My compaq pressario wont start up windows vista, it only appears a black screen with different commands
  • 11,800 Answers
That is the boot option screen - if you can't get past it then Windows is totally corrupted and the only thing you can do is to reinstall it.
Posted on Nov 05, 2010
Configuring updates screen
Try booting up in Safe Mode and see what happens.
Turn off the computer, then hit the power button to turn it back on and immediately start hitting the F8 key repeatedly until you see SAFE MODE. Take the Safe Mode option and let it boot up. Safe Mode will look different to you, the screen will be darker and the icons bigger, this is normal. If it boots up ok, then do a restart into your normal windows mode.
Try running the check disk utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice the percentages going from high to low, this is normal. Let it run to completion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows. Try doing a Repair Install that way you don't loose your data, documents, music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair when the options appear.
In Vista and Windows 7 you want to get to the recovery console and look down at the bottom of the window for the Dos Command.
Jun 08, 2012 | Computers & Internet
I have a laptop that is a Compaq Presario and upon start up it says the following a kernel file is missing from the disk Insert a system diskette and restart the system how do I fix this
Which kernel file are you missing?
Try running the Check Disk Utility.
To run the check disk utility you will need a repair disc or a operating system disc. Put the disc in the cd drive and boot from it. You want to get to the Dos Command Prompt (Black screen with white letters) and type the following commands and press enter after each one:
sfc /scannow
chkdsk /r
Jun 04, 2012 | Compaq Computers & Internet
My Compaq Deskpro EN P933 has been giving me headache for long. The last time i shut it down it was working normally.The next morning i powered it on it din,t even get to the BIOS.It displayed a black...
A Black screen with what message?
Try the check disk utility.
Jun 01, 2012 | Compaq Computers & Internet
My compaq laptop keeps blinking at the start up screen what should i do
To run the check disk utility you will need a repair disc ora operating system disc. Put the disc in the cd drive and boot fromit. You want to get to the Dos Command Prompt (Black screen with whiteletters) and type the following command: chkdsk /r
Check disk will run well over an hour or two and you will notice thepercentages going from high to low, this is normal. Let it run tocompletion. Then reboot machine.
If check disk fails to solve your problem you might have to reinstall windows.Try doing a Repair Install that way you don't loose your data, documents,music, pictures, videos or programs.
In windows xp you get to the dos command prompt by selecting R for repair whenthe options appear.
In Vista and Windows 7 you want to get to the recoveryconsole and look down at the bottom of the window for the Dos Command.
May 20, 2012 | Compaq Presario 1210US Notebook
My compaq presaario turns on and off without loading
Does it show a blue screen? If so you want to disable the automatic restart so you can read the error message.
Apr 24, 2012 | Compaq Computers & Internet
Compaq presario cq56 flashes from red start screen to cursor back and forth and cant open f11
Sounds like your boot files or system files has either a corrupt file or missing file.
You will need a repair disk or system disk to remedy this. Put the disk in the cd drive and boot from it. You wan to get to a dos prompt (black screen with white lettering) and run the Check Disk utility.
Apr 01, 2012 | HEWLETT-PACKARD Compaq Presario CQ56-129NR...
Black screen v6000 laptop "HELP Please"
It appears the hard disk has been wiped/formatted and does not have an operating system installed.
You need to get a Windows Vista installation CD and if the Windows label on the bottom of the laptop is still attached then this label has the product installation code.
Boot up with the Windows Vista installation CD to install the Vista operating software then you need to install the Presario device drivers.
You can download the device drivers from the Compaq/HP WEB support/download page. Make sure you select your model laptop and the Windows drivers you require and install them. Click on this link to download the drivers: -
www.compaq.com/country/cpq_support.html
Mar 19, 2012 | Compaq Computers & Internet
Windows vista wont start
Ok,Try safe mode with command prompt,If you can get to the command prompt
Type these in one at a time and press enter ( let each one completely finish before typing the next one.)
Bootsect.exe /NT60 c:
Bootrec.exe /FixMbr
Bootrec.exe /FixBoot
Bootrec.exe /ScanOs
Bootrec.exe /RebuildBcd
bcdedit.exe /import C:\Boot\BCDBackup
May 21, 2009 | Toshiba Satellite A135-S2276 Notebook
How to install turbo c in vista home basic compaq pressario lapto??
how to run turbo c in full screen mode on vista operating system.
when i am running turbo c it's gives  a message that vista not support full screen. what should i do please suggest me.
Sep 13, 2008 | Compaq Presario Notebook
Computers & Internet Logo
Alun Cox
