Question about ASUS Computers & Internet
I have an asus cm1630. I want to install a program. Where do I put the cd? There is an optical drive for music, etc and an expansion bay, which does not open.
  • ASUS Master
  • 11,800 Answers
The cd goes in the cd unit, aka optical unit.
Posted on Nov 05, 2010
How do I insert CD in computer? It doesn"t seem to have an open slot.
If there is no "Open" button for the drive then normally they are opened by pushing on the DVD/CD tray itself momentarily. It only needs a short positive push and the drive tray should slide out.
Dec 28, 2014 | Acer Aspire Computers & Internet
Asus k55a-rbr6 Cd Drive not recognized in Devices and Printers, will not run any CD.
The Asus K55A-RBR6 optical drive uses the Windows built-in driver. The drive may have failed or it could have a power or cable issue. To check for a power issue, try ejecting the optical drive by pushing the disc tray into the computer. If the drive tray ejects and retracts, it has power.
First, go to the Device Manager and check if there are any driver issues identified by Windows. (Click Start > Control Panel (in the right hand column. Click on either System and Security > System or Hardware and Devices and then select the Device Manager. Expand the section for DVD/CD-ROM drives and look for a yellow triangle with an exclamation point or a red triangle with an x. Try to uninstall the driver and then reboot the machine. Windows will try to restore the driver. (You should alsocheck Windows Update for any optional drivers. Start > Control Panel > System > Windows Update.)
Check that you have installed the latest available BIOS upgrade (407), from http://www.asus.com/Notebooks_Ultrabooks/K55A/#support .
The laptop uses a SATA slimline internal optical drive. The drive needs a power connector from the internal power supply and a SATA cable connected to the motherboard. You can access these if you disassemble the laptop. You may want to try just replacing the drive (~$25 at many vendors). If the second drive doesn't work, then try replacing the SATA cable and make sure it's well seated at the motherboard and the optical drive. There aren't extra power cables in most laptops but you should check for damage. Alternatively, get an external USB optical drive to replace the internal drive.
I hope this helps.
Nov 15, 2013 | ASUS Computers & Internet
When I go to save a mixed down program to a blank CD-R and follow the usual steps to do so, (select save program, then select IDE, then select CD-DA) it takes me to a screen that says from top to bot
pull the cd drive look at the back smell it make sure its not burning up easy to check on the back of laptop there is a pic of a disk unscrew that screw gently tug or pry it out with laptop off not in hibernation mode pull it out look at the back of cd drive and look inside the cd bay with flash light look for darkness on connectors smell inside cd bay try that 1st making sure it is working correctly and power up laptop witout cd drive connected let it see it without it in then after boot shut down put cd drive back in and restart ok try that
Jan 17, 2013 | Computers & Internet
Is it possible to remove the top optical drive bay's front panel and fit the optical drive without it?
The front panel drive panel needs to be removed so you can install an optical drive. There may be a metal panel behind the plastic front panel, if so this will need to be removed so the optical drive can be inserted into the drive bay.
Nov 12, 2011 | ASUS TA-891 ATX Mid-Tower Case
Can I install a none sata ide hard drive in a Asus Cm1630-06
lilpolak
Most motherboards have one IDE port on this that you can run 2 IDE devices off of. Note the main reason for this IDE port is not all ROM drives are SATA yet but you can run hard drives off this port as well.
Let me know if you have any more questions or problems
Issken
http://www.fixya.com/users/issken
Sep 29, 2011 | ASUS Essentio Desktop / AMD Athlon II X2...
How to install GH22nS50 Rewriter into my computer
These are the steps for installing your optical drive:
1. Remove both side covers on your PC case. 2. Locate a free 5.25 in bay on your desktop computer. This is usually located near the front/top part of a PC ATX case. 3. Remove the front/external cover for your chosen drive bay. This cover is usually not screwed in. You just have to pry it open. 4. Screw in the optical drive to the drive bay. You need 4 screws, 2 on each side. 5. Power connection : Locate a SATA power connector from your power supply and plug this into your new optical drive. The SATA power connector looks like this rjbautista.jpg
6. Data Connection - Locate the SATA ports on your motherboard which looks like this rjbautista_0.jpg
You need to plug in a SATA cable from your motherboard to your new optical drive
SATA power and data ports on the back of the optical drive
7. That's it! Your new optical drive should now work. it's plug n Play so you don't need to install any drivers for this device.
Mar 21, 2011 | LG RETAILSUPER MULTI DVD REWRITER DVD-RAM...
Select bay error
Try restarting the notebook and press F2 to get to the BIOS and look if the optical drive was detected, if not place the WIndows instalation disc into the drive then reboot the laptop and press F12 then chose to boot from CD, then press any key to start the instalation of Windows. Agree by pressing F8 then when you are asked what would you like to do press install Windows, on the next screen you will be asked again what action would you like to take, chose to repair the existing windows, and follow the onscreen instructions, this will not delete any files on your laptop but will infact repair windows. By chosing to install new windows, at the start the system will load the default drivers which infact will reisntall the CD /optical drives. Also before you try all this you could just go to Device Manger and check if any drivers are market with red "X" or the yellow exclamation mark under the DVD.CD drives. This should resolve the issue as it seems to be that windows is corrupted and cannot load the optical drives or detect them. Good luck
Apr 29, 2010 | Toshiba Tecra S3 Notebook
Does this computer Eee Top come with a disc player installed?
Yes the ASUS Eee Top has a built in optical drive that can both read and write CDs and DVDs.
Dec 27, 2009 | ASUS Computers & Internet
I got a really bad virus on my eee PC how do i format the netbook to its original settin. i cant even format the drive because the virus wont let me. please help.
Hello
Thank you for using
FixYa for your problem
google the programs
download and run combofix.exe
Download & run malwarebytes
Download & run Superantispyware
download and run spybot - search and destroy
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Nov 30, 2009 | ASUS Eee 4G Notebook
As for the suggestions given by experts, i want to know whether installing service pack 2 cd, how can we upgrade from service pack 1...coz from start -> WindowsUpdate is not working..
If you have service pack 2 Cd, just put it in your optical (CD/DVD) drive. If service pack 2 does not auto start, use Windows Explorer, locate your optical drive and explore it for a program named "Setup.exe". When you double click on this program, service pack should start the install.
Jun 08, 2009 | Computers & Internet
Computers & Internet Logo
139 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
