Question about GPS
I have a Polar Start PS3025 SH remote starter on my 2003 Sport Trac. The unit is coding that it is in "Tach Watch Lockout" I am wondering how to fix this problem? The user manual says I need to check the Tach source. I am not sure where this would be. A wiring scematic might be helpful. Any advice you can offer would be great!
  • 193 Answers
SOURCE: need owner or service manual 2003 jeep liberty sport 4x4
Ok go here to download the service & repair manual
http://manualspace.com/jeep-liberty-2003-service-and-repair-manual.htm
Posted on Jun 17, 2009
  • 9 Answers
SOURCE: Change the brakes on 2007 sport trac
it has front and rear disc brakes, disc brakes are very simple to change out. Most disc brakes have two bolts that hold them on, one on the bottom one on the top on the inside of the brake caliper, they may be an allen head, or just a bolt. Remove them counter-clockwise. After you remove the two bolts, lift up and away on the caliper and the whole assembly will come off. Once you pull the assembly off you will see the two pads, one of them is driven by a piston, the other one is fixed. Remove the fixed one, they just pop off (have little metal clips you may have to slide the pad off). Take a C-clamp or something comparable to squeeze with, place it on the back of the caliper and on the old pad thereby squeezing the cylinder back into the piston, once you squeeze the cylinder back into the piston, it will give you room needed for thicker new brake pads. Piston should retract with the c-clamp fairly easy, shouldn't be a whole lot of resistance. Remove c-clamp after you get it to retract and remove old pad. Put new pad on, just like you took the old ones off. All four are basically the same to change out, they all have two bolts holding them on. You pull those, get the pistons to retract and replace the worn pads, put them back on, line up holes, put bolts back in... and your good to go. When you get back in the car and turn the key on, you may have to pump the brakes a few times.
Posted on Nov 02, 2009
SOURCE: Ball joint replacement-2003 Ford Sport Trac
I have removed my lower right ball joint nut jacked up the truck by the lower control arm and used the pickle fork and it still will not seperate. what next?
Posted on Feb 06, 2010
  • 10865 Answers
SOURCE: 1997 Chevy Silverado Car Alarm w/remote Start
Hello m1..... Here is the link to this alarm manufacturer including manuals, etc. If this site does not answer all of your questions, click on their contact icon and speak directly with their technicians. http://www.xlsperformance.com/cars_alarm_starter.htm
Joe
Thanks for choosing Fixya!
Posted on Dec 24, 2010
SOURCE: Problem start about a week
Have you checked the polarity of the Generic unit. There will be a symbol on the GPS where the power is plugged in which will state whether the outer of the plug is positive or negative, make sure the symbol on the generic unit matches this.
Posted on Jan 29, 2011
How to fix my headlights
Search Results
    Explorer Headlight Problem and Interior Stuff - YouTube
    ? 10:53
    https://www.youtube.com/watch?v=f1j-H1dGT4o
    Jan 1, 2011 - Uploaded by justhes
    Explorer Headlight Problem and Interior Stuff ... Thank's to your movie I fix my car. .... 2001 Ford F150 Headlight Switch Replacement - Duration: 5:05. Jon Olson 10,273 views. 5:05. 2003 Ford F-150 4X4 Repair Part #3 The GEM Module ... EXCLUSIVE: 2016 Ford Explorer Sport with Mark Mills at Athens ...
    Replace 2001-2005 Ford Explorer Headlight / Bulb, How to ...
    ? 4:49
    https://www.youtube.com/watch?v=cQJrO0L_tSM
    Sep 16, 2013 - Uploaded by Go-Parts
    Replace 2001-2005 Ford Explorer Headlight / Bulb, How to Change Install ... How To Install Replace Headlight Ford Explorer Sport Trac 01-05 ...
    How To Install Replace Headlight Ford Explorer Sport Trac ...
    ? 4:28
    https://www.youtube.com/watch?v=NzMVcCsZ860
    May 11, 2010 - Uploaded by 1A Auto Parts
    How To Install Replace Headlight Ford Explorer Sport Trac 01-05 1AAuto.com .... I did this on my wifes 2003 Explorer only difference was the screw was a ... Replace 2001-2005 Ford Explorer Headlight / Bulb, How to Change ...
    2001 Ford F150 Headlight Switch Replacement - YouTube
    ? 5:05
    https://www.youtube.com/watch?v=l84h2PUHS0E
    Mar 1, 2014 - Uploaded by Jon Olson
    Headlamp Switch was purchased through Auto Parts Warehouse: ... to help me with my 2001 Ford Explorer Sport-HeadlightSwitch, but the .... Ford F150 Explorer 2000 2001 2002 Overhead Console Repair - Duration: 6:38.
Jan 10, 2016 | 2001 Ford Explorer Sport
My sport trac stopped running, lights very dim and clicking noise when you try to start it up, what could be wrong
sounds like a problem with battery // posible earthing/or charging have battery and altanator checked out could also be problem with starter solinoid if you get it sorted let me know please.
Aug 03, 2011 | 2003 Ford Explorer Sport Trac
2001 ford explorer sport trac wont start all the function turn on
check what the diagnosis machine will give if there is no data then check if the starter crank sensor is getting any power
Jul 26, 2010 | 2001 Ford Explorer Sport Trac
Remote Car Starter with tachless vehicle. (Tach Lock-out)
Did you read the requirements for your particular system? The reason I ask is most remote starters will not work on a vehicle with a manual transmission, because of thier need to have the clutch pedal depressed in order to engage the starter.
Apr 17, 2010 | 2003 Ford Focus
Won't start
Check the battery cables make sure they are clean and tight. Make sure the battery has at least 12V, new batteries sit on the shelf for months sometimes before they are purchased. If this yields no results, remove the starter and have it checked. If it checks bad, replace the starter.
May 16, 2009 | 2007 Ford Explorer Sport Trac
Remote starter wont work
just read over the tach learning procedures for this. Are you sure your hooked up to a good tach source. My notes show its the green wire at the coil. Check your connections and let me know if there good.
Feb 26, 2009 | DEI Python 1400XP Remote Start/Keyless...
Left tail light @ blinker out
check the bulb contacts for corrosion, also check inside the bulb holder
Oct 29, 2008 | 2003 Ford Explorer Sport Trac
GPS Logo
126 people viewed this question
Top GPS Experts
Are you a GPS Expert? Answer questions, earn points and help others
