Question about Maytag Atlantis MDG6400AW Gas Dryer
Maytag Atlantis Gas Dryer
I have had a service man come and fix it but he didn't. He canceled payment.
At first He thought it was the sensor for the glow bar because it worked after he opened it and cleaned it off.
Then he thought it might be the vent which is all clear.
After he left I put a load of wet clothes in and heard the flame come on but the heat did not continue to cycle through to dry the clothes.
I have tried it on all cycles and nothing.
I even took the front off while there were a few dry clothes in and cleaned the sensor and started it up and watched the flame come on again.
I put the front back on put some wet clothes in and heard the flame come on and still no continued cycle of heat to dry clothes.
Any advice?
  • 22 Answers
I would sstart by replaceing the gas valve coils they are located on the top of the gas vavle . they will weaken over time and will not stay energized to open the primary and secondary vavle
Posted on Aug 22, 2008
One of the fins in my Maytag gas dryer, model Atlantis has come loose. I need to flip the tiop and need assistance
Unplug unit first and turn off gas .Page 5-2 of the service manual below (Similar to yours) will cover removal of front and top. Good Luck.
Service Manual
Sep 09, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag gas atlantis dryer. It starts but after a
I love the Maytag Atlantis!!! This sounds like your motor may be bad. It's NOT the element or it would not heat at all. Hope this helps!
Aug 13, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
How do I replace the gas valve coils on my maytag atlantis gas dryer?
usually the gas valve is not the issue on these dryers after ten years of doing service calls i have only ever changed one. have you replaced the element that lights the gas? they have to see a certain resistance before they will open the gas valve. these will usually develop a hairline crack they will still glow red but not open the valve. when you replace it make sure you do not touch the element as this will shorten its life.
Apr 27, 2009 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag dryer wont shut off
Is it an auto sensor shut off? If so, it may be that your hose is plugged and so actually takes that long to dry the clothes.
Mar 13, 2009 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis Dryer not heating up
Best guess is that one of the two solenoid coils on the gas valve is faulty, one has two connections and the other has three. Always replace BOTH solenoids even if only one has failed.
Aug 10, 2017 | Maytag Atlantis MDE7400AY Electric Dryer
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
MAYTAG atlantis MDG6400AW, dryer not heating
no we can fix it its proab a heatyer coil or thermial limiter if you reply ill help mater of fact did you have it on auto dry ?
Apr 03, 2008 | Maytag Atlantis MDG6400AW Gas Dryer
Maytag atlantis gas dryer
timeout...I'm guessing you mean that the timer on off doesn't turn anything off. If this is a mechanical timer unit, the contacts are welded. If electronic, your relay is probably welded. Replace the item. If you do go inside, unplug the unit, and then find the relay or contact set and see if they are actually welded. Most units have a diagram on the back. Follow it through with a multitester.
Dec 17, 2007 | Maytag Atlantis MDE6400AY Electric Dryer
Maytag Atlantis MDG7400AW Gas Dryer not drying clothes
This problem doesn't sound right, but you could have a bad moisture sensor.
May 19, 2007 | Maytag Atlantis MDG7400AW Gas Dryer
Maytag Atlantis MDG6400AW Gas Dryer Logo
215 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
