Question about Compaq Computers & Internet
I can log in to my computer i for got my password
  • 3,940 Answers
Assuming you are talking about logging in to Windows XP here are some things you can try:
Windows XP Home Edition or Windows XP Professional in a workgroup loadTOCNode(3, 'whattotry'); 1. Log on as an administrator. a. Restart the computer, and then after the Power On Self Test (POST), press the F8 key. b. On the Windows Advanced Options menu, use the arrow keys to select Safe Mode, and then press ENTER. c. Select Microsoft Windows XP edition, and then press ENTER.
Note In this step, edition represents the correct Windows edition. d. On the To begin, click your user name screen, click Administrator, and then type the administrator password. e. Press ENTER, and then click Yes. 2. Reset the password. a. Click Start, and then click Control Panel. b. Click User Accounts, and then click the name of the user account that you want to reset the password for. c. Click Change the Password, and then type a new password. Note If you do not want to use a password, click Remove password, and then continue to step "e." d. Click Change Password. e. Restart the computer, and then try to log on to Windows XP again.Reference: http://support.microsoft.com/kb/321305
If that doesn't work, there is a more drastic way to do this:
you can easily change or wipe out your Administrator password for free during a Windows XP Repair. Here’s how with a step-by-step description of the initial Repair process included for newbie’s. 1. Place your Windows XP CD in your cd-rom and start your computer (it’s assumed here that your XP CD is bootable – as it should be - and that you have your bios set to boot from CD)
2. Keep your eye on the screen messages for booting to your cd Typically, it will be “Press any key to boot from cd”
3. Once you get in, the first screen will indicate that Setup is inspecting your system and loading files.
4. When you get to the Welcome to Setup screen, press ENTER to Setup Windows now
5. The Licensing Agreement comes next - Press F8 to accept it.
6. The next screen is the Setup screen which gives you the option to do a Repair.
It should read something like “If one of the following Windows XP installations is damaged, Setup can try to repair it”
Use the up and down arrow keys to select your XP installation (if you only have one, it should already be selected) and press R to begin the Repair process.
7. Let the Repair run. Setup will now check your disks and then start copying files which can take several minutes.
8. Shortly after the Copying Files stage, you will be required to reboot. (this will happen automatically – you will see a progress bar stating “Your computer will reboot in 15 seconds”
9. During the reboot, do not make the mistake of “pressing any key” to boot from the CD again! Setup will resume automatically with the standard billboard screens and you will notice Installing Windows is highlighted.
10. Keep your eye on the lower left hand side of the screen and when you see the Installing Devices progress bar, press SHIFT + F10. This is the security hole! A command console will now open up giving you the potential for wide access to your system.
11. At the prompt, type NUSRMGR.CPL and press Enter. Voila! You have just gained graphical access to your User Accounts in the Control Panel.
12. Now simply pick the account you need to change and remove or change your password as you prefer. If you want to log on without having to enter your new password, you can type control userpasswords2 at the prompt and choose to log on without being asked for password. After you’ve made your changes close the windows, exit the command box and continue on with the Repair (have your Product key handy).
13. Once the Repair is done, you will be able to log on with your new password (or without a password if you chose not to use one or if you chose not to be asked for a password). Your programs and personalized settings should remain intact.
I tested the above on Windows XP Pro with and without SP1 and also used this method in a real situation where someone could not remember their password and it worked like a charm to fix the problem. This security hole allows access to more than just user accounts. You can also access the Registry and Policy Editor, for example. And its gui access with mouse control. Of course, a Product Key will be needed to continue with the Repair after making the changes, but for anyone intent on gaining access to your system, this would be no problem.
And in case you are wondering, NO, you cannot cancel install after making the changes and expect to logon with your new password.
Cancelling will just result in Setup resuming at bootup and your changes will be lost.
Ok, now that your logon problem is fixed, you should make a point to prevent it from ever happening again by creating a Password Reset Disk. This is a floppy disk you can use in the event you ever forget your log on password. It allows you to set a new password.
Here's how to create one if your computer is NOT on a domain:
  • Go to the Control Panel and open up User Accounts.
  • Choose your account (under Pick An Account to Change) and under Related Tasks, click "Prevent a forgotten password".
  • This will initiate a wizard.
  • Click Next and then insert a blank formatted floppy disk into your A: drive.
  • Click Next and enter your logon password in the password box.
  • Click Next to begin the creation of your Password disk.
  • Once completed, label and save the disk to a safe place
How to Log on to your PC Using Your Password Reset Disk
Start your computer and at the logon screen, click your user name and leave the password box blank or just type in anything. This will bring up a Logon Failure box and you will then see the option to use your Password Reset disk to create a new password. Click it which will initiate the Password Reset wizard. Insert your password reset disk into your floppy drive and follow the wizard which will let you choose a new password to use for your account.
Reference: http://pubs.logicalexpressions.com/pub0009/LPMArticle.asp?ID=305
Posted on Jun 14, 2008
H0w do i log in to my allready youtube account on my second computer
Your user name and password is saved in no 1 computer and it logs you in, Google ( login youtube ) then on the drop down window login with username and password. computer will ask save password for this site click ok if want computer to remember next login.
Dec 25, 2014 | YouTube Computers & Internet
Tip
HOW TO REMOVE OR CHANGE ADMINISTRATOR PASSWORD WHEN LOG IN TO YOUR COMPUTER
HOW TO REMOVE OR CHANGE ADMINISTRATOR PASSWORD WHEN LOGGING-IN TO THE COMPUTER.
If you have lost or forgotten your password for logging in to a computer. Here's how to remove or bypass the password without reintalling your operating system.
Here is the procedure how to remove or change the ADMINISTRATOR PASSWORD.
1. You need to download Windows Password Unlocker in any computer and save it to CD as installer or to USB flash disk or external hard drive. Here is the link for software to download for a small fee http://www.passwordunlocker.com/windows-password-recovery.html
2. Using CD/DVD, put the CD/DVD with password remover software and boot up your computer.
3. Press any key when there is message appear to boot up to CDROM.
4. It will run the password remover and you can change or remove the password and after that it will boot it up and run without password.
5. For usb flash disk or external drive, open your log in menu and enter wrong password. After that, a reset password will appear and click the reset password. It will ask you to put new password and do not put any password and click next. Then it will open now the Windows display setting.
on Dec 24, 2010 | Computers & Internet
Tip
How to log on to Windows XP if you forget your password or if your password...
Introduction:
If you forget your Windows password or if your password expires, you
must reset your password before you can log on to your computer. This
article contains two methods that you can try to reset your password
so that you can log on to your computer again. These steps only work
if you have previously created a password reset disk for the computer,
or if you can log on as an administrator to assign a new password to
your account.
If you do not have a reset disk or cannot log on as an administrator,
unfortunately, you may have to reinstall Windows XP and all other
programs that were installed on the computer before you can use the
computer again. This is for security. Without these safeguards, anyone
could reset a password to anyone else's computer and gain access to
private information.
This article is intended for a beginning to intermediate computer user.
You may find it easier to follow the steps if you print this article first.
More Information:
Reset forgotten or expired password
If you forget your password or if your password expires, there are two
methods that you can use to log on to create a new password. One
method is to use a password reset disk, if you have created one. By
using the password reset disk, you can recover your user account and
your personalized computer settings. Another method is to log on using
the administrator account to delete the forgotten password and then to
If you have a password reset disk, go to method 1. If you do not have
a reset disk, go to method 2. The instructions guide you through each
step and help you verify that the problem is resolved.
on Mar 28, 2010 | Computers & Internet
I have a password on my computer to log in, how do i go sbout resetting the password on my computer, i dont have a usb reset plug for the computer
go to safe mode by press f5 at first screen, then log in as administrator
after log in go to user account, click your account that you insert password, and you can remove the password from there
restart your computer and you will log in without the password
Feb 19, 2011 | ASUS Eee PC 1000HE Netbook
Forgot my log on password how can i reset password
I have included instructions for windows XP, however, no matter what operating system you have installed on your notebook, this solution may work. When windows is installed, there is an adminstrator account installed on the computer by default. Most often, the password is left blank.
So, if you restart your computer, hit control-Alt-Deletecan when the user account page appears and type in Administrator as the user and leave the password blank, you may be able to sign onto your computer to reset your user password. Step by step instructions are listed below. If you cannot access your computer using the administrator account, you many have to use the restore partition on your computer to do a restore of windows. This will bring windows back to the original configuration as it was when the computer was delivered to you. You should be able to chose a "Non destructive" restore so that your hard drive is not formatted and your documents will not be erased.
If you need further instruction on using the restore utility on your Pavilion notebook, let me know.
Brian
Here are the step by step instructions:
Log on as an administrator to reset the password
loadTOCNode(3, 'moreinformation'); If you did not create a password reset disk, you may be able to log on as an administrator to reset a forgotten or expired password. The steps to do this differ if the computer is a stand-alone computer or a member of a workgroup of two or more, or a member of a domain. Select the appropriate set of steps from the following to try to log on as the administrator to reset the password.
loadTOCNode(4, 'moreinformation'); To log on to a computer as the administrator to reset a password, try the following steps.
a. Restart the computer.
b. Press CTRL+ALT+DELETE two times, and then type the name of the administrator user account.
c. In the Password box, type the administrator password, and then click OK.
Note If the administrator password is set to a blank password, do not type a password before you click OK.
. Click Start, and then click Run.
a. Type control userpasswords2, and then click OK.
b. On the Users tab, click the name of the user account that you want to reset the password for, and then click Reset Password.
c. Type a new password in the New password box, and then type the password again in the Confirm new password box, and then click OK.
d. Restart the computer, and then try to log on to Windows XP again.
If you can log on as an administrator to reset your password and you can now log on successfully, you have resolved the issue, and you are finished.
Dec 30, 2010 | HP Pavilion 110-1030NR Notebook
I forgot the password to log
If you forget your Windows password or if your password expires, you must reset your password before you can log on to your computer. This article contains two methods that you can try to reset your password so that you can log on to your computer again. These steps only work if you have previously created a password reset disk for the computer, or if you can log on as an administrator to assign a new password to your account.
If you do not have a reset disk or cannot log on as an administrator, unfortunately, you may have to reinstall Windows XP and all other programs that were installed on the computer before you can use the computer again. This is for security. Without these safeguards, anyone could reset a password to anyone else's computer and gain access to private information.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | IBM ThinkPad T21 2648 Notebook
I lost my log in password
If you forget your Windows password or if your password expires, you must reset your password before you can log on to your computer. This article contains two methods that you can try to reset your password so that you can log on to your computer2_bing.gif again. These steps only work if you have previously created a password reset disk for the computer, or if you can log on as an administrator to assign a new password to your account.
Thanks.
Apr 30, 2010 | ASUS Eee 4G Notebook
Forgot password to get into windows
When I forgot Lenovo Windows 8 password, I got Windows Password Recovery Tool Ultimate to support me make a password reset disk with USB and reset password efficiently!
Apr 30, 2010 | Computers & Internet
Forgot password
Apr 29, 2010 | HP 530 Notebook PC
Problem to log in.
Start up in safe mode pressing F8 on boot up and select safe mode. When in the system under administrator there will be option for you to delete the password on your account. Re boot then enter again with no password.
Feb 22, 2007 | Toshiba Satellite M100 Notebook
Computers & Internet Logo
176 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
