Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
I con,t formot the usb it says there is a writeprotect
  • 977 Answers
Hi!
Follow this:
  1. Plug the USB pendrive to your computer.
  2. Download this tool.
  3. Run the tool.
  4. Pendrive is unprotected! :)
Best regards,
Pelu.
Posted on Nov 05, 2010
Memory card not formot plz help
Try a different formatting program. SDFormatter sometimes works, when otheres won't.
Jul 03, 2014 | SanDisk Electronics - Others
How do I remove write protect from my CMB USB 2.0 USB device?
To disable the write protection:
    1.From the Start menu, click "Run", type "regedit", and press <Enter> or click <OK>.
    2.Navigate to HKEY_LOCAL_MACHINE > SYSTEM > CurrentControlSet > Control > StorageDevicePolicies.
    3.Double click on "WriteProtect" and change the value to 0 (WriteProtect = 0 for disabled; 1 for enabled).
    4.Close the registry editor and restart Windows.
    5.After Windows starts, test writing to your USB drive.
    Important Note:
    Serious problems might occur if you modify the Windows registry incorrectly. **PLEASE** make sure that you follow these steps *exactly* and *carefully*. For added protection, back up the registry before you modify it in case you have trouble so it can be restored.
    For more information about how to back up and restore the registry, follow the steps as in the KB Article: http://support.microsoft.com/kb/322756/
Mar 04, 2014 | Electronics - Others
How can i format writeprotected pendrive
    Important Note:
Mar 04, 2014 | PNY 4GB USB 2.0 Flash Drive - Grey/Black
Device media is write protected
To disable writing access to USB drives and make all USB drives has only read-only access, follow these steps:
  1. Run Registry Editor (regedit).
  2. Navigate to the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control
  3. Create a New Key named as StorageDevicePolicies.
  4. Highlight StorageDevicePolicies, and then create a New DWORD (32-bit) Value named as WriteProtect.
  5. Double click on WriteProtect, and set its value data to 1. write-protect-usb.jpg
Once set, all users on the computer is now blocked and prevented from copying, transferring or writing any files, documents and data to the USB disk drives, without the need to restart or reboot computer. Any attempt to download or copy files to USB drive will return the following error message:
The disk is write protected.
The media is write-protected.
Remove the write protection or use another disk.
usb-removable-disk-write-protected.jpg To revert and remove the blocked write access to USB drivers, just delete the StorageDevicePolicies registry key, or delete the WriteProtect registry entry, or change the value data for WriteProtect to 0.
For user who doesn't want to manually editing the registry, simply download the following registry registration files to enable or disable the write protection (block writing attempt) to USB removable drive. Double click the .reg file unpacked from the .zip archive to merge the registry key entries.
Download DisableWriteToUSB.reg
Download EnableWriteToUSB.reg
The trick works in Windows XP SP2 and SP3, Windows Vista, Windows Server 2003 and 2008.
Feb 27, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
I cant open my sd card.when I am insert sd card in computer display there is disc
  1. Go to registry, follow the path
  2. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\StorageDevice Policies
  3. There you will find a key "WriteProtect", check the value.
  4. If value is '0' then OK, if '1' then make it '0'
  5. To change the value, double click at the key "WriteProtect", one manu will pop up. change the value.
Aug 20, 2010 | PNY 1GB microSD Memory Card
I can't disable write protection
Check for any tabs on the disk itself. There should be one. Slide the tab in the opposite direction.
Jul 25, 2009 | Computers & Internet
Formot nomber
*#7370# full format
Jun 30, 2009 | Nokia N72 Cellular Phone
How to disable usb windows xp in a local user means only one usre
Go to Run command and type regedit
HKEY_LOCAL_MACHINE\System\CurrentControlSet\ Control\StorageDevicePolicies
Now add a new DWORD called WriteProtect and put the value as 0 to disable write privileges to the USB port. To reverse the step, either delete the WriteProtect REG_DWORD or toggle the value to 1 which will enable the port.
Mar 09, 2009 | Microsoft Windows XP Professional
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
504 people viewed this question
Top Kingston Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
