Question about Targus USB Ultra Mini Keypad Keyboard PAUK10U
I have a neutac key pad and I am not sure how to get the secondary keys to work and also the minus key does not work and same with the triple zero key it does not work either the model # is k0061
  • RAYLEE Nov 05, 2010
    figured out the secondary keys but still can't get the minus or triple zero keys to work
Hi - I need to phone US with prefix +1, but there's no PLUS sign on my phone. What can I press instead please. Phone is iDECT
Hi Jackie, The + symbol is on the number zero "0", When you key it into your key pad you need to press zero and hold it down until the + key is on the key pad... Should take less than 5 seconds.... CHEERS.
Mar 30, 2016 | Computers & Internet
I can't get rid of the zero in front of the minus, add, multiply and devide sign. how do i get rid of it?
Are you entering any number before pressing the minus, add, multiply, or divide key? Those operations require two numbers; if you don't supply the first one then the calculator will supply the previous answer, which was zero.
For example, to add 2 and 3, press 2 + 3 = and you'll see 5. Now to add 4 to that, press + and the calculator will automatically supply the 5. Press 4 = and you'll see 9.
Oct 08, 2013 | Sharp el-531x scientific calculator
Where is the underscore key on my laptop
The minus key (-) to the right of the zero key (0) at the top of yuor keyboard, is what you're looking for. If you hold down the Shift key and then press that Minus key you will create an underscore (_).
I really hope this helps, but if it does not, please post your laptop model name so I can better answer your question!
Dec 18, 2010 | Computers & Internet
Minus Key doesn't work. all other keys work fine.
Please define the "-" minus key. Are you talking about the PC's keyboard or a button on the printer's front panel.
Also, what is the make and model of the printer.
Don
Feb 27, 2010 | HP PSC 1210 All-In-One InkJet Printer
Hi, recently bought an Oki c710 printer (not the older c7100). I am looking for the engineer access password to reset the 'Replace Drum' message when a drum comes up for its use limit. We all know they...
Try this:
While printer is off, hold down plus "+" and minus "-" keys then power printer on and continue to hold the + and - keys until "System Maintenance" appears on the display (you will see "please wait", "initializing", "ram check" before it appears).
When System Maintenance appears press Enter. You will be prompted for a password. The default password is "000000" (six zeroes). [Use the minus key for quicker access to the zeroes and press enter twice after the last zero to enter the menu.]
Nov 13, 2009 | Oki Electric Industry OKI C710dn - - color...
My touch pad thing with play, pause, volume, stop etc. has stopped working. The blue lights on them arn't showing up either. Can anybody help please?
There is most proably a button on your keyboard that turns your touchpad on and off. Hunt around for that. Look for keys that have blue writing on the foward edge of the keys these usually indicate a secondary function for that key. You have to press the key that turn this secondary function on and off and then look for a key with blue writing that may have to do with your touchpad
Aug 07, 2009 | Computers & Internet
Outside garage door key pad will not function in very cold weathe
Yes, that is an issue.  My suggestion is to replace the outside keyless with a wired keyless (Domino GD-1).  This will get your batteries inside so they can stay warm.
Dec 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
How do you enter negative numbers on a TI-30X iis calculater?
On the bottom of the calculator near the zero and the enter key it has the symbol (-) that is a negative number symbol
Nov 22, 2008 | Texas Instruments TI-30XA Calculator
Primary and secondary mouse disabled
i think the buttons of the mouse pad are on press mode you should consult a technician for this
Oct 04, 2008 | Toshiba Satellite L45-S7423 Notebook
Ink waste absorber is full, what do i do!!!
1. To clean physical pads:
Open cover (as if replacing ink cartridge).
Locate waste ink pads, they are far right under cartridge slider.
Pry up waste ink pads (inky, might want to wear gloves).
Rinse pads in sink or with alcohol, dry.
Replace pads. Make sure pads are fully seated.
2. To reset waste ink counter:
Press Menu-Scan-Copy-Scan to enter service menu.
Use arrow keys to scroll to “Service menu counter access”.
Press OK.
Use arrow keys to scroll to “ABS-M DOT COUNT”
Press Copy.
Use arrow keys to reset count to zero.
Press OK.
Press Stop/Reset.
Mar 15, 2008 | Canon PIXMA MP130 All-In-One InkJet...
Targus USB Ultra Mini Keypad Keyboard PAUK10U Logo
112 people viewed this question
Top Targus Computers & Internet Experts
steve morris
steve morris
dhnguyen
Are you a Targus Computer and Internet Expert? Answer questions, earn points and help others
