Question about Tricity Bendix AW1000W Front Load Washer
I have mislaid my manual. i am trying to clean the filter of my tricity bendix 1000rmp washing machine. I opened the small door at the bottom right of the machine and unscrewed the cap inside . now the cap will not closeproperly and is leaking water. what do I do please?
  • Tricity Bendix Master
  • 3,463 Answers
Make sure the filter and the housing are clean and that there is no grit or similar on the seal, if it still leaks, then you may have to fit a new filter and or seal.
Posted on Nov 05, 2010
How to remove filter on tricity bendix 1000 washing machine?
tricity bendix aw1001w eco shower washing machine ...
? 1:11
www.youtube.com/watch?v=lJZrGLfYdtQ
Aug 19, 2009 - Uploaded by whichwasher2007
my aunt's old tricity bendix. it says aw1000w on the front, but check ... How do you clean out mold in the ...
Sep 29, 2015 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1260W - drum won't turn - 5 beep error repeats
Washer motor control board failure is the likely problem, also check all connectors for signs of burning. Also test the washer motor.
Apr 24, 2017 | Tricity Bendix AW1260W Front Load Washer
Where is the filter on a AW1560W washing machine
There is a small 4 inch square door on the bottom right of the front of the machine. Press the right hand side of the door and it will pop open. Pull out the small drain hose, drain off any excess water, unscrew the corcular filter cover to extract it. Instructions and pictures can be found on page 17 of your user manual. If you do not have a manual, you can download one here:
http://www.usersmanualguide.com/tricity_bendix/washing_machine/aw850w
Please rate this solution
Jul 21, 2011 | Tricity Bendix AW850W Front Load Washer
The Washing Cycle has halted with water in the cylinder and "F04" flashing on the micro monitor in the control panel. I have mislaid my manual and request advice please
This error indicates an obstruction in the water pump. Tip machine back so you can fit a bowl under the bottom right hand side. Flip back cover at bottom right to reveal pump filter access - unscrew (quite a bit of water comes out so have the bowl ready).
Bottom right on the front of your machine is a small door that flips down.
Open this and you'll find a drain tube.
Drain the water off into a dish.
Then remove the filter and clean it out.
Good luck.
May 23, 2011 | Bosch Washing Machines
My bendix washing machine door does not open after wash cycle ha finished
  1. Is there still water in the machine when the wash cycle has finished? If so, the door doesn't open because there is still water in the machine. Try clearing the filter at the bottom of the machine, in the front. If this doesn't work, check that the drain hoses are cleared. If it still doesn't work, try replacing the drain pump.
  2. Is the "door" light still on? You may have a faulty door lock assembly, or your control board may be faulty.
Feb 27, 2011 | Tricity Bendix AW1400W Front Load Washer
Hiya, We have a tricity bendix 1000rpm cwd1010 & i'm having problems getting to the filter to clean it.I have opened the door on the bottom right of the machine & have attempted to unscrew the...
It will be something stuck in the filter that is preventing it coming out.
As you unscrew it try twisting it from side to side , and screwing it back in again, and keep on doing that, hopefully it will eventually come out.
Hope this helps.
Jan 12, 2010 | Tricity Bendix Washing Machines
Tricity Bendix
try opening the small front panel at the bottom right hand side of the machine unscrew the drain guard and check for any blockages
Sep 08, 2008 | Tricity Bendix AW1260W Front Load Washer
Tricity bendix aw1400w will not spin
We had a similar problem, where it washed okay but didn't spin and just 'beeped' with end light flashing. When the drum was empty it was not moving round very freely.
Try unplugging the machine from the electricity. Then take top off machine off so you can see the casing outside the drum. There's a small rubber tube on top. If you disconnect that you can look through into the drum. Try turning the drum round slowly while looking through the hole. We found a sock wedged in which we managed to pull out through the hole (not easy and don't expect the sock to come out in one piece).
It worked - and we've had to repeat the procedure a couple of times now. Think I must be putting too much in the machine in 1 go, although there's always space at the top.
Jan 22, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity bendix
Water stuck in th machine like what you said is not normal.First you need to drain the water by taking out the hose behind the machine which is into the wall. Plug off first before these jobs. Bring the hose to ground level, the water will run off. Bucket or whatever to collect. Re-fit pipe to correct level in standpipe carefully, without pushing in too deep. The pipe level is important; you can check, there is a water level mark behind machine. You need to clean out your outlet filter;(which is accessible thru the front bottom right side of machine, small push door, or plastic screw) this needs to be done periodically - according to your usage. If this does not solve your problem check out your outlet pump. Plug off the wall first before you do the jobs. The machine will not drain water if the outlet is clogged. For the pump, tubes, etc you hav to open up behind the machine. Be prepared for water to come flowing out.......
And don't forget to rate me pl, if the solution has worked......
Dec 08, 2007 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
216 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Charles T Nevin
Charles T Nevin
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
