Model 417.42042100 Makes a LOUD knocking noise in the spin cycle. During fast spin, it seems like the machine will burst apart shaking and knocking.
  • katereit Nov 05, 2010
    Sears Kenmore Front Loading Washer. It squeaks on the slow spin & knocks violently on the fast spin.
    Top Expert:
  • Washing Mach... Master
  • 76,164 Answers
Thanks for the model number but need the make as well to use the model number to research problems with the machine associated with this noise you have, it would save time to know if this is a front loading machine as well.
Posted on Nov 05, 2010
  • 1 more comment
  • yadayada
    yadayada Nov 05, 2010
    Thjanks for that, the problem is caused by the tube bearing failing and this in turn causes the tube shock absorbers and or springs to fail, the entire tube assembly must be removed and the bearing replaced and all the parts checked for damage associated with the tube stablitization, this is a huge job and not for the average home repair person unless you are very talented and have a really good set of hand tools
  • yadayada
    I am sorry that should read TUB not tube.
  • yadayada
    If you are going to attempt the replacement of the parts yourself this video at Youtube will help to take apart the washer. You can order the parts from the web link below the Youtube link.
    http://www.youtube.com/watch?v=zmVJh-cWqJI
    http://www.repairclinic.com/Shop-For-Par...
Washing machine makes loud knocking noise
drain or drain pipes blocked
bearings gone
Aug 18, 2014 | Washing Machines
Loud noise during spin cycle
Open the cabinet top and check along the sides for a broken or out-of-position damper. Shake the mechanism in several directions to help locate. Hope this helps!
Jun 12, 2010 | Kenmore HE2 Plus Front Load Washer
Loud knocking during finial spin cycle
replace the balance springs from the bottom of the tub to the frame there weak and letting the tub rock
Jan 18, 2010 | Washing Machines
Washer makes a lot of noise during spinning
we need the brand and the model
but for starters, please check on the links below.
http://forum.appliancepartspros.com/washer-repair/4501-washer-makes-extremely-loud-noise-during-spin.html
http://www.thestuccocompany.com/maintenance/Washing-Machine-noise-during-spin-cycle-169980-.htm
http://www.askmehelpdesk.com/appliances/washing-machine-noise-during-spin-cycle-167960.html
Sep 10, 2009 | Whirlpool Washing Machines
Frigidaire was tub makes loud thump noise during spin cycle....
Need more information to make an accurate diagnosis, try removing the front panel (two screws at bottom) and visually check first the belt (all the way around) and then the springs that hold the tub suspended.
I would bet on the belt.
Quentin
Jul 22, 2009 | Frigidaire FEX831CS Top Load Stacked...
Knocking in washer
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
good luck.........
Mar 28, 2009 | Maytag Performa PAV3200
Kenmore series 80 washer makes loud knocking noise during spin cy
Unless your front loader is set firmly on concrete and leveled to perfection, the force of a heavy wash load spinning in excess of 1000rpm will create a bit of vibration and noise.A firm footing is your best defense against to much movement.
Also due to the earlier movements during the spin cycle, the shocks that are used to dampen the spin cycle might have been broken or damaged.
If the problem persists inspite of proper levelling, please do check for the shocks or might have them replaced them for good.
Dec 14, 2008 | Kenmore 24032\24036 Top Load Washer
Rattling noise during spin cycle
Nov 12, 2008 | Maytag MAH2400A Front Load Washer
Kenmore Front load washer model 3 970-c29042-00 The washer is making a loud noise and shakes like something is loose when the drum is turning..
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Aug 04, 2008 | Kenmore 46462 Front Load Washer
Loud noise while agitating in wash cycle
If you begin dissassembly from the tub down, you wil come to the transmission with the spindle sticking out of it. If you undo the bendable tabs all around the transmission it comes apart in two halves. Careful, its full of oil. The spindle has a plastic gear bolted to the bottom of it. It meshes with other gears in the tranny. It has sheered teath and is making the noise.
Sep 24, 2006 | Admiral AAV7000A
Washing Machines Logo
153 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
