Rethread the machine
check the top tension-usually 3 or 4 is good
change the needle & make sure it's inserted correctly (flat side to the back of machine)
some needles & thread do not work togeather--try this
Cut 6-8 inch piece of thread of the spool you are going to use for your project
Take the needle you are going to use for the project
& insert the thread thru the eye of the needle
& lift one end of the thread to a 45 degree angle
& if the needle is the right size for the thread it will slide down the thread
But if the needle hangs on the thread you need one size larger needle for the thread
also make sure the thread tail are 3-6 inches long & pulled behind the needle
