Question about Sewing Machines
Machine not stitching
Hi, I have just bought the abovel sewing machine from a friend , I have given it a good clean and change the oil. I am trying to get it to stitch, every time I try to stitch the thread breaks, infact it is not stitching at all, the thread just breaks. I tried re threading it (from the manual) but everything fails, please help, I know it works, before I took it home it was just missing stitches, but now its doing nothing.
thanking you in advance
Regards
Maureen
maureen.bailey@hotmail.co.ukthe
  • Ms Pearl Jun 14, 2008
    Hi Richie -asg1,
    I tried your suggestion plus I adjusted the tension on the bobbin, which was too tight. The top thread is still breaks but not as much, however, the machine is still not stitching, it just about make a stitch about every 2-3cm. I am at a loss, tried everything. Any more suggestions?. please help
  • simeus1 Jul 05, 2008
    I have exactly the same problems, the thread breaks, it doesn't stitch at all. And the engine sound is too heavy.
    Genius:
  • 1,036 Answers
Hi there!
This is nearly always down to the top thread tension being too tight.
At some point before the stitch-arm, there should be a tension wheel or adjuster.
Back it waaaaaay off, and spread the plates to see if there is any trapped thread in there. Clean it out if there is.
Then rethread as normal. Tighten down the top tension wheel untill you feel it bite on the thread when you pull it through. About the same drag as pulling a teacup along a table is good.
Also make sure the bottom bobbin is in the right way around. I don't know why, but it does make a difference to the tension.
If this helps at all, rate as Fixya.
If not - contact me again and we'll try something else.
Thanks for posting.
Posted on Jun 14, 2008
  • Richard Perkins
    Richard Perkins Jun 14, 2008
    Top tension is still too tight.
    Is the thread too thick?
    Are you sure it is passing through the tensioner correctly?
    Try a test run of stitching. Is the thread pulled tight at the top, and baggy at the bottom?
    Is it a belt drive model to the bottom catch mechanism? of it is, the timing may be off.
    There is a timing mark on the outside of the spool assembly.
    This should be passing to the left just as the needle enters the footplate. If it isn't the timing needs setting up correctly.
    Hope this helps.
I have turned my dial to the zigzag option, yet it is still sewing a straight stitch. How can I fix this problem?
UPDATE: It appears that your machine is computerized. Probably best to take it for service. Oiling will most likely damage your machine and do nothing toward resolving the issue.
Please provide the make & model of your machine. If it is a mechanical machine, most likely the machine has seized so that the needle does not do the appropriate swing for zig-zag or decorative stitches. A good cleaning and oiling with fresh, good quality sewing machine oil will take care of a mechanical that is seized.
Will not zigzag or decorative stitches New to these newer plastic style...
Jul 31, 2016 | Sewing Machines
Will not zigzag or decorative stitches. New to these newer plastic style machines Always used older steel machines. This was given to me my by my sister who used it very little. Could cam be broken?
Hmm, I'm wondering if it has been cleaned and oiled recently. Older mechanicals require frequent TLC. Consult your owner's manual for cleaning and maintenance instructions:
Is your sewing machine mechanical (ie, not computerized)??? CAUTION--if your machine is computerized, do NOT proceed with the following suggestions.
If it is mechanical, have you cleaned and oiled your machine recently? Most mechanical sewing machine failures are because they have not been adequately and routinely oiled, the old oil has solidified and frozen the mechanics. I recommend Bernina oil or liquid Tri-Flow Synthetic Lube (or similar good quality sewing machine oil) for mechanical machines--do NOT use 3-in-1, cooking oil, WD-40, or the sewing machine oil from your grandmother's sewing basket. (I am not associated with any Bernina dealer.)
If it is in fact frozen, pick up a bottle of liquid Tri-Flow Synthetic Oil at the hardware store. Oil one or two drops in every oil hole (see your manual) and also every place where metal rubs on metal. But DO NOT oil any plastic gears, rubber, or belts. If it is still stiff or frozen, direct a hot handheld hair dryer into the top and bottom mechanism of your machine. See if that loosens it up. You may have to repeat.
Once your machine is working again, place a drop or two of good sewing machine oil as directed above. Be sure to use a small brush to clean the lint and dirt out of your machine, especially around the feed dogs and bobbin area. (Caution: Compressed air will sometimes force the dirt and lint into areas that cannot be cleaned.) And continue to use good quality sewing machine oil to keep it running. Recommendation: every time you change a bobbin, after 8 hours of sewing, or every six months if it is not in regular use.
Dec 30, 2015 | Singer 6038 Mechanical Sewing Machine
Cannot change the stitch length on this machine.
See the suggested answers for your question. If it is a mechanical machine, the oil has probably solidified and is not allowing you to change the stitch length selector.
Something you might try is opening the machine and directing hot air from a handheld hairdryer into the internal mechanism concentrating on the location of the stitch length selector. This may help loosen it up.
Consult your owner's manual and follow the instructions for cleaning and oiling your machine. Use ONLY fresh good quality sewing machine oil and apply only 1-2 drops each spot.
Dec 19, 2015 | Sewing Machines
Stitch Selector will not change. How to get it unstuck?
Is it a mechanical (NOT computerized) machine? If so, your machine probably hasn't been cleaned and oiled and the selector mechanics are stuck. Consult your owner's manual, clean and oil as directed using only good quality sewing machine oil and apply only 1-2 drops of oil each place.
Try this ONLY IF IT IS A MECHANICAL MACHINE: gently try to move the selector bar and see where things should move and apply a drop of oil. Then direct hot air from a handheld hairdryer into the mechanics and see if that helps free things up. You may have to repeat multiple times.
Once it is working again, clean and oil every time you change a bobbin, every 8 hours of constant sewing, or every 6 months if not in regular use.
Sep 17, 2015 | Sewing Machines
Husqvarna prisma 980
since the sewing machine was given to you, it might be a good idea to have the sewing machine serviced to see if there is a problem with the reverse and stitch setting.
Aug 14, 2013 | Sewing Machines
Does two stitches and stops
have you tried changing the needle?
sometime when a machine will not stitch, the machine could be out of time
& you'd have to take it to a sewing machine shop to have it retimed
Apr 29, 2012 | Singer Izek Computerized Sewing Machine
When trying to change to the other sewing stitches the cams will not the the selector pass
doesn't sound like he tried real hard, my suggestion is to find a sewing machine shop that will take the machine apart & find out why the selector doesn't move, it's possibly a worn or loose or broken part, & the repair man is suppose to open the machine & find out what's wrong.
Mar 01, 2012 | Bernina Sewing Machines
Old style 830... having trouble doing automatic stitches
Take the machine to an authorized Bernina dealer for service - make sure to fill out the service slip with any problems you are having.
Mar 05, 2010 | Bernina Activa 130
How do i stop juki ddl from top skipping stitches?
Hi. Skipped stitches are usually caused by a mismatch in your thread and needle. Wrong thread type, wrong needle size, or even old thread can cause skipped stitches. If all else fails, change the needle. If that doesn't work, clean the machine. Sometimes just getting rid of all the lint and giving her a good oiling does a world of good.
Let me know if this works.
Robbie
Jan 10, 2010 | Juki HZL-E80 Computerized Sewing Machine
Where to oil and what kind of stitches can it do.
I found my answer by going to the dealer here and asking questions. They were very helpful and friendly. Said that if I need any more help to let them know. I bought a Bernina from them about a year ago. I really like it.
Sep 28, 2008 | Baby Lock Imagine
Sewing Machines Logo
157 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
