SOURCE: Adobe Audition 3 Not Sensing Mic
Check the input and output settings. Look in the preferences or settings menu for "i/o settings" or "i/o setup." You're going to set it from the default internal mic input to this one. It sounds like it may be that simple.
SOURCE: my behringer c1u doesn't have
First, I'll ask a question. Can you get any sound at all? If so, then you're getting the right amount of power, and your LED is broken. If not, then you've either got a problem with the USB port, the USB cable, or the mic itself.
If it's the port, you'll have to go to your computer's device manager and see if it brings up any errors with the USB.
If it's the cable, a new one can be purchased from Behringer.
If it's the mic, there might be a short somewhere inside, and a schematic, as well as someone who can solder, would be helpful.
Hope that helps!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/cameron_463100ffd54b591d
SOURCE: I have a Behringer Mic
How to Operate a Behringer C-1U
The Behringer C-1U is a USB condenser mic for recording individual instruments. A condenser microphone is a mic that uses vibrations produced by sound to change the distance of internal plates that produce signal. Condenser mics typically require an extra change, known as phantom power, to operate. Since the C-1U is USB powered, phantom power is not needed. The Behringer C-1U has a frequency response that favors sounds around the 10KHz range. This heightens the clarity of recorded signals due to the microphone's treble boost.
Things You'll Need:
* Computer with USB 2.0 port
* USB cable
* Recording software
Instructions
Turn on the computer. When the operating system loads, connect the microphone.
Install any necessary drivers for the C-1U. This will happen automatically when the device is connected.
Select the Behringer C-1U as an input source in any desired audio software. In Windows, click the "Volume" icon in the task bar to open the mixer. Select the C-1U as the primary input. On Macs, use the "Audio/MIDI Setup" in the "System Preferences" menu to select the C-1U as the primary input
Note: make sure you activate the phantom power on the mic. That's the only way to power up the microphone.
Have a nice day.
