Question about Consew Sewing Machines
The feed dogs will not move and the hook will not pick up the thread. It is a Consew 369RB-1.
    President:
  • 2,777 Answers
Did this sewing used to work just fine? Or is this a new unit and it has not worked since you got it? If the feed dogs are not moving then something must be jammed up in there.. can you see any indication of whats stopping them from moving?
Please give me a bit more detail here about how it got to be this way and I can help you out.
Thanks, let me know if you have any questions or concerns, just reply to my answer here and I will be right back with you.
Tim
Posted on Nov 05, 2010
I can not figure out how to raise the feed dog. the needle will not pick up the bobbin thread. Are these connected? thanks, Pauline paulinemccracken@gmail.com
Possibly. First put in a NEW needle. Then check when you rotate the handwheel to see if the hook is rotating around the bobbin case. If not, then probably the timing belt has come off. If the hook is rotating around the bobbin case and the feed dogs are not coming up, then check that you have the feed dogs engaged. Another sinario is that the timing is off just enough to not pick up the bobbin thread. Check for these symptoms first, and then well go from there.
Apr 26, 2011 | Singer 7462 Mechanical Sewing Machine
I need help in adjusting the feed dogs, they messed up when I adjusted the timing for the needle and bobbin.
When the sewing machine is properly timed, all the parts work together in a seamless flow of coordination. The needle moves from it highest point down toward the needle plate. The feed dogs reach the farthest point toward the back of the sewing machine. The feed dogs drop under the needle plate. This is just before the needle point reaches the needle plate. The needle continues to move down dragging the upper thread under the needle plate. It proceeds toward its lowest point.
The needle begins its rise back up. A loop of thread forms along the back of the needle. A special cut out on the back of the needle to accommodate this loop is called the scarf. The sewing machine hook slides behind the needle. The point of the hook slides into the thread loop and pulls the thread around the bobbin. The bobbin thread and upper thread wrap together. The needle and hook proceed through their actions under the needle plate. The feed dogs move under the needle plate from back to front.
The needle proceeds to rise again up out of the bobbin area exiting the needle plate. At the same time the feed dogs rise up out from under the needle plate. They begin to move from front to back as the needle continues to rise.
The thread from the bobbin flows through a bobbin tensioner providing resistance to the thread as it is drawn up by the upper thread knot. The upper thread is also under tension. This comes from the upper tension, thread guides, tension spring, and sewing machine take up lever.
The thread from top and bobbin grow increasingly tighter until they form a locked stitch in the middle of the fabric. This process is repeated for every stitch.
How do you adjust sewing machine timing?
The needle, hook, and feed dogs must move in harmony. If they fail to do so, the machine will not perform as expected. When the hook is just slightly out of time with the needle, you will notice skipped stitches. This may begin on only one side of the zig zag stitch or intermittently. If the timing is just a bit more out of sync, stitch formation will become impossible.
If the feed dog timing is out of sync, the fabric will not move through the machine as expected. Threads may bunch up or the fabric may just not move.
As you can see, timing is everything.
click on this link directly
http://www.fixsewingmachines.com/How-to-Adjust-Sewing-Machine-Timing.html
This will help. Thanks please keepupdated.please do rate the solution positively .thank you for using fixya
Jan 29, 2010 | Sewing Machines
I need a downloadable Operating Manual for the Consew 206RB-5
I can not get the top thread to pick up the bobbin thread on a machine I have just bought .It was sewing fine and then the bobbin ran out. I have tried every which way but nothing works which way should the bobbin be winding
Apr 08, 2009 | Consew 206RB
Thread loops
Proper set of bobbins and tension set up vs. fabrics will sew you satified.Also incude regular maintenance cleaning of the feeds dogs with a brus,also the shuttle assembly need sometime to clean.Some threads and fabrics chips accumulates in the feed dogs and shuttles assembly.In setting up thread bobbins the thread should be clockwise direction as you pull out on slot coming out to the bobbins (as you shown in my inserted image manual).The loop thread should be propely in the sequence position same like in the image refer to it.If you use cotton/ polyester fabric in the begining of trial set tension dial to No.3 and stich to No. 8 to 12 any convenient to you Use needle No. 14 .Posible make a record if you are sewing different types of fabric mostly silk fabric is hard to sew adjusting to lower stich can posible sew satisfactory.
Mar 10, 2009 | Consew 206RB
Thread braking
Check the condition of the top pressure discs and the bobbin case tension. Check for wear in the hook - is the bobbin case seated correctly? Check the tension spring in the bobbin case. I doubt timing has anything to do with the problem. Unless the hook's picking up the top thread a little late, thereby "spearing" the thread. The hook could be catching the thread loop too late. Sounds to me like there's a parts or a small adjustment problem. You don't mention thread or needle size. That's another area of concern at times.
May 22, 2008 | Consew 226R-1
Thread jammed around bobbin case holder....can't get loose
lol...kinda jammed together but i kinda understand, your on the right track but if you are unsure i would take it to a repair shop,
dont mess around that area because you can throw the timing off, i would need more information to where the thread is actually hung up, send pic if u can
Jan 20, 2008 | Consew 206RB
Breaking thread
1. Make sure you are using the correct needle and thread for type of fabric and it is installed correctly. Make sure bobbin is threaded evenly. 2. Tread path - make sure the machine is correctly threaded. Then, with your finger, feel for burrs, nicks or roughness on any metal parts that contact the thread. Open the slide plate, remove the bobbin and inspect the bobbin case and hook. Remove the needle plate and examine the needle hole. Sand any rough areas with fine emery paper and blow away grit. If burrs or nicks remain on the needle, presser foot, needle plate or bobbin case, replace them with exact replacement parts, if they remain on the thread guides, take-up lever, bobbin hook or tension regulator, take the machine for professional service. 3. Loosen thread tension by adjusting tension dial. 4. Clean feed dog, bobbin case, and tension discs. Unplug the machine. Use a small, stiff brush to wipe dirt and lint off the machine head and the needle bar area. Raise the presser foot and the needle to the highest position, open slide plate and remove the bobbin and needle plate. brush away dirt and lint from the feed dogs and bobbin case and remove any tangled thread with your fingers. Use a soft cloth to clean between the tension disc on the tension regulator. 5. Also check tension on presser foot
Dec 31, 2007 | Consew 206RB
Sewing Machines Logo
69 people viewed this question
Top Consew Sewing Machines Experts
TCHNICAL SUPPORT FOR...
Irene Tulloch
Tally Girl
Tally Girl
Are you a Consew Sewing Machine Expert? Answer questions, earn points and help others
