Question about Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ 2.30GHz, 2GB DDR2, 320 SAT
Problem with my Acer Aspire m1100 E1402A.PC came with 2x1Gb RAM. I added 2x1GB RAM of other brand but same spec. Computer won't boot,no signal at monitor,no keyboard. Removed new RAM, computer OK. Reinstalled new RAM in DIMM 1&2 everything OK.Installed old RAM in DIMM 3&4 and no boot,no signal at monitor,no keyboard.Computer works with either set of RAM in DIMM 1&2 but dead with either set of RAM in DIMM 3&4.How do I fix? Tom.
  • 1 more comment
  • ridgvu51 Nov 06, 2010
    How can I tell which of the sockets is bad ? Can they be replaced? Is this work for a tech or would I be better off replacing with 2x2 GB.RAM?
    DIMM slots appear to be OK. I tried installing RAM in slot 4 (plus 1&2)and got distorted screen. RAM in all 4 slots gets me nothing. RAM in slots 1,2,&3 gets nothing. I think it is a software problem not a hardware problem.
    What you are saying is that I have to get memory from Acer only ,even though other memory has same specs.
  • 4,281 Answers
This problem is related to incompatibility between RAM memory. For that make sure all RAM has same frequency and same company. Always different frequency of RAM creates this problem. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Nov 06, 2010
  • 2,973 Answers
Most likely the motherboard does not take more than 1 Gb of RAM. If so then you will have to do with 1 GB only. The new RAM is fine as it works alone.
Posted on Nov 07, 2010
  • 10,319 Answers
The contacts in that port socket are not aligned straight or touching together at one terminal
Acer desktp internal ram installation needed
I'm a bit confused....did you have all four of these in the ACER and are trying to put the 2x1GB into the Emachine? And that the 2x1 GB wouldn't work in the Emachine but they did in the ACER and that the 2x512 Acer cards worked in the emachine?
If that is what happened here is my best guess. The ACER MOBO will support 533/667/800 MHZ DDR2 RAM. The Emachine will only support 533 RAM. Iys possible the 2x1GB are either 667 or 800 MHZ and are not compatible with the Emachine but will work in the ACER.
Jan 23, 2012 | E-Machines T5082 PC Desktop
Acer aspire m1100 desktop getting a no signal on monitor, how do I get my pc to open
My Acer Aspire M1100 would not boot and had no signal to the monitor. I thought the video card or motherboard had gone bad. I tinkered with it for over 2 years (yes I'm hardheaded) and finally realized the processor had worked itself loose. Reseated the processor and it works fine again. Hope this helps someone.
Jan 04, 2012 | Computers & Internet
What steps do i neeed to take for adding ram to aspire m1100?
1st open the machine
look for the RAM cards
if there is only one, remove it and read the type
buy exact same type RAM card of higher capacity say 512MB or 1GB
insert it into the other slot and switch on PC
Nov 29, 2010 | Acer Aspire M1100-B1300A Refurbished AMD...
2GB (2x1GB) Dell 184pin PC3200 DDR400 DIMM Memory Kit (p/n 311-3483). After I physically install the ram are there any software changes I have to do? Thanks Mario
No software changes to apply. After installing the RAM, boot the computer up. A DOS type screen will pop up stating "The amount of memory has been changed, hit F1 (I believe it is F1) to continue". Continue and you will be on your way to enjoying a much more productive computer!
PS Make sure the 2gb memory has been recognized by right clicking on My Computer and viewing the specs.
Hope this helps!
Mar 02, 2010 | Dell Dimension 3000 PC Desktop
Acer Aspire M1100 desktop will not boot or respond
sounds like a motherboard or HD problem, If you can try the HD in a different pc to see if it can be recognize, also don't forget to setup you pc to boot the HD first.
Jul 03, 2009 | Acer Computers & Internet
Aspire t180 memory problem
check, if you motherboard support 2GB, or else start windows in safe mode with 2GB.
Oct 17, 2008 | Acer Aspire™ T180 PC Desktop
Memory installation
bev,
all the DIM's must be of same type and same size to work, otherwise it creates problem, like no boot, boot with lowest memory etc.
There is no problem in your PC, its technical issue you can not use two ore more different type RAM at the same time in a motherborad.
Thanks
Iqbal
Apr 08, 2008 | Acer Aspire™ T180 PC Desktop
Apparent conflict between my wireless adapter and RAM
have you tried looking for an updated bios version for your motherboard?
Jan 05, 2008 | Computers & Internet
Acer Aspire M1100-U1402A Refurbished AMD Desktop PC - AMD Athlon X2 4400+ 2.30GHz, 2GB DDR2, 320 SAT  Logo
447 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
