Question about Yamaha RX-770
Yamaha rx770 stereo receiver
When I switch back and forth between the tuner and cd player from the input switch, it cracks on the speaker....could it be a bad input switch?
Thanks
I have the same receiver with the same problem. I fixed it by using a cleaning spray on the inside of the input switch. Deoxit 5 is the cleaner and it took care of the problem.
Posted on Jun 28, 2008
Receiver channel volume not identical
Remote controls normally do not adjust stereo volume levels independently, and I will assume that the problem is present on ALL input settings (tuner, CD, etc.). Check "balance" control settings, speakers and speaker wires for possible problems. Balance control at 12:00? Inspecting speaker wires and speakers do not reveal problems? Have you swapped speakers to see if problem reverses? Try this "process of elimination" and hopefully you'll ID the problem.
Mar 23, 2015 | Yamaha Remote Control RXV496RDS...
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
How to connect speakers to RCA model #RP-8070D
This unit is just a 5 disc CD player and cannot drive large speakers all by itself. Normally it is hooked up to a stereo receiver / amplifier which is what provides the power to drive the speakers which are wired to the back of the stereo amplifier.
If you have a home stereo, then just run the cables from the 2 AUDIO OUT connectors on the back of your CD player to the CD IN connectors on the back of your stereo.
Then turn your stereo on and select CD on your stereo input mode selector and you should be able to play the cds on your RCA and hear them through the stereo speakers.
If you do not have a stereo amplifier with speakers to connect it to, then you can always listen to it through headphones connected to the headphone jack.
Or if you have a set of self powered amplified speakers, like the kind you hook up to a computer, then you can run the AUDIO OUT cable from your cd player into those as well.
Good luck.
Apr 14, 2011 | RCA Audio Players & Recorders
Just bought a used yamaha receiver model RXv793 do not know how to hook it up.
First do not panic by seeing all sockets in the back side of the receiver.You can connect 5 speakers and one subwoofer on the speaker A switch and maybe a second pair of stereo speakers on the B switch.All the speaker sockets have red and black terminals, so do all speakers. Just get decent cables ( You can buy a whole connection Kit if you want ) and connect the corresponding outlets to you speakers.If you have a powered subwoofer connect the subwoofer input to a socket labeled Subwoofer pre out on the RXV. You will need a RCA to RCA cable for that Next you will need a coaxial or Optic fiber cable to connect a DVD player digitally. The back of the DVD player will have a socket marked coaxial out, and so does the RXV's backside. Just link them .
Turn on the system everything should work. If you are not getting DVD sound there is small button on the RXV front panel called Digital input -- set it to auto ( keep pressing the button and it will scroll through various modes). Also remember to switch on speaker A on the front panel.
Mar 09, 2011 | Yamaha RX-V793
I just purchased a Yamaha RX-V465 AV Receiver, and I cannot get any sound out of it except for when I have Tuner selected. I have my OPPO CD/DVD player hooked up via HDMI and via the stereo analog audio...
Also the test tone is working OK (Setup / Speaker Setup / Test Tone)? Have you used automatic speaker setup with the supplied YPAO microphone?
For HDMI, you need to configure the receiver to "take" out the audio from HDMI. Go to Setup / Function Setup / HDMI / Audio and select "Amp" to route the audio to receiver, or "Amp+TV" for audio to go both to receiver and to TV. You can also check in Options Menu / Signal Info that receiver has recongnized the sound and what format it thinks it is in.
Jan 09, 2011 | Yamaha Rx-v465/rxv465 Home Theater...
Kenwood Stereo
I presume you realize none of these things produces speaker amplification. A receiver would do that and facilitate graceful and simultaneous interconnections. But it's not a necessity for selective interconnective between them, just not all at the same time.
I can't find any details on anything you named except the Tuner.
Typically, the tuner would use an RCA pair to go to a receiver AUX, TUNER or other Line Level input for source selection and amplification. Lacking a receiver, run it to the Tape Deck inputs for recording.
Ditto for the CD changer, but you'll probably have to disconnect the tuner.
Jan 26, 2010 | Audio Players & Recorders
When I play CD only the right speaker is play but
first- is the tuner set to mono or stereo? if stereo, stop using the analog rca jacks and use an optical (toslink) cable to transfer your audio to your receiver. almost all cd players have this output and the same with the receiver. better still, if you are using a late model cd or bluray, and your receiver has hdmi inputs use those as they will transfer both audio and video with one cable.
Oct 29, 2009 | Sony STR-DE575 Receiver
Right speaker goes off when using Rec out on the Phono input
The switch is contaminated. Pick up some electronic switch cleaner and spray into the switch. Move the switch back and forth a number of times and that should clear up the problem. Make sure that you get the cleaner that has a lubricant included.
Dan
Jul 08, 2008 | Yamaha RX-595 Receiver
Connect audio components for recording Cassette to CD
Try this since you do not supply model numbers. If your receiver and CD have digital audio connector (coaxil or fiber) hook the receiver output to the cd input.
If you do not, see if there is a spare set of RCA jacks for output. If not, just hook up the cd player in the cassette jacks-there is always a cassette in and out-and hook your cd player to an auxillary input or use the cd player input.
Remeber though, cassettes have inherently more noise than cd so your cds will not sound like a pre-packed cd.
Dec 22, 2007 | Sony SS-X90ED Main / Stereo Speaker
Can't get B Speakers to work
Use the remote and switch it to be in the sub mode (top right corner of remote) It is here (in the sub mode) that you can change volume and inputs.
May 29, 2007 | Onkyo TX-DS555 Receiver
Yamaha RX-770 Logo
583 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
