Question about EliteGroup KV2 Extreme Motherboard
I am trying to get the SATA drives to boot up, the system does power up but it stays on the display screen and does not run the POST. I have checked all the bios settings and every thing is set correct. I am trying to use a wester digital 320GB Sata drive, has any one had this problem?
  • 238 Answers
SOURCE: Biostar P4M800-M7A Motherboard SATA RaiD Mirror Array As C boot Disk
hi, you need not have to upgrade the BIOS,, set the SATA HD on the IDE channel in the BIOS, or what options r avilable for SATA controller, if it is set to RAID, you will need a raid utility to format the SATA, or it wont shoe in windows, let ,e know
Posted on Dec 17, 2007
map9966
  • 2351 Answers
SOURCE: SATA drive not detected in BIOS and windows does not boot up
PrashantP, your board does not support SATAII. As mentioned by Asus:
Qusetion: Why can't my SATA-II hard drive be detected on VIA VT8237 chipset based motherboard?
Answer:
This may be caused by the fact that VIA 8237/8237R South-bridge chipsets does not provide upward compatibility with SATA-II hard disk drives at 300 MB/s. These HDDs may not even be detected at POST. To install a SATA-II hard drive, users need to lock the drive at 150 MB/s data transfer rate by HDD jumper setting. Please refer to the following jumper setting from HDDs manufacturers or visit their website for latest updates.
Even if you updated your bios it will have no effect.
This is also why your SATA drive is not being seen by the bios.
Anymore questions PrashantP? Just post back here.
please vote...
Posted on Feb 23, 2008
map9966
  • 2351 Answers
SOURCE: SATA drive stops or hangs . . .
Hi fadetoal, it's not you or you're drives. It's the onboard SATA controller. When a board is SATA compatible & the bios does not see the SATA drive (List the SATA drive), the fault is the board. You're board goes one farther than normal. Bios see's the drive but can't run. All you're going to do is pull you're hair out trying to get the board stable. Hope its still in warranty.
RMA time: http://www.ecsusa.com/ECSWebSite/Support/rmamb.aspx?MenuID=25&LanID=9
Best of luck!
Mike
Posted on May 03, 2008
frcs68
  • 1605 Answers
SOURCE: Won't boot from 500GB SATA drive
Windows XP original support up to 137GB
Windows XP sp1 support up to 250GB
Windows XP ps2,3 have not change.
you have to enable 48 LBA in order for the system to recognized the drive.
the exact porcedure is list in the link ;
http://support.microsoft.com/default.aspx?scid=kb;en-us;303013
Posted on Nov 17, 2008
  • 67 Answers
SOURCE: Asus P5KPL SE & Sata, Bios "Not Detected Problem"..
The Asus bios won't show SATA devices.
However if you are using Windows XP with Service Pack 2 (or newer operating system then the devices should be detected. If this is not happening then enter the bios -- Storage Configuration -- Configuration Enhanced and set the IDE devices to compatible. This allows all drives to be "seen" and you should then be able to load an OS.
Posted on Jan 23, 2010
Asus p5n-e sli will no longer stay on for more then a few seconds
You go to AVIRA dot com and download the boot tool, or go to BITDEFENDER and run an online scan, you don't put in a new HDD just because you had a virus, it sounds like you had a problem and thought it was a virus.
Read you manual, plug in the Sata drive into Sata 1.
Do you mean BIOS post, if you don't even see the BIOS post, check your monitor with another PC.
There is only one correct power switch pin, a , + and - pin, how can you switch, there is no such thing as switching.
Dec 15, 2012 | ASUS P5N-E SLI Motherboard
I'm getting a POST error
Don't format the problem is in BIOS. Try setting defaults.
Nov 20, 2012 | Biostar A780L3G Motherboard
Dell Inspiron N5030 refuses to boot. When it is turned on, the ON LED light stays on for a minute & goes off. There is no display on the screen. But when it is plugged to A/C, it stays on for a while...
The first thing to check for is loose ram, battery, a loose hard drive or any loose cards.
Pop the cover off the bottom, reseat the ram battery and hard drive and try booting again.
If that does not work try booting off a copy of Puppy linux on a live CD. Puppy runs only in ram and will allow you to bypass a bad hard drive to get a system running. Puppy also has system testing tools that you can check your hard drive with.
Aug 15, 2011 | Dell Inspiron N5030 Notebook PC
I m unable to install xp on dell vostro 1015 with 2 gb ram and intel core 2 duo cpu (t6570) ( the laptop came with preinstalled windows 7 and i have also successfully installed red hat linux 5 server...
If you try to run XP setup without changing the BIOS SATA setting to ATA mode, setup will BSOD with an 0X0000007B error. Make sure the SATA setting in the BIOS is ATA...
you will get this error when you will be booting your system from CD and windows installation will be in first step.
to resolve it, go to BIOS setting-->change BIOS SATA setting to ATA mode--->apply changes-->insert windows CD and restart the system-->press f12--->nd boot from CD....hope u will be able to resolve it.
Oct 12, 2010 | Dell Vostro 1015 Laptop
How to fix no bootable device - insert boot disk and press any key
the harddrive might be loose. check that the IDE/Ribbon Cable, or SATA wires are secure into the back of the hard disk , and where the other end of the cable meets the motherboard.
next , make sure the bootable device order is correct. that it is indeed trying to boot of the hard drive. that is done in the BIOS. Press DEL, or F12 or whatever option (sometimes F2) is displayed on the screen at the very start of the powering on state. (this is called the POST screen).
If you access the BIOS screen from the POST (the black DOS screen before windows starts) look in the listing for Logical Boot Order, and ensure that the Hard Disk Drive is listed as one of the first in the order.
try that and see what happens.
because beyond that, you might have a dead hard drive, or the master boot record on your disk is corrupt, and either of those are bad results.
Jul 10, 2010 | Computers & Internet
Dell PowerEdge 1600sc server won't boot.
> black screen & flashing cursor ...
Damaged boot-record on the disk-drive???
Was it configured to try to boot from 'A:' ?
Disconnect the hard-drive & CD/DVD drives.
Put a diskette into the drive, and see if it tries to find a boot-record on the diskette.
If it tries, then it has P.O.S.T.'d correctly.
> no beep codes
When it worked, did it beep _once_ when P.O.S.T. completed?
Taking out the RAM _should_ cause some beep codes, i.e., "no RAM".
> anyone?
Replace the monitor?
Replace a dead video-card?
Or, add-in a video-card, and connect a monitor to it, leaving the original monitor connected to the original video-card. One of the two displays should show the P.O.S.T.
Jun 12, 2010 | Dell PowerEdge 1600...
When I boot up the computer, the screen has the p5l-vm 1394 logo and at the bottom it says "press delete to run setup, and press tab to display BIOS post message I tried restarting a couple of times and...
The system is currently not able to boot from your hard drive.
press delete key, then on the first screen check to see if the system has found your hard drive. If not, power off and make sure all cables are plugged correctly and hard drive has a power lead attached and retry.
Mar 30, 2010 | ASUS P5L-VM 1394 Motherboard
I have an Acer 5670 Laptop, I replaced the HDD with a new SATA drive and when I powered up the laptop, the Video card fan starts, the CD drive cycles once, the drive light flashes 3 times, then it stops....
Sounds like it. Try taking out the hard drive, disconnect all usb devices and anything attached, and try to run POST again...Being a laptop, there is not a whole lot else you can do if it won't POST. YOu can try swapping in some different RAM that is known to be good also.
Jan 13, 2010 | Acer Aspire 5670 Notebook
Computer will not boot to desktop
1. Unplug the SATA drive and see if you get a desktop then.
2. If so, then go to hardware/device and look for PCI sata card.
3. If it is listed, check the details, copy down and post here.
4. If it is not listed, see if it is listed under computer management/hardware/devices or in the "problem device" or "conflicts" tabs. Post any mention here.
5. While I wait for your reply/you wait for me to catch it, you should also try switching the card to another PCI slot. Sometimes, with new technology added to older boards, the slot ID is important.
Feb 23, 2008 | AOpen AK77-8XN Motherboard
EliteGroup KV2 Extreme Motherboard Logo
Top EliteGroup Computers & Internet Experts
David
David
Matthew Spark
Matthew Spark
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
