Question about Thermador DW44Z Built-in Dishwasher
My dishwasher DW44zp/21 does not drain completely after a wash for the last few days. A small puddle of water remains at the bottom of the washer.
  • 3,037 Answers
Some of the most common reasons include that the drain hose isn't working properly, the sump pump isn't working correctly, or possibly there is a plumbing problem in your home's drain lines.
You will want to remove the cover from the air gap and clean it out. This may remove any blockage that could be causing the dishwasher problems while draining. You'll also want to examine the drain hose and ensure that it is free from anything that would hinder the water from draining completely. It's also possible that the hose has something obstructing it and will need to be flushed to remove the object. If you have checked the air gap and the drain hose and can't locate the problem, then you may want to consider calling a professional plumber. He may need to replace the drain valve or hose. Let me know what you find and whether you need anything else.
Benjamin
Posted on Nov 05, 2010
My dishwasher will not drain completely
Most likely, the drain pump is clogged or the filter for the main pump is clogged with goo. If, during the drain cycle, water is just "peeing" into the drain line or sink drain, something is clogged. Broken glass, food, bones, etc., can find a way into the main pump mech or into the drain pump. You didn't specify what model washer you have but check the round removable filter found in a lot of Frigidaire dishwashers. Yours could be square, rectangular, etc. Get the users manual if you need help finding out how to clean the filter! Remember, if water can't move freely through the filter, your washer won't spray strongly either. Also, dishwashers will not drain out every drop of water--they will drain past where you can see the water but there will always be a small puddle of water in the motor. This keeps the seals moist and prevents dry-rotting, cracking and leaking.
Aug 18, 2015 | Frigidaire Dishwashers
My dishwasher won't drain completely in the last cycle so in other words water remains in the bottom of the washer. Don't know how to take it apart and clean out.
Here is a tip that I wrote that will help you with your dishwasher not draining problem...
Dishwasher Problems - Water will not drain out
heatman101
Nov 11, 2010 | Dishwashers
Dishwasher overflowed, garbage disposal still works. Ran the dishwasher and noticed food and debris shooting back into sink thru garbage disposal. Water was on floor. Upon completion of full cycle, water...
Before loading into the machine you have to remove food particles. Washer will wash the greasy surface. If particles are left in the dishes, the same will find entry to the drain system. Check the drain filter in your machine. Clean them. Mostly problem will be solved!
Apr 08, 2010 | GE 24 in. Profile PDW9880JSS Built-in...
Sometimes the next morning after I have washed a load of clothes that evening, even though at night there is no water in the bottom of the machine, the next morning there is a small puddle in the bottom. ...
i think the drainage of your washing machine, is not functioning well,or it has a leak, that's why some water remain in the bottom of your machine..
check this one..
http://www.washingmachineadvisor.com/
Feb 02, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Water left in compartment
You need to elevate your dishwasher drain hose under the sink. The water going down your disposal side is running down the hose into the dishwasher.
Nov 05, 2009 | KitchenAid 24 in. KUDS25 Built-in...
My Bosch shx46A05UC no longer will drain.....it
I ran into the SAME problem with my Bosch SHX46A06UC /21. The problem ultimately ended up being a clog in the air gap vent, (meaning, SOMEBODY ran the dishwasher without the bottom filter being in place or not in place properly). Remove the air gap cover and upper surface nut to drop the air gap vent into the area under the sink. Disconnect the hoses from the air gap vent filter (placing a bucket under the hose from the dishwasher). Run the drain cycle on the dishwasher. The washer should drain into the bucket and let you know that your pump works and that there are no clogs or kinks in the drain hose. (This will also remove the clog if so). The air gap vent's smaller hose connection is MOST LIKELY where your clog is. Look at the upper end of the air gap vent. You'll see a couple of clips on opposite sides of each other, that hold the air vent cap in place. Using a small screwdriver, (or your hands if you can), depress the clips (or one at a time) to get to the point where you can pull the vent cap off the filter. Either use water or a thin, long blade screwdriver to force any objects out of the filter. You should now have full flow through both branches of the filter. Using water and a rag, clean the vent cap and filter. Mount the air gap vent filter back onto the sink. Reconnect the hoses and remove the dishwasher's internal filter(s) and clean them as well while you're at it, making sure to remove any debris that might remain underneath the filter and has the chance of clogging the unit again.
Run the washer again to test. You should be good!
Cheers!
Oct 13, 2009 | Bosch 24 in. SHX46A05 Stainless Steel...
Water not completely drianed after running, is this normal?
Hello. There should be no water left in the bottom at the end of the wash cycle. There are a few possible causes, the most common one being debris in the small pump that pumps the water out of the machine and into your sink drain, or debris in the hose vrom the dish washer to the sink, or a blockage where the dishwasher empties into your food disposal [if you have one installed].
May 31, 2009 | Kenmore 15762 Dishwasher
Ran the dishwasher and the water didn't drain completely. Checked the drain line for clog - it was clear. Scooped out the remaining water (barely covered the flat wire mesh filter in bottonm of the...
Hello Ramona Doug,
Try disconnecting power from your dishwasher for a few minutes to clear the memory and then reapply power again. Start a wash cycle without dishes on the hottest water setting and after a few minutes.. pause the wash and add a few cups of white vinegar to the wash water.,. that will help break up deposits in the system.. See if that gets you going properly.
Regards
Oct 13, 2008 | Bosch Dishwashers
Water won't drain, Soap Door open with soap still there and stops running at Plate Warmer cycle
Reset the washer manually. Close the machine, and slowly advance the timer till you here the fill valve start. Then let it do it's thing
Jul 21, 2008 | GE Nautilus 24" Built-in Dishwasher
Thermador DW44Z Built-in Dishwasher Logo
295 people viewed this question
Top Thermador Dishwashers Experts
ray gallant
Are you a Thermador Dishwasher Expert? Answer questions, earn points and help others
