Question about Amana Refrigerators
For the first time beginning this summer, my Amana refrigerator (1999) is dripping from the freezer into the refrigerator below. I thought maybr because it was a very hot summer and it was self defrosting often. Is it worth or can it be repaired? e-mail address: annekaras@comcast.net
  • annekaras Nov 06, 2010
    Thank you for your help. Because I am not sure what value the euro has in dollars at this time, I do not know how to figure my cost but at least I know what needs to be done and can be a little more intelligent about the repair.
    Anne
    It seems to be a solution at this time and I will use this knowledge when I have a repairman to the house. Thank you for letting me know what the problem is.
    Anne
  • 22,114 Answers
Yes i think its worth repairing as a engineer shouldnt charge a lot to top the gas up for you ,be warned though that R134 gas has escaleted in price since last year though i have just paid 238 euros for new 15kg bottle for topping up ,thats only the gas though no depoisit or anything on the bottle .should cost no more than 100 euros tops even in madrid to check and gas a fridge about 70 euros around here
Posted on Nov 05, 2010
Amana refrigirator bottom freezer moderl ARB 2214CW it leacks water on the bottom onto the floor it pudles in small amounts all the time at first I thought I spilled somthing.
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Aug 31, 2010 | Amana ARB2217C Bottom Freezer Refrigerator
My refrigerator is dripping water from the top (bottom of the freezer). It seems to be worse in the summer.
Check the freezer drain and blow out with comp air
but it may be frozen defrost water in the drain
If so you will have to turn off ref 24 hrs to defrost the ice in the drain.
if this was helpful please rate me.
Leo Ponder Appliance-Tyler,Texas
imufo2@sbcglobal.net
Aug 02, 2010 | Amana Refrigerators
Water is dripping from the ice maker into the ice tray
you may have a bad water valve. the valve could be not completely shutting off. when you hear the ice maker begin to cycle open the freezer door and watch it. look to see if the plastic tube coming thru the back of the refrigerator is not leaking after the ice maker has completed its cycle. if it is dripping and running over your water valve is bad.
you may also check the level of the ice maker. sometimes you can be out of level causing a slight leak.
Jul 11, 2010 | Amana DRS2660B Side by Side Refrigerator
Water dispenser drips how can I fix it?
There are two possibilities. The water control valve is leaking while off or the water has air bubbles in the supply line. If you just recently changed the water filter and the air has not been completely purged this will cause a drip until the air is out. You can also remove the water line at the control valve and see if it continues to flow. Just us care by unplugging refrigerator first. Be right back with part numbers, Sea Breeze
Dec 22, 2009 | Amana ABD2233DES Bottom Freezer...
Water dripping from inside of freezer compartment.
The condensate drain has a blockage further down and possibly in one of the turns as it leads down to the pan below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie2.gif that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
- Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 24, 2009 | Jenn-Air JCD2389G Side by Side...
The drip pan
Take off the toe grill on the bottom of the refrigerator and the drip pan will be sitting down low in the left hand side of the opening. You have to lift it up and pull pretty hard to get it out. If you have pet hair ( and probably even if not) you should periodically vacuum out the coils in this section -- you can see them when you remove the drip pan. I just got a LOT of dog hair out of mine last night.
Sep 07, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Side by side Amana freezer/refrigerator thawing.
The doors not being shut can make it freeze up,Just thaw again and make sure the doors get shut each time and see what happens,just post back details if it doesn't work after thawing
Aug 05, 2009 | Amana ASD2625KE Side by Side Refrigerator
Water build up in the freezer
sorry about the delay in responding, saw an open call, hope this is helpfull too you !!!
sounds like a drain clog in the freezer compartment above. remove the freezer rear panel and totally defrost the evaporator area, directly under the evap you see( under all taht ice) a small drain hole that has become frozen over, try defrosting with either a hair dryer( not a heat gun too much heat youl melt everything) or by pouring hot water donw the drain until you get a free flow of water down the tube. after its clear reassemble and you should be fine
Jan 24, 2009 | Amana ACD2232HR Side by Side Refrigerator
Ice maker drips water
In most of theses cases the dripping is caused by the molding in the ice maker cracking and the water is wicked out. On some ice makers you can replace the complete molding but its usually easier to just replace the ice maker.
Nov 02, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Refrigerators Logo
57 people viewed this question
Top Amana Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
