I have a telephone number of the consumer affairs of for maytag that's hard to find!
If you call them thay will demand that thier servicers find and remedy the problem or swap it out for you!.
Even if it is past warranty.
I'm not at work for another couple of hours.
When I get there I'll give you the 800 number for Whirlpool (They now own Maytag) Consumer affairs and you can cal Monday!
I do this frequently for my customers!
Everyone knows,
"It's easyier to keep the customers you have than find new ones"
But no matter what happens,you have no need to pay the repair persons child's college tuition!
You have your own needs!.
How much did you spend on this machine even though it did wash and perform?
Noise is not broken or failure.
I had a Maytag Neptune that did this for 6 years and I fixed 2 other problem unrelated .
Then on the third break down I dumped it in the trash and bought myself a Speed Queen Commercial
washer that will last me 25 years for half the price of the $999.00 Maytag Neptune.
When I complained to my father about the noises in our family car he used to tell me,
turn on the radio.
Please remember to leave a rating before you go!
Thank you
Posted on Sep 28, 2008
duby1990
  • 367 Answers
SOURCE: Maytag Washer HAV2558AWW loud noise during spin cycle
Your maytag is really an amana and the bearings are bad. Yes it does cost a lot. If i were you i would buy another washer. Get a whirlpool. (whirlpool now owns maytag)
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: Maytag Neptune Series MAH5500BW loud noise during spin cycle.
very loud in spin cycle can mean a bad rear bearing, not something a homeowner would want to try to replace, parts would exceed 6-7 hundered dollars. you may have some extended part warr through the manufacture. still probly gonna be a 5 hundred when the labor is added in
Posted on Dec 06, 2008
aasc
  • 1606 Answers
SOURCE: shreiking spin in rinse cycle
Your pump is probably what's causing the noise . Usually the bearing starting to go out , causing the pump to freeze up , begins with this noise .
Posted on Oct 11, 2009
Testimonial: "Thought it might be a belt rather than the pump."
I replaced the brake, brake stator, and snubber ring on a Maytag MAV7650AWW top load washer. Now, when it is running it makes a loud grinding or humming noise. Nothing appears to be leaking. I ran it with...
most likely a bad water pump/remove belt and turn pump by hand , you'll be able to tell if its the pump by the way it turns,should turn smoothly in both directions
Mar 06, 2010 | Maytag Atlantis MAV7551 Top Load Washer
May be the bearing in your direct drive shaft. If washer is a belt drive, the belt could be frayed
Nov 17, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Make loud noise during spin cycle
Washer may be out of balance, Move closes around in washer and restart
Oct 24, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis 7700 - Noisy agitation/wash cycle from motor
Your drive motor may be fine. Check the water pump that is located in the back behind the small metal door on the left bottom corner and see if thats where your noise/water is coming from. These extraction pumps have bearings casing that gets mangled and locked up. Look right above the flywheel that the belt rides on in the W-pump.
May 09, 2009 | Maytag Atlantis MAV6451 Top Load Washer
Grinding Noise during spin and wash cycles but it' working ok
#1 issue have had with those as a repairman is the pump.the spot welds break and the pump rubs metal to metal also the belt can wear and flap.you can get somthing in the inner tub in those little holes[ie..nail]and when the tub moves it drags.to look at pump,belt motor pulley.tilt washer back .rest on wall and you can inspect all from there.God bless,tom
Jan 03, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Grouling noise in the spin cycle
First, check the belt (located in the bottom of the unit) and if it shows signs of wear (black dust) and shiny sides on belt and black marks on the motor, transmission, and water pump pulleys - replace the belt. The motor is spring loaded and acts as the tensioner up to a point of too much wear on the belt.
You will need to tilt the washer about 45 degrees and prop it to keep it from going all the way over (just makes it more difficult to right it later). Pop the belt off by rotating it while pulling the belt off the edge of the transmission (larger) pulley. Again, the motor pulley is spring loaded and will flex appropriately. Reverse the process with installation of a new (exact replacement part number).
If this doesn't fix the problem, you may have to call the Maytag Repairman. They would have replaced the belt anyway and would probably charge $50 + for the belt and installation.
Dec 21, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Nov 16, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Loud squeal during wash and spin cycles, maytag atlantis washer
Squealing normal occurs due to belt slippage. I would check your belts (look for cracks. Check the belt tension as well, most washers have an adjustment, normally on the motor that allows you to increase the tension of the belt.
If part of a belt gets torn and it is long enough, it will hit any part of the washing machine within range and make a clicking noise at every revolution of the motor.
I am pretty sure you need new belts. You should be able to remove a few screws and open the back cover. Between the pulleys there is a tensioner...loosen that so you can remove the belt easily. replace it with a new belt and adjust the tension.
hope this helps
Feb 23, 2008 | Washing Machines
Loud noise during spin cycle
this is my experience repairing the maytag washer Atlantis mav series 9750 aww, I had to replace the spin bearing since it was making a jet engine noise when it was spinning out the water. its not an easy job for my 1st time taking this machine apart, you literally take it all apart to get to this bearing, but now I can show how to do it with pictures making it easier for you to do it. even if you have to replace something other than the spin bearing, this how to tutorial will show you how to get to most of the parts in this machine
tutorial located here tutorial located here https://sites.google.com/site/maytagwasherrepair/maytag-washer-repair
Jan 02, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Maytag Atlantis MAV7551 Top Load Washer Logo
121 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
