Question about Garden
Do i need a gasket between the muffler and the exhaust hole on a sears 6.75 self propelled mower
  • 143 Answers
You don`t need a gasket but the engine might be very noisey without it. Stephen.
Posted on Nov 05, 2010
Why wont my mower start and gas comes out of muffler
carb is flooding out ether bad plug or your carberator needs rebuilt
Aug 25, 2014 | Toro Lawn Boy Self Propelled CARB Walk...
Troy bilt self propell model# 184986 need throttle cable, cant find
look on sears parts online but a lot of newer mowers they don't use them anymore
Apr 07, 2012 | Troy Bilt 5.5hp Self Propelled Mower
Rear wheel is broken need replacement
I believe they carry them at Sears, since many of the Sears mowers use the high wheels. Tractor Supply also has a pretty large selection of mower wheels. Best of luck to you.
James
Aug 25, 2011 | Mtd 22" White Outdoor Self Propelled High...
I have a new 650 sears craftsman self propelled 22" lawnmower that will not start. I have gone through the prime bulb instructions, still no luck.\r\nAny ideas? Walter in Alberta Canada.
could be the priming bulb gasket between the air-filter assy. and the carb.
I have the same lawnmower and if I prime with gas from a can it will start but stop after a few seconds. When I push the bulb I can hear air leaking in this area. You can replace the gasket by removing the back half of the air-filter assembly. I am looking to buy a gasket today I let you know how it works out! Thanks Ron
Oct 24, 2010 | Craftsman 675 Series 190cc 22" Briggs ...
Craftman 6.6 self propelled mower blowing oil between the upper &
The Breather or Dip Stick Gasket at Engine. It you had the mower turned on its side befor problem, its coming out of the Muffler. This will go away but check your oil level.
Sep 08, 2009 | Craftsman Garden
Craftsman self propelled lawn mower will not propell
Take off the cover up front on the self propel. Engage the self propel and make sure your cable is not broken. If that is ok then remove the wheels and inspect the molded cogs on the inside of the wheels and make sure they are not stripped out. If they are stripped go to www.sears.com and on the tool bar click on parts direct. Under model number enter yours and it will take you to a parts diagram. Get the part number for the wheels and go to local small engine parts dealer and get new. You can also do a search on the web for the wheels and maybe get them cheaper.
Good luck and let me know if this helps or you need any more help.
roundo4
Aug 16, 2009 | Garden
Poulan Pro® Self-Propelled Mower
Make sure the engine is not overfilled with oil most of the small rotary mower engines hold about 20 oz of oil.It will push oil out of the breather is the oil level is too high or if the mower was tipped on its side. Also check the air filter to make sure the oil did not saturate it.Once you correct the problem the smoke should clear up.
Aug 05, 2009 | Poulan Pro " Pro" Self Propelled Mower
How do I clean the carb on my 2yo sears 6.75 front whell self proplled push mower
take it off and remove the fuel bowl and spray every thing with carb cleaner ; put the straw that comes with the cleaner on nad spray in every hole on the carb; remove the float,and valve, taking note so you know how to go back with it, and spray in that hole also re assembly
Jun 12, 2009 | Mtd Yard - Man 160cc, 21" Self - Propelled...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
