Question about Dishwashers
Is there a general reset code for this model? Problem seems to be that it pumps out,then fills thendoesnt advance in the program.There is a clicking occasionally then it waits 5 mins then a short pump out again followed by a long pump and refil Just lacking the actual wash..+no spray
  • 1 more comment
  • Geoff Morrison Nov 06, 2010
    Hi There,
    It's an ASKO 3350
    The water seems to come in- I hear the fill
    There was no error code on the display either, However U2 has just appeared
    Just seems that the motor doesnt reverse into spray arm mode(wash)
    It does pump out to start with as well
    Is there a service manual for this model?
    I am an electrician myself- I just dont usually work on dishwashers
    I'm wondering if there's a list of codes..A service manual or something?
    Now I find the u2 code flashing on the pots cycle
    This doesnt appear on the other cycles
    Are there 2 water solenoids?
    I was thinking there was just the inlet solenoid- there may be a problem with the solenoid to the washpump if there's a second one...
    Just thinking
    BTW I downloaded the userguide, so I have some of the codes now
    I tried resetting the U2 Code by tilting the machine back..no go
    I havent checked the pan yet
    I'll need to find a Torx for the front panel screws
  • Dishwashers Master
  • 3,247 Answers
Please confirm if there is still a problem with the dishwasher. Are you expecting any further suggestions ? You should post a comment as soon as you find the torx screw driver and are able to investigate the component.
Posted on Nov 07, 2010
    President:
  • 1,891 Answers
If ther was a code i would need your model # to help you . but the ans is no . what i think is going on is the machine pumps out that is normal then it should fill / and it does not . so ck the water float in side the tank / lift it up and listen for the click if it clicks the ck the water valve as it may be bad . rember no water then no wash but it will still try to pump out ...mm hope this helps ..
Posted on Nov 06, 2010
Programs don't advance. The machine seems stuck in each mode, it will fill and wash but doesn't advance through the programs. I have to switch off and manually advance the dial to rinse, spin, drain etc
Try moving your drain hose to a different height.t may need lower than you have it. My washer did the same , Drain hose needs to be higher than the pump that drains the washer.
Aug 09, 2013 | Indesit W 123 Front Load Washer
LG FRONT LOAD 'WM2077' pumps water out as it's filling. What is wrong? How to fix?
Suspect that the main program controller unit is faulty as it seems to output to the wrong cycle so as to drain as it fills. You can remove the unit and check all the connections to the panel. Check the output to the drain pump and see if the voltage to the pump stops when the program is reset, if not there is short in the board.
Sep 04, 2012 | LG Washing Machines
When i go to my mail, can't read the list. It seems to be on top of each other.
clear cached and cookies;
Start>control panel>internet options> under General TAB>click clear cache and cookies/clear history/delete browsing history
short cut: open Internet explorer>tools>internet option>under General TAB>click clear cache and cookies/clear history/delete browsing history
you can also reset your browser in to it's default functionality: Start>control panel>internet options> under Advance TAB>click reset Interner browser
shortcut: open Internet explorer>tools>internet option>under Advance TAB>click reset Interner browser
Aug 18, 2011 | Yahoo Mail
Bosch SHE44C07UC/22 - FD8606 : pump does not run during wash cycle, but does run during empty cycle. timer works. fill works. empty works. relays are heard about 2 minutes into fill cycle. may be...
Hi 2ipnelson,
Very difficult to know for sure which part is not working.
It is best to run the dishwasher in testing / service mode to ascertain which component is not working.
I found a .pdf document that explains the whole process, it should also work for your SHE model.
The link: LINK - CLICK HERE
Follow the steps, and the culprit part should be diagnosed.
Hope this helps :-)
* If this solution helped you, please accept it
Jul 26, 2011 | Bosch 24 in. SHE44C05UC Stainless Steel...
My dishwasher wont turn on when start is pressed. It wont fill. We have checked all connections and it is plugged in. We got it to work about 5 times by using the reset code but it never would start to...
It seems that the control board is faulty as there is no reponse to the panel even with all checks. So if the power seems right , ther fault can be the program controller.
Please check the motor wiring, the pump and connections once again before the board can be changed.
Sep 28, 2010 | Dishwashers
Machine doesn't start washing process
mine fille up with water puttaht is a far as it getes
May 22, 2009 | AEG Washing Machines
Hyperlinks don't work in Outlook 2007
I have something for you to try:
  1. Click Start, point to Settings and then click Control Panel.
  2. Double-click to open Internet Options.
  3. On the Programs tab, ensure that Internet Explorer should check to see whether it is the default browser is enabled.
  4. Click Reset Web Settings.
  5. In the Reset Web Settings dialog box, click to clear the Also reset my home page check box.
  6. Click Yes, click OK, and then click OK again to apply the settings and close the dialog boxes.
  7. Click Start, and then click Run.
  8. In the Run dialog type regsvr32 urlmon.dll, and then click OK.
  9. Click OK to acknowledge the success of the Urlmon.dll registration.
Let me know if this fixes your issue.
Feb 04, 2009 | Microsoft Office Professional 2007 Full...
GE Profile washer won't spin cloths after wash or rinse cycle
My GE washer model number WLSR2000G3WW washes and pumps water out but will not spin...can someone help me to solve my problem PLEASE?
Jan 23, 2009 | GE WBSR3140DW Top Load Washer
Indesit washing machine wi101
I have the same issue, have just returned from a 9 month break and now the washer does the click thing, but if you open and close the door a few times and set to program 4 is seems to work after about 10 minutes! It was perfect when I left, not 18 months old either. Can see it being the timer either, maybe a pickup of some type not detecting a level? Peter
Feb 08, 2007 | Indesit WA 115 Front Load Washer
Dishwashers Logo
23 people viewed this question
Top Dishwashers Experts
