Question about Hoover Vacuums
How do I install the belt in a Hoover dimension II vaccuum?
  • 1,673 Answers
Take off the bottom plate, then you can get to the brush roll and the belt. The belt goes around the brush roll and goes to the motor shaft. If you can't see the motor shaft, then you will have to take the top cover off to get to it.
Posted on Jun 17, 2008
How do I repair Hoover Windtunnel floor/carpet switch? Brush will not turn but belt is not broken. I believe setting was hard floors and son forced the switch when the vaccuum was running.
The lever that switches from carpet to hard floors may be broken if it was forced, remove the cover to gain access. Replace both belts too. They may be stretched or worn even though they look good.
Dec 31, 2016 | Vacuums
Hoover Dimension has no suction and it smells of something burning
pets in house? check all hose passages for "hairball" clog...and check the drivebelt that spins the brush...(some have an electric motor to spin the brush, thus no belt)
Nov 02, 2012 | Hoover Bag Paper Microfilter Dimension...
Bag is empty but it vaccuum still says bag needs to be checked?
you need to blow out the insides some how like with an air compresser
Mar 18, 2012 | Hoover U5227-930 Elite Upright Vacuum
I have an American Fare Model 2324 belt. Will it fit the Hoover Lagcay II...seems pretty tight
you can get a free belt from for your hoover just mention I would recommend using the propper belt which is 38528-040.
Jan 21, 2010 | Vacuums
The power drive belt of my hoover u3305-030 vacuum keeps falling off, what am I doing wrong?
One possible solution to your problem is you have the wrong size belt. Check your belt, it should have a letter on it, if it is old, it may be stretched out. Check in your owner's manual, near the belt area, or on the inside of any cover for the correct belt size(which is a letter). Be sure to check that you have the correct size and if not or if it is old, go to your local home depot($1.89+tax for Hoover Model belts) or any other store you know provides vaccuum belts, and purchase a replacement belt.
Hope this helps and please don't forget to rate
May 02, 2009 | Vacuums
My hoover upright has no suction, the brushes move but it doesn't pick anything up at all
Hi there...
I had the same problem. Checked for obstructions, cleaned the filters, etc.
 I took out the rubber belt and noticed that it was much more stretched than the newer black belt.   I replaced it, and it made a 100 percent improvement on the suction.
Your vaccuum should have come with a postcard that allows you to mail in belts for new ones. You'll get two new ones in the mail, and they are free for life.  Just keep mailing in the old broken or stretched out ones.
Hope that works!
Mar 17, 2009 | Hoover U5753-900 WindTunnel Bagless...
How do you change the belts on a hoover wind tunnel vaccuum
Flip the vacuum over push the pedal so the vacuum lays flat on the floor or table. Remove the four silver screws at all four corners of the brush area. Pull up on the plastic cover and remaove it. Lift the brush out towards you if this is a self propelled unit there will be two belts one will stretch one won't the non stretch belt rarely needs to be replaced and usually indicates another problem. Take a new stretch belt and loop it around the metal shaft and then the brush roll use two hands to push the brush back into position give it a spin to make sure everything is spinning freely then replace the cover. In the case of a self propelled model the stretch belt spans the metal shaft and one of the drive wheels. For belts,bags or questions visit
Aug 12, 2008 | Hoover Vacuums
How to install front wheel assembly on Hoover Bagless windtunnel vaccuum
There is a spot that sticks up on the holder for the wheels, the hole in the spring goes there, then it fits between the holder and the base asm.04f5295.jpg
Feb 24, 2008 | Hoover U5753-900 WindTunnel Bagless...
Replacing a belt on a dirt devil vaccuum
That metal rod is probably the motor shaft or pulley. On some of these, the open space between the shaft and top cover is very narrow. You just have to push thru th opening to around the shaft, then put it on the brush roll. Th belt will stretch enough to re-install the brush roll.
Jan 06, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Vacuums Logo
88 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
