I have a Roper washing machine Model RAX4232PQ0. I goes thru the normal wash and spin cycles but when it is done, the clothes are still wringing wet. It sounds as if the last spin cycle is not spinning fast. I put it on the last spin cycle again and it seems to dry out the clothes some more. The pump is working and drains the tub before spinning. What could be causing this problem? (Note: I did replace the moter drive coupling and that did not solve the problem.)
    President:
  • 1,430 Answers
The clutch likely needs to be replaced. They are inexpensive and easy to replace.
Posted on Nov 05, 2010
Clothes are not wringing out
Washing Machine Won't Wring Out Clothes Properly - DIY ...
www.diychatroom.com/.../washing-machine-wont-wring-out-clothes-pro...
Apr 16, 2013 - 6 posts - ‎4 authors ... thing - the spin cycle doesn't really seem to do an effective job of wringing out theclothes once. ... Sounds like it's not spinning fast enough.
Washer does not wring out the clothes. Clothes are dripping ...
Nov 23, 2015 | Washing Machines
I have a Roper washer Model RAX4232PQ0 When it drains and spin cycle comes on it makes a very loud rubbing slash screeching sound and when we open it it smells like a burning smell Not rubber burning but...
Known problem:
A Failed switch Ark-Les part #8318084
Incident report on there website:
I have a Roper model #RAX4232PQ0 top-loading washing machine. The door switch wore out, short-circuited, and caught on fire. The machine continued to operate, so it took a little while to figure out where the smell was coming from. The failed switch is an Ark-Les part #8318084.
Dec 19, 2013 | Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
The spin cycle on my washing machine is not working, the clothes are still wet when the cycle is finished
Make sure that the clothes are not too heavy ( jeans and sweats ), and put in the machine evenly. If the machine is off balance, it won't spin fast enough to wring out the clothes.
Oct 14, 2010 | Hotpoint Washing Machines
My Roper washer will not spin on the spin cycle.
IF ITS A TOP LOADER YOU MAY HAVE A BROKEN LID SWITCH. LOOK DON THE HOLE IN THE TOP WHERE THE LID PIN GOES CAN YOU SEE THE LID SWITCH ARM? IF ITS NOT FLUSH WITH THE HOLE ITS BROKEN. SOMETIMES YOU CAN STICK SOMETHING THROUGH THE HOLE TO ACTIVATE IT
Jan 15, 2010 | Washing Machines
On delicate cycle clothes wringing wet when done
check drain hose kink or belt adjustment...worn clutch...basket drive
Aug 13, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Roper Washer Wont Spin Out
Probably a bad lid switch. Open the control panel. Disconnect the lid switch wire connector on top of the cabinet under the control panel. Make a small insulated jumper wire and insert it into the wire that is still connected to the control panel. Set the timer to spin. If it spins replace the lid switch in the cabinet. If not, replace the timer.
May 05, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
359 people viewed this question
Top Washing Machines Experts
