Question about Toro Lawn Mower With Toro Power Tools
Toro self paced lawn mower works just fine going forward. Cannot pull mower backwards, wheels are stuck.
  • 143 Answers
Your cable might need renewing, it could be rusted or frayed where it connects to the gear lever,or the lever itself could be stuck. Try spraying it with W D 40. Check the gears inside the wheels, they might be stuck and need freeing and oiling. Stephen.
Posted on Nov 05, 2010
Wheels are locked when trying to push it forward with engine shut off.
There should be a release to disengage the drive system so you can push it when not running. On my Cub Cadet it is on the back above the hitch. It is a simple lever that I pull out and push up to disengage. Has to be something similar on the toro.
May 02, 2016 | Toro Lawn Mower. 22 in. Personal Pace with...
Toro timemaster is 3+ years old and doesn't self propel when you push the handle forward any longer.
Either the transmission is shot or the gears on the wheels that turn have been worn away;. They are plastic and do not last long nor take much abuse.
Apr 04, 2016 | Toro TimeMaster 30" 190cc Personal Pace...
Toro 20333 self propel. Doesn't engage. l
Is the tension spring gone? How is the cable? Usually there is a spring at the end of the cable in which when you pull back on the bar with your hands, this tightens the belt so that it engages with the engine allowing the wheels to turn.
Oct 06, 2015 | Toro 20332 22" Personal Pace Walk Lawn...
I have a Toro mower made in 5/09 self propel system it grinds when you pull it in reverse. The selp propel is not working. The belt is on. and it seems to be only the left rear wheel? The cable is not...
Yes it is the transmission. A Mower shop will charge you about $225 to fix.. I order parts online and fixed mine for $90. Transmission consist of 3 gears which turns the rear wheels to self-propel.
Jul 21, 2014 | Toro Lawn Mower. 22 in. Personal Pace with...
Lawn boy self propelled mower won't move backwards
is it belt driven can you pull it back when it not running
Apr 11, 2013 | Garden
Replace right rear hieght adjuster on a toro self pace mower
Remove wheel, remove screws mounting adjuster, straighten or replace.
Oct 02, 2012 | Toro 22 in. Personal Pace with Blade Stop...
I bought a self propelled Toro mower and it is hard to pull backwards. I removed the plastic toe guard and that did not help. I also have a White "brand" self propelled and it is easy to pull backwards.
The self propel system uses a type of racheting pinion drive that sometimes gets greased up and wont release like it should.
You would need to remove the wheels and pinions and look at the shaft ends for a key, a ball and a spring. This is the "pawl" that locks the wheels going forward and rachets when the wheels go backwards.
Clean up the parts of all the aluminum colored grease and reoil with something lighter. 3 in 1 would do nicely. Reassemble.
Now the next time you start going backwards and it jams...just push the mower forwards slightly without engaging the drive and see if the unit doesnt free itself.
Good luck and be careful!
Jul 19, 2010 | Toro Garden
My toro self propelled lawn mower won't roll backwards... the wheels are locked up
My Toro Pace Master self propelled 22" 6.75 mower will not move by itself. I can push the mower and cut. It does start with no problem. I have a cable on left side of the mower that extends to the top of the handle broken off at the top of the mower and is loose. Is there a way to check to see if this is why it will not self propel. It attaches to the push handle that does I push down to propel the mower. Any suggestions?
May 07, 2010 | Toro Lawn Mower With Toro Power Tools
Self propel toro mower will not "self propel", nor will it pull backwards
that dont make sense self propel is forward only release handel pull it back could have broke a belt on the pull or wheels are full of grass
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
314 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
