FixYa.com
Tags:
Routers
Generic problem for all Routers
Can not use Internet with new Linksys rangeplus...
posted by npht on Jun 14, 2008
I'm using HighSpeed Internet of AT&T and the modem is 2WireGateway. Now I have 2 laptops Sony Vaio VGN - CR 220E and Dell Inspiron 1525, so I bought Linksys rangeplus wireless router to use Internet wirelessly. I run the CD to install into my laptop and then did all the steps correctly. The installation was completely successful, but I cound not use Internet. I had to use the old 2Wire GAteway modem to surf Internet but it is not wireless. What can I do now? Please show me. Thanks a lot.
Comment by npht, posted on Jun 14, 2008
The model number : WRT110
the 2wiregateway (4200-001047-001) RG2701
-HG-00
192.168.1.254
192.168.1.254
IPv4 IP Address : 192.168.1.100
IPv4 Default gateway: 192.168.1.254
Can you show me how to set up router to use 192.168.2.1??? THanks
yay! It works. Thank you very much.
I have two laptops.Now one laptop has to connect with the wireless routers all the time and the other can use Internet wirelessly.
So Is there any way that I can use Internet on both wirelessly?
Thanks.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Clarification Request
by antiochpc, posted on Jun 14, 2008
What is the IP address of the 2wire?
Best Solution
FixYa! (100)
antiochpc
Rank:Guru Guru
Rating: 87%, 301 votes
Okay chances are your 2wire's ip address is conflicting with your router's ip address. Set up your router to use 192.168.2.1. Save the settings then everything should work for you.
Comment by antiochpc, posted on Jun 14, 2008
The easiest way is to use your router's setup program. Or you can log in manually by typping the address of the router into your web browser, i.e. http://192.168.1.1 and supplying the default login information (usually admin / admin, but it should be in your documentation).
Rating Locked! (?) npht has rated this solution as FixYa!
This Problem Also Relates To: Motorola Wireless G Broadband Router (wr850g) 3Com OfficeConnect Router 3Com OfficeConnect Wireless 11g Cable/DSL Gateway Router (3crwe754g72-a-uk) 3Com OfficeConnect ISDN Lan Modem Router Actiontec (GS204AD9-02) Router (actiongs204ad9-02.) AOpen AOI-906 Router (90.18A10.906) Asante (99-00618-71) Router
Can you Help with these Routers problems?
2wire 2700HG-B Router (2700HGB)
HP wire less printer
My HP wire less printer was... Answer This...
Zonet ZSR1104WE Wireless Router
no cd installation
Hi, I had a Zonet 1104 at work... Answer This...
GreyFox 4-Port Internet Firewall Router...
portforwarding
i got this router... Answer This...
Linksys Wireless-G WRT54GS Router (e125894)
I can't access my router...
My D-Link DIR-615 wireless n... Answer This...
Intel Express 9510 Router
switch type used in india for...
Hi i'm facing a problem... Answer This...
Repair Service
Find Router Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
