Question about Acer Aspire 8920-6671 Notebook
My laptop starts to boot then shuts down before the screen boots up and then after three seconds it reboots itself and then there is no display
  • Acer Master
  • 13,433 Answers
You are actually willing to pay a dollar to have your problem solved?
But seriously it sounds like the computer is faulty, most likely the mainboard, its pretty common in acer machines, it also could be overheating especially the video chipset gets hot and may cause the machine to hang or shutdown unexpectedly.
Well the only real fix for this problem, you won't like it, is to contact acer to get it repaired - IF you are in warranty.
If you are outside of warranty, contact any local repairer to get the fault confirmed before replacing anything in the machine.
Cleaning the machine from dust etc, might help a bit, then also reinstalling windows, by repeatedly tapping on ALT + f10 during start up. if your computer crashes during recovery there clearly is a serious problem.
Posted on Nov 06, 2010
  • Acer Master
  • 11,800 Answers
Hardware failure - the motherboard has a fault and that can only be fixed in a repair shop.
Posted on Nov 05, 2010
Please I hope someone can help me. The laptop is stuck on the reboot and select proper boot device screen.. i can get to the bios though
unplug your laptop, remove the battery and wait for three minutes. then install back your battery and power on. right after you power on your laptop press shift key together with f9. release the keys when the laptop begin to boot. follow the instruction on the display.
Sep 04, 2015 | ASUS X551MA-DS21Q 15.6" Notebook - Intel...
Tip
To Reboot or recovery from CD/DVD problem with OS "Aser"
If you don't press the Alt+F10 key combination or use the recovery CDs, can you get into Windows? Boot with the recovery CDs in. When at the Acer logo during POST, press the F12 key. Then, select boot off CD or DVD. Alternatively, you can enter the BIOS by pressing the F2 key at the Acer logo and go to the Boot tab. There, you can set the CD/DVD drive as the first item in the boot order.
When turning your laptop on, before Windows starts booting, a splash screen appears first (usually with the logo of the manufacturer). Look on the splash screen (usually at the bottom) for a key (usually F10 or F11), assigned for System Recovery. Some manufacturer(s) (e.g. HP) place the recovery files to a hidden (mostly) partition of the hard drive, the others give a Recovery CD/DVD with the laptop.
or
  1. Press the start button from the start menu depending on your operating system(win 2000,xp)
  2. Press Ctrl+Alt+delete combination from the keyboard.
  3. If you have a power button on your laptop keyboard,it could also be useful by pressing and hold it down for few seconds
N.B: "Ctrl+Alt+Delete" can exit you from usage and trigger a reboot
or Shutdown. Try and reboot using the operating system. Attempt to use the key combination that will allow you to exit from the operating system and restart the laptop. Be patient, as it may take some time if it has locked up. Hold down the power button. If the operating system's answer to the rebooting will not work, find and hold down the power button of the laptop. This should cause the device to shut itself off. You'll have to press the power button again to power it back on, completing the reboot.
Unplug from the wall and remove the battery. If restarting via the operating system and the power button do not work, unplug the laptop from the wall outlet, and remove the battery from the laptop. This will cause it to power off immediately. Allow time to reboot. Give the laptop time to cool down before you power it back on if you had to do this manually.A few seconds should do unless you have additional problems.
All the Best!
on Sep 13, 2010 | Computers & Internet
My laptop won't start up it turns on but then nothing
Unplug the power, remove the battery and then hold the power button for 30 to 60 seconds. Then reattach the power and attempt a boot.
If it boots, then shutdown, add battery and restart.
The laptop's screen display may remain black when there is a corrupted graphics driver, or a problem with the LCD display's back light. (Try tilting the screen to 30 degrees and see what happens.)
It could possibly be that your outputting to the wrong screen - most laptops have a "Fn" button that can be pressed in conjunction with a little screen on the keyboard to switch to either internal display or external (say F1 or F2).
Mar 04, 2015 | Computers & Internet
Restart laptop and it fails to boot up
Have you tried hitting "esc" key repeatedly once you start the computer? This or the F11 key should take you to the black screen that lets you select to reboot in safe mode etc.
If it does, toggle down to the start in safe mode, let it boot up, then shut down. After shutting down, I have been able to reboot computer into normal mode.
Hope this helps.
Nov 27, 2013 | Acer Computers & Internet
WHEN I TURN ON THE WIRELESS THE LAPTOP SHUTS DOWN
Most likely you have a bad driver. Try connecting your machine directly to the wired network. Go to your manufacturer and download the latest drivers.
If your machine does not have a hardwired port, you can bring the drivers with a flash from another machine.
Also, you might try booting in safe mode. After booting, press F8 until you get asked for what you want to do. Try booting in safe mode with networking. If you are able to boot here, you know that the wireless card itself is ok. So, get the latest drivers.
Hope that helps.
May 25, 2010 | JVC MPXV841US Notebook
Fujitsu Siemens Lifebook C1020 laptop display and booting problem
change the ram memory ...this issues appear when the ram memory is not functional like it should..if you have a way to borrow some just to try ..you will make an ideea
If you have more than one boards in the laptop..remove one by one ..and try to boot with the other/s until you locate the one with problem..
Jan 30, 2010 | Fujitsu Siemens LifeBook C1020 Notebook
My laptop rebooted itself for updates. However, the screen turns blue before it gets to the main screen. It says it shut down windows so it doesn't damage my computer. I don't know how to fix it if i can't...
Boot the laptop, and immediately after you see the DELL splash screen, start pressing F8. This will display a startup menu with a few different options. Choose the option that says "Last Known Good Configuration" - this will back out the last update changes that may have caused your problems. Good luck!!
Oct 21, 2009 | Dell InspironTM 1501 Notebook
Laptop won't boot up.
it looks like your rams are broke down. can you write your notebook model /mark down ?
May 27, 2009 | Computers & Internet
Booting repeatedly at compaq window itself,it is not takes up WINDOWS OS.
Solution 1:
When you start the system, press F8 and then select "Last known good configuration". If it does not work the first time, try at least three or four times.
Solution 2:
You can try installing the OS again but you will lose the data in your c drive.
Solution 3:
Check with the BIOS configuration, Take a note of the original configuration before you make any changes.
Jan 15, 2009 | HP Pavillion ZV6000 Notebook
Dell 2407 a04 Turns on (for 2 seconds) then off
your pc may be set to a resolution that is out of range for the monitor. Boot into "Safe mode" reset the Display settings to 640 x 480. reboot into normal mode then change the screen settings to your desired resolution.
Sep 07, 2007 | Dell UltraSharp 2407WFP 24" LCD Monitor
Acer Aspire 8920-6671 Notebook Logo
189 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
