Question about Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish
I need to buy a blade bracket where can i get one
  • 44 Answers
Home Depot or Lowes has a big selection . Thats were I go alot of those are universal. Hope this helps.
Posted on Nov 06, 2010
I need the blade bracket
If you find them you need to buy a whole set ( 4 or 5 ). Probably not worth fixing!
Jul 09, 2015 | Aloha Housewares (93645) Ceiling Fan
How can I get a bracket that holds the leaf blade????. #ST306-002-22
  1. Check and see if bracket is broken
  2. If not then see if screw is tight enough if not tighten more
Jul 05, 2014 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Fan blade bracket
Save yourself some money & buy a fan that gives good airflow. Where did you buy that, Kmart?
May 07, 2014 | Aloha Housewares (93645) Ceiling Fan
Balance blade rotor broke
You can get a new balance beam on Ebay for a few pounds just search Air hog. Just check the linkages are ok before you order so you can buy them as well if needed. They are actually called a " Flybar"
HTH
Jan 03, 2014 | Air Hogs Hover Assault Vehicle
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
My celing fan is wobbling, how do i fix it?
Ceiling fans need to have balanced blades if they are not to wobble. At it's simplest this means that all blades should weigh the same, and they should all be exactly the same shape. But it's not quite as simple as that, as the brackets that each blade is secured to also have to be balanced.
In practice, good quality fans will have the blades carefully balanced by the factory, and on better quality models the blades will be matched to individual mounting brackets in which case there will be markings to identify which bracket goes with which blade (and also to identify where each bracket mounts to the motor).
Cheap fans (almost anything under £130) will not be carefully balanced and so whether they wobble or not is a matter of pot-luck.
To try and cure your fault, first remove and accurately weigh each blade complete with the brackets attached. You can buy strips of self-adhesive balancing lead to add a gram at a time to the upper side of the tip of any blade which is under weight. Note that if any blades are damaged, you must repair the damage before weighing. If any blades are twisted along their length (normally they're simple flat paddles set at identical pitch angles by the way the brackets are shaped) then they must be counter-twisted to match the other blades. Also, check for manufacturer markings to see whether there are any suggestions as to which blade goes with which bracket and whether the brackets are marked to match a particular mounting point on the motor (usually simply by matching coloured paint blobs).
Once you have checked all that you can, see if the wobble remains. If it does you should try swapping the brackets around on the motor: by doing so you'll normally remove the wobble altogether or will considerably reduce it. You might not achieve perfect balance, but you may get to a point where the resonances which cause the wobble offset each other.
A well-balanced fan will not wobble appreciably at any speed, a less well-balanced example might still wobble at some speeds and not others.
I hope that I've helped and that you will take a moment to rate my answer. If there's any part of my reply which is unclear to you then add a comment and I shall try to assist you further when I'm next online.
Jul 11, 2010 | Dryers
Although this is posted in completely the wrong category, I shall try to assist you.
Jul 11, 2010 | Meade Capture View Binoculars
Oscillating bracket broke, need to replace
Please suggest where I can buy a new blade for 16' airworks pedestal oscillating fan?
Thanks... VladF
Email frolovvl@sympatico.ca
Phone (home) 905-891-5741
Phone (cell) 416-471-1326
Aug 31, 2009 | Optimus F-1660 Fan
Mounting snow blade to lawn tractor
It attaches the the front of the tractor. Similar to a plow to a truck. If you don't have the brackets, you will need those, or make your own. You can see a picture of the brackets if you go to sears.com. Click on the PartsDirect link at the top, and enter the blade model number.
Sep 29, 2008 | Garden
Hampton Bay 52 In. Cameron II Plus Ceiling Fan, Brushed Steel & Cobalt Blue Finish Logo
78 people viewed this question
Top Hampton Bay Dryers Experts
Donald Klecher
Donald Klecher
Level 1 Expert
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
