Question about Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System
Panasonic kx tg8231cb. The screen says "New Voice Mail" (and the time and date) instead of showing the wallpaper. What do I do to see the wallpaper? I've gone through the settings, made sure there was no voice mail and it did not help
  • 3 Answers
Press and hold the "mute" button until you hear a beep. That should clear your screen!!
Posted on Dec 22, 2010
Get rid of New Voice Mail
Hello Fortina, it appears you have voicemails from your telephone company. If you wish to eliminate your voicemail service then we recommend you contact your telephone service provider.
Apr 22, 2014 | Panasonic Kx-tg6533b Dect 6.0 Plus...
HELP WITH MESSAGE ON SCREEN
You may have 1 unlistened to voicemail. Please listen and then delete all of your voicemails to have a fresh start.
Mar 03, 2014 | Panasonic KX-TG7733S 1.9 GHz Digital DECT...
My phone rings once and shows "Incoming call" on the LCD screen and when I answer, no one is there. People calling say the phone only rings once or it goes directly to voice mail.
You have to go into the menu and reset the rings so that the phone will ring at least 4 times. Your owners manual should give you directions to do that. You can also call Panasonic.
Aug 29, 2011 | Panasonic KX TG4023 Cordless Phone
I have a Panasonic KX-T7636 phone system. We have a new receptionist and want to change the main menu greeting so that one of the options is "press zero for (new assistant)" instead of the old...
You have a Panasonic 7636 PHONE. The system is either a TDA/TDE or NCP. The Voice Mail system is either embedded or a TVA and it comes with a set of instructions. Custom service announcements and company greetings are administered from the message manager's mailbox 998. Check your original installation notes and documentation for how to do that.
Carl
Jul 08, 2011 | Panasonic KX-T7636-B Corded Phone
Cannot get the message light to light when a message is left on a Panasonic KX T7667. Also cannot get phone to display date and time instead of Name and extension number on same model.
The second question is easy. Press the TRANSFER button on the idle phone until date and time show up.
As far as MW, have someone ring your phone and dial "4". If the light goes on, you have a notification problem in the voice mail system. Look at the assignments in the VM system to make sure the extension number is paired to the mailbox.
If it doesn't lignt on the "4", the phone is probably defective.
Carl
Mar 11, 2011 | Panasonic Lands Phones
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Panasonic KX-TG8423E Time & date display issue...
Same thing happened to me on one of the phones but if you go into display setup you can choose the wallpaper with time and date showing or without. You need to choose the - with time showing on each phone individually.
Jan 10, 2010 | Panasonic Lands Phones
Changing the voice mail access number.
press menu
arrow down to "Initial setting"
press select
"voice mail" will sow on the screen
press select
"store VM access#" will sow on the screen
press select
edit the number and press save
Dec 20, 2009 | Panasonic KX-TGA630S Cordless Expansion...
Panasonic KX-T773 reads "102:" instead of date/time
Your extension reads 102 because that is the extension #.
Press either the tranfer key or the " * " star key and your display will change to time and date or just the date.
Oct 28, 2009 | Panasonic KX-T7731 Corded Phone
KX-TGA101S Model
On the newew phones 93's, you need to hold the "OFF" button till it beeps. Time should appear along with the handsets number.
Mar 12, 2008 | Panasonic KX-TGA101S Cordless Handset
Panasonic DECT 6.0 Expandable Cordless Phone System with Digital Answering System Logo
521 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
